Question about Infinity IL 50 Main / Stereo Speaker
My infinity il-60 tweeter is not working. I have a replacement in route. How do i take the speaker apart to get at it?
4 Suggested Answers
  • 5 Answers
SOURCE: Infinity RS 2/RS 2000.2 blown tweeter
Check out www.speakerrepair.com They're out of Orange County but they have a great business and do very good work and good replacement parts.
Posted on Mar 04, 2009
SOURCE: How to take the speaker apart to repair or replace
Take off/unscrew the upper bass/mid , insert your hand and gently twist the tweeter magnet assembly anti-clockwise about a quarter of a turn, and remove thru upper bass hole Peter Speakerworks.com.au
Posted on May 20, 2010
  • 6771 Answers
SOURCE: the tweeter and highs are not working on my
Yes you can! odds are it is the tweeter, and a female jack clips on the speaker, just make sure the polarity is correct by looking at + or- side so the wire goes to the correct side on the new driver also. The speaker replacements must be ordered from Infinity to keep a matched sound.
Posted on Jan 26, 2011
Got a pair of Infinity RS-8b. They are missing the middle speaker. What should I replace it with?
I got a couple of answers:
http://www.speakerrepair.com/page/product/home-audio-tweeters/10-236.html
http://speakers-parts-tools.info/tag/infinity-speaker
Jan 12, 2013 | Infinity RS-8 Speaker
Can infinity tweeter be repared
Well...the short answer is yes. It can be rebuilt by a someone that does this but if this is a car speaker you just need to replace the tweeter. If it is part of an all in one speaker you can still replace just the tweeter but I would just replace the speaker at that point.
Oct 01, 2012 | Car Audio & Video
Polk rti6 tweers blown...4 speakers.....can these tweeters be repaired
It may be possible to have the tweeters repaired by Polk however if you have the skills your least expensive route would be to replace the tweeters and install them your self. I would recommend using the internet to find replacement tweeters either through Polk or possibly Ebay, or Amazon. Each tweeter has 2 wires that must be removed before uninstalling. Note the polarity and where they connect. red is + POSITIVE , BLACK IS - NEGATIVE
Apr 15, 2011 | Polk Audio RTi6 Main / Stereo Speaker
Back speakers can't handle bass
you need to replace all the speakers in the truck except the front tweeters if you have them. I replaced all four with new infinitys from futureshop. Installed it was near 500 dollars. You need to get 2 ohm to match the infinity deck if yours is infinity. Most other systems are 4 ohm, these are 2 x 2 ohms for 2 and 4 ohm use. the factory's are garbage and use paper cones. The rears have plastic caps holding the tweeters in. On all four the paper was ripped away from the magnet and it caused them to vibrate and shake, once replaced with 180 watt infinitys...great sound.
Jul 06, 2010 | 1997 Jeep Grand Cherokee
Tweeter plays and very low volume when in back by
This sounds like I would be trying a new crossover network module.
Jerry G.
Aug 06, 2009 | Infinity IL 10 Main / Stereo Speaker
Mar 02, 2009 | Audio Players & Recorders
6x9s cone not working!
can you swap speakers with other one?if so do this and if speaker still sounds bad it is definately the speaker. there is really no way to take speaker apart and repair
Oct 02, 2008 | Infinity Reference 6412cf Coaxial Car...
Component speaker not working
The easiest thing to test is to try swapping the connections of the front component speakers at the amp connections. If the problem follows the speakers, the issue is probably with the speakers. I would triple check (again) the speaker wire connections. It's also possible the crossover for the driver side component speakers has an issue (thus why the tweeter worked for a while).
If the problem stays on the drivers side, the issue is probably with that channel on the amp. Triple check the RCA connections for that channel.
It's much easier to test other speakers on an amp channel versus trying to check it with a meter.
If the driver's door is "abused" often, my initial thought is the wiring at the speaker or the wiring in the speaker (to voice coil, within the crossover, etc) is the most likely culprit.
Apr 10, 2008 | Infinity 475A Car Audio Amplifier
TweeTer Not working.
The only way I can think of to check is to disconnect the leads to the tweeter, then check resistance with an Ohm-meter...no reading means dead speaker.
Dec 28, 2007 | Car Audio & Video
Infinity IL 50 Main / Stereo Speaker Logo
158 people viewed this question
Top Infinity Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you an Infinity Audio Player and Recorder Expert? Answer questions, earn points and help others
