Question about Olympus MJU 300 Digital Camera
Lens does not come out
When I open the slide, the lens does not come out. The battery is not the
problem, because the window shows saved pictures allright. There are more people who had this problem, but no clear solution has been offered. The suggestion was made to open the slide and press below the S of Olympus, but this had no result
Repair by Olympus costs almost as much as a new camera, because it ran out of warranty.
  • tjeerd Jul 10, 2008
    I feel that no real solution is offered. Indeed I can selftech the camera, but without any details of the construction, I think that this is very risky.I would appreciate to have an additional expert opinion, e.g. about where to start on the camera. Thanks
  • Olympus Master
  • 19,396 Answers
Try pulling the lens gently out, using your fingernail while you turn on the camera.
Try also helping the extraction process by tapping gently the back of the camera with the palm of your hand while you turn camera on.
If this does not work you will probably need to take apart the lens gear, in this case may be better to contact a repair shop.
Posted on Jul 10, 2008
  • Olympus Master
  • 13,433 Answers
My opinion on camera repairs @ home is not to do it.
a few repair places I can recommend are
http://www.advancecamera.com/repair/
and
http://www.precisioncamera.com/
  • Ekse Jul 10, 2008
    well after rereading your problem.. try tapping it on the sides.
  • Ekse Jul 10, 2008
    I tryed to repair my camera, and I do have quite alot of experience in electronics, guess what! I never got it back together + it stopped working totaly. what a pain those small flex cables are inside the camera.
  • 2,071 Answers
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras AV cable, and turn the camera on in picture review mode. Have no idea why this would work, except that quite a few people have reported some success with it.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
    Genius:
  • 1,226 Answers
if you can self tech your camera, the mechanical mechanism maybe disalignment. you need to disassemble the unit. Most of this problems can be resolve by the registered olympus tech. In your case you have the right to repair it by yourself but warning all parts are sensitive.
melnavz
    President:
  • 1,257 Answers
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hopefully all this information helped,
I can not save my pictures?
Dear Darlene
To save your photos, you should already have done the following:
You clicked on "Create New Slide Show". A new window appeared - it is called "Slide Show Creator - Select Photos". You clicked on "Add Photos". You looked for your photos on your computer, selected them and then clicked on "Open" to add them to the slide show. (I'm leaving out the parts on transition, soundtrack and duration, since they do not relate directly to your question.)
Now, click on the "Next" button at the bottom of this window. You are now at the window called "Slide Show Creator - Options". At the section called "Name Slide Show" type a name for the show. To save the photos: 1) click on the "Finish" button at the bottom of the window. The window disappears and you are now back at the Menu window (where you started). 2) Click on the word "File" at the top left of the window. Go to "Save Project" and click on it. A window called "Save As" appears. Type in the name you want to give to the project and click on "Save" at the bottom right. You have now saved the project (including photos) on the computer - it should be in your "My Documents" folder.
If you go and have a look in your "My Documents" folder, you will notice a file (or files) with a ".slw" extension. These kind of files contain information about the slide shows you've created. They form the individual parts - or chapters - of your project. They are only used by the SlideShow Expressions programme. You will also notice another kind of file, one that ends with a ".ssp" extension. It should contain the name of your project, because that's what they are: project files. It contains all the information that is needed for the programme to burn or view your project: the chapters, the photos, the soundtrack, etc. This is the file you will load when you've just opened SlideShow Expressions and want to continue making or editing your existing project(s). If both these kinds of files are there, "slw" and "pps", it is a good sign and means that your project (and therefore the photos contained in them) has probably been saved correctly.
I hope I understood your question correctly.
If you have a legitimate copy of the programme, there will be a User's Guide on the install disc. It is good to consult this when you have questions. Simply insert the install disc and once it activates a window on your screen, click on the relevant link (something like "User's Guide") to access the guide. You can also copy the User's Guide from the disc to your computer. This will be usefull if you're going to use the guide a lot. To copy it, insert the install disc and then go to "My Computer". Right-click on your ROM/Writer drive (it may display the name of the programme), and click on "Explore" to look for the User's Guide on the disc. It is a pdf file. You can copy it and then paste it somewhere on your computer for quick access.
If you still have questions, you may make use of the free online support: go to www.individualsoftware.com/support.
The best of luck to you.
Nov 05, 2012 | Individual SlideShow Expressions
How do you set the background on a Dell to show a slideshow of all of the pictures?
To use your own pictures
1.
Find the pictures that you want to include in your slide show. All of the pictures must be located in the same folder.
Open Desktop Background by clicking the Start button Picture of the Start button and clicking Control Panel. In the search box, type desktop background, and then click Change desktop background.
2.
If the pictures that you want to use aren't in the list of desktop background pictures, click the Picture location list to view other categories, or click Browse to search your computer for the folder where the pictures are located.
Picture of the Picture location menuLook for pictures in other locations on your computer.
3.
Select the check box for each picture that you want to include in your slide show.
By default, all of the pictures in a folder are selected and will be part of the slide show. If you don't want all of the pictures in the folder to be included, do one of the following:
Clear the check box for each picture that you want to remove from the slide show.
Picture of one check box cleared in a group of selected photosClear the check box to remove a picture from the slide show.
Press the Ctrl key, and then click each picture that you want to remove. Only the selected pictures will appear in the slide show.
To create a slide show of pictures on the desktop, you must select more than one picture. If only one picture is selected, the slide show ends and the selected picture becomes the desktop background.
If all of the pictures in the folder are selected, any new pictures that you add to the folder will be added to the slide show automatically.
4.
Do one or more of the following:
Click an item in the Picture position list to crop the pictures to fill the screen, fit the pictures to the screen, stretch the pictures to fit the screen, tile the pictures, or center the pictures on the screen.
Click an item in the Change picture every list to choose how quickly the slide show changes pictures.
Select the Shuffle check box to have the pictures appear in a random order.
5.
Click Save changes.
To use pictures that Windows provides as part of a theme
1.
Open Personalization by clicking the Start button Picture of the Start button, and then clicking Control Panel. In the search box, type personalization, and then click Personalization.
2.
Under Aero Themes, click a theme to apply it to the desktop. With the exception of the Windows 7 theme, all of the Aero themes include a desktop background slide show.
3.
To change the theme's default slide show pictures or settings, click Desktop Background.
4.
By default, all of the pictures associated with a theme are selected and will be part of the slide show. To add pictures from other themes to your slide show, do one of the following:
Point to each picture that you want to add to the slide show, and then select its check box.
Picture of one check box cleared in a group of selected photosPoint to a picture, and then select its check box to add it to the slide show.
Press and hold the Ctrl key, and then click each of the pictures that you want to add. Only the selected pictures will appear in the slide show.
5.
To change the slide show's settings, do one or more of the following:
6.
Click Save changes.
Your slide show will be part of the unsaved theme that appears under My Themes.
For information about customizing and saving themes, see Create a theme.
You can find more themes to add to your collection in the Personalization Gallery on the Windows website.
For information about customizing a desktop background slide show, see Make changes to your desktop background slide show.
Aug 04, 2011 | Computers & Internet
Spilled water on digital camera. saved pictures will show on screen but can not get camera to take pictures
take the batteries out, open all the covers, place plastic wrap around lens (glass part) set it in a container of white rice close the container lid and try it in the morning.
Jun 20, 2011 | Panasonic DMC-TZ5 Digital Camera
How can i save a picture as my screen saver
Assuming you are using windows XP on this:
Create a new folder in "my pictures " folder
Copy the images you want to use into there
On your desktop, RIGHT click and choose "properties" to open the display settings
Click "Screen saver" and choose my pictures slideshow
Click "settings" to open the options for this
Click browse to point to where you saved the images
Set the duration and timings to suit your tastes
Exit by clicking Ok and the OK to exit the display settings
Apr 11, 2011 | Acer Aspire One PC Notebook
Olympus Stylus 840 - lens won't open
you need to take it or send it for repair. There is nothing you can do yourself.
Olympus Stylus 840 Repair - Google Search
Mar 23, 2017 | Olympus Stylus 840 Digital Camera
How can I see a Microsoft Power Point slide show, size 3.30MB ?
Unless your picture frame supports Power point files you can't load it straight on to it, but you could try this.
  1. Open the powerpoint file in MS Powerpoint (or download the free powerpoint viewer)
  2. Use the Print Screen button (also marked PrtSc) to copy the screen to the clipboard
  3. Paste into a picture program (such as MS Paint, free with Windows)
  4. Save the files as a JPEG
  5. Load these onto the picture frame
Hope this helps
Jan 20, 2009 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 | Cameras
Connection
re enter widow CD untick other only tick Broswer & reinstall. restart computer
Apr 23, 2008 | Computers & Internet
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Lens only comes half way out
I had a problem that may be related to yours. From time to time, whenever I opened the cover, the lens wouldn't work properly. It would make a grinding noise and then when I took pictures they would all come out out of focus. After much fiddling about, I eventually discovered that if I set ALL RESET to FALSE on the SETUP menu, it returned to normal. Possibly this could fix your problem. Otherwise maybe its a battery problem. My camera sometimes refuses to take pictures when the battery is low.
Sep 24, 2007 | Olympus Camedia C-350 Digital Camera
Olympus MJU 300 Digital Camera Logo
245 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
