Question about Sewing Machines
Bernette 46, unable to use hand wheel, needle is stuck in low position, so unable to remove it.
  • 66 Answers
SOURCE: I was given a brother
Hey RM check the bobbin area and see if the hook area has any thead cought in it you might have to remove the bobbin case to see it
Posted on Jan 30, 2009
SewTechWayne
  • 186 Answers
SOURCE: Brother Innovis 4000 D stopped sewing
These machines are known to freeze up in the needle bar crank, even when only a couple of hours old. If it is less than a year old, a Brother certified service center will fix it under warranty.
neona_techie
SOURCE: Needle position wheel is stuck
Remove the top cover. Note where the shaft of the the needle position wheel enters a metal casting under the wheel. Old oil deposits gum up the shaft. Heating this area with a hair dryer usually frees up the shaft. Be careful you don't use too much heat that would melt the plastic wheel. Lubricate the shaft with tri-flow and work it in by turning the wheel while it is warm. If it sticks again after it cools, repeat the process. It may take several hours or days for the tri-flow to penetrate and free the wheel up.
Advice provided by the amazing Ray White at whitesewingcenter.com
Posted on Jul 12, 2009
SOURCE: needle centering wheel is stuck tight and cannot
On these machines, the shaft UNDER the centering wheel fits into a bushing, and this is what normally rotates. The wheel is fixed to the shaft. Penetrating oil needs to be placed UNDER the centering wheel but above the bushing. We solved this problem on two machines by saturating dental floss (the kind used to clean braces) with penetrating oil. Insert the floss UNDER the plastic wheel around the shaft, with the two ends sticking out the slot for the centering wheel. Then cycle the floss in and out of the area around the shaft. Let it soak and repeat. It takes some time, but it worked, and did not require disassembly of the machine. Greased Lightning also was used. Kithen grippers help with rotating the wheel.
Posted on Sep 25, 2009
chris592
  • 86 Answers
SOURCE: Imagine BabyLock Serger. The hand wheel only moves
I suggest having a professional look at it, if you don't have one near by. You can try to fix it yourself, but if release the gears the machine willl most likely get out of time and not sew properly.
How to release gears on each gear are 2 set screw, usually a hex head. just turn it counter clockwise and it will release.
But remember the machine will have to be timed, which is a bit to difficult to explain over text chat.
Posted on Apr 02, 2011
Testimonial: "Thanks for the suggestion. I took it in for service today because I don't want to ruin the machine. This is the second time the gears have locked up, "
Pfaff 1467 needle jammed in fabric and hand wheel stuck
Be sure to unplug the machine.
Loosen the screw that holds the needle in place (even though the needle is still stuck in place) and try moving the handwheel so the needlebar will raise to its highest position.
Try to remove the bobbin case from the machine. If the thread is tangled, you can try snipping (patiently and carefully) with small scissors and removing the loose threads with tweezers. Do NOT yank! Just keep working until the thread knot becomes loose enough to actually remove the bobbin case and the needle.
May 01, 2017 | PfaFF Sewing Machines
Needle is stuck in down position and manually the wheel won't move
Try removing the bobbin case. Usually the thread is holding the needle in place, therefore the hand wheel will not operate. Once you get the thread released, it should all come free.
Sep 15, 2016 | Simplicity Sewing Machines
Hand piece is very tight to turn and unable to use the machine
Make sure to clean/remove all the lint, thread, dust, etc. that may have built up in the bobbin area, around the feed dogs, and under the needle plate. Sometimes gunk build-up will prevent the hand wheel from turning. Remove the bobbin & bobbin case from the machine and the needle and see if the hand wheel will turn. If not, then it may be time for service.
My hand wheel is hard to move and will not make complete turn unless...
https://answers.yahoo.com/question/index?qid=20100518074139AAeeykz
Help My Needle Hand Wheel are Stuck Sewing Machine Jammed
Apr 20, 2016 | Sewing Machines
Why does my hand wheel feel springy? why won't it turn and move the needle?
Is the bobbin winding mechanism activated? That will usually prevent the handwheel from turning and moving the needle. Otherwise, it could be broken...
Feb 23, 2016 | Bernina BERNETTE 65 Mechanical Sewing...
Automatic needle threader stuck
You may have a thread stuck in your bobbin area. Remove your bobbin, brush gently with a clean soft brush to remove dust and/or thread bits, then gently wiggle your hand wheel back and forth, and brush again. This should free up your machine.
Jul 09, 2014 | Janome Sewist 500 Sewing Machine
Needle sticks
Bent needle and dirty machine or machine in need of a proper COA (tuneup) are my first thoughts.
Jan 21, 2014 | Bernina Bernette 75
The hand wheel is not moving the needle at all
Check the hand wheel. There should be a smaller wheeel in the center of the hand wheel. Make sure it is locked in(turn center wheel clockwise or could be counter clockwise til snug)
Dec 07, 2013 | Janome Memory Craft 3000
The needle is stuck in the Shark 612C model sewing machine, any solutions?
Try http://www.fixsewingmachine. com I also suggest that you clean bobbin case. Now, when needle is "stuck", this requires patience and care in "jiggling" the hand wheel to and fro until needle point begins to clear the jammed area. Carefully snip one thread that moves up under needle and jiggle hand wheel by carefully turning hand wheel toward you to see if you can move the take-up lever all the way up to the UP position. Look at bobbin case area and remove bobbin. Cut bobbin thread and remove bobbin case. Sweep gently with brush underneath case and carefully, gently sweep over the feed dogs, poking very ends of brush bristles into "teeth" area to remove lint, fuzz ball/s, and any loose thread/s. Raise presser foot, remove (possibly bent) needle. Insert new needle of appropriate size for fabric weight. Make sure needle pushed all the way up into needle bar groove, at side to back. Keep presser foot RAISED while rethreading. This allows thread to locate tension discs, and HOLD THREAD TAUT. Replace bobbin, making sure thread is EVENLY distributed on it. Imablanced bobbins cause jams, and bobbins with burrs and scratches can real havoc as well as the hook part of the shuttle where the bobbin fits. Smooth such areas with emery cloth carefully, ever so gently. Hope my suggestions are a solution for you. Jimmy
Apr 06, 2012 | Euro-Pro Shark 60 - 384
The hand wheel won't move. i tried to see if the feed dog was at fault and moved the lever back and forth and now the feed dog is stuck in the down position - and the hand wheel won't move
Open the throat plate and bobbin area to see if thread has tangled there. Snip and remove thread with tweezers - do not yank or **** and tangles out of the machine.
Mar 18, 2010 | Bernina Bernette 75
Sewing Machines Logo
131 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
