Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Hi - I recently set the security on my router but am having trouble connecting to wireless on my home laptop. All other devices seem to be ok (2 work laptops, IPad, Ipod) and I get a message saying that the settings on my home laptop are different to the router. All other devices linked to the wireless and asked for the password, this was entered and the connection was made. Any advice greatly appreciated. Thanks
    Guru:
  • 825 Answers
This error message usually occurs in windows vista & win7 if the settings saved on the computer doesnt matches with the settings in the router...
You can get rid of this message by deleting the list of preferred networks from your computer...
To delete the preferred networks, follow the method given below...
Open control panel > open Network & Internet(double click) > open Network & Sharing center(double click)
On the far hand side left you will have an option called "Manage wireless networks" If you click that, you will see the list of preferred networks that are already saved in your computer... Now select your network, make a right click and select "Remove network" Select "ok" for all the warnings...
Thats it..! you are done..! Now search for the list of available wireless networks in range, you must be able to see your network name without any error mesages... Select your network and click connect, it will ask for the network key(if you have setup one)... Enter the key and get connected...! You must be able to go online now..!
Posted on Jan 04, 2011
Testimonial: "Thanks for the quick response and the step by step instructions - I'll give that a go and see how I get on. "
  • Manikandan Raj Jan 04, 2011
    Thank you...! Im pretty sure that it will work...!
Have wifi.....but can't get internet connection. Other devices at home working ok.......is it settings or something?
If other items work from your router and seem OK, check you are actually connected to your router with wifi. Check it is not looking at another router.
Resetting the router may help. Just power it off, wait 2minutes and then power on again.
Oct 04, 2016 | HP Computers & Internet
Connecting to a "2WIRE" wifi connection. Says the
I understand that you are having trouble connecting your Nintendo DS wirelessly to your 2Wire router. The solution is simple, your Nintendo DS only supports WEP (Wireless Encription Passkey) security. It is highly possible that your 2Wire router's wireless security is set to WPA. That means you will need to reconfigure your router so that it will be utilizing WEP as a security for your wireless connection. To be able to do this, you need a couple of information from the one who setup your router. 1. User name of your router 2. Password or your router.
Once you have gotten this information, you will need to access your router configuration page through one of the computers that is linked to your 2Wire router by typing http://gateway.2wire.net on the address bar of your browser.
It will be asking you for the username and password. If nobody had setup or changes the username and password of the router, use this default username and password of a 2Wire router. Username: (none) Password: Wireless or Username: 2Wire and Password: (none). Try any of the two. If it does not work, try admin and the word password for the password or any other combinations of the two.
Once you have entered the router's configuration page click the Home Network Tab and then click on Wireless Settings. You will see there a portion that says Wireless security. In that area, you will see a drop down where you can choose what kind of wireless security you want on your system. As I have said, the Nintedo DS does not support any other wireless security setting but WEP. That means you will need to change the drop down to WEP. That also means after changing this, you will need to reconfigure your other wireless devices (like your laptop) to use WEP as well.
Jul 21, 2011 | Nintendo DS Lite Console
Recently bought a Sony Vaio F series laptop (VPCF133FX). I'm having problems connecting to my wireless router Linksys WRT120N. I have restarted both the modem and router numerous times. I have reinstalled...
Can you try the laptop somewhere else? Try Mcdonalds or Starbucks, work, school, etc. Does it see the connection there? Does it connect ok there. Break your troubleshooting it into small steps. If it works else where then something is set wrong in your wireless at home. If it doesn't work else where then keep troubleshooting the laptop itself. When your watching the SSID show up then disappear are all wireless SSID also doing the same. Can you see neighbor and just watch if they drop in and out? Can you confirm your router is the same network speed. B,G or N. Make sure its a on a speed the laptop can do. Can you change your router and disable the security for a little while and see if that effects how the laptop connects. IF it works without security then check your security settings, Maybe the router is set to an old or newer type if security, Try different one's if it works correctly with security off. Can you login into your router and look at the logs its recording. Maybe there's a clue in it. Re-confirm the gateway and subnet are correct. I don't know if your XP, vista or 7, but open a command window or Dos prompt and type "ipconfig /a" It will list all the network information. Also type "ipconfig ?" For a list of options to use with the command. You may need to a release or renew the connection.
Jan 20, 2011 | Sony VAIO(R) VPCF133FX/B 16.4" Notebook PC...
Hi, our new lap top will not connect to the wireless network at home. Other laptops here have no problem. The PC identifies the network and asks for the security key, which we then type in. Frequentlt the...
More than likely if you haven't downloaded the correct drivers, maybe?
As it works with the LAN cable, I would think the pc must be OK, I would check the settings for the router and re boot the laptop.
Hope that helps.
Dec 30, 2010 | Sony Computers & Internet
Router connection loss
Your router might have been reset and now the settings on your devices does not match that of the router. If you have wireless security enabled on your router make sure your devices are set up to match those settings.
Jan 24, 2010 | 2wire 2700HG-B Router (2700HGB)
2wire312
You may want to double-check if the wireless adapter on your laptop is enabled. If it is enabled, try to view the available wireless networks on your wireless connection and select the name of your wireless network. You may also want to check your wireless router if there is a wireless security enabled. It is important that you know the wireless settings on your wireless router to make sure that the wireless adapater settings on your laptop match the settings on the wireless router.
Jul 02, 2009 | 2wire HomePortal® 1800HW Router...
Random wrong passwords
Any router that your connecting to wireless, without a password, does not have wireless security set up on the router.
Any other wireless router that you are trying to connect to that does not allow you to connect wireless, has wireless security set up and that same security must be set up on the wireless device (like laptop or desktop, whatever is not connected via ethernet cable.).
Reply back what you find and I will be glad to help more.
Feb 04, 2009 | Adaptec Computers & Internet
Laptop
A wireless router is device where in you can connect 2 or more computers in your home network. It is secured and is capable or providing you wireless connection. You can also get to connect printer wirelessly. Basically theres a lot of stuff you can do with a router depedning what brand it is and model. Let us know if you needed how to set it up. Just lemme know.
Jun 14, 2008 | Computers & Internet
One laptop can not seem to connect
Ok, I had the same problem, heres how to fix it.
1; Turn off your wireless computers.
2;Go to your routers setup page and restore the factory defaults.
3. Name your wireless network only so that you can see it on your laptops.
4; Get onto the network with all of your computers.
5; got to the routers setup page and set the security.
You will have set the security while the computers are already on the network.
Apr 19, 2008 | NetGear DG834G Router
DI-524 One wireless connection makes others not ok
This is unusual, as it seems the router is allocating two pc's the same IP address. Go into your routers settings (internet browser and type the router address, eg 192.168.1.1)' and look at Client DHCP list and look at the IP addresses that each pc has been given and see if two are the same, they should be one digit difference, that being the last. Also go into the properties of both your pc's wireless cards and ensure that they are set to obtain an ip address automatically.
Jan 10, 2007 | D-Link AirPlus DI-524 Wireless Router
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
214 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
