Question about ASUS P2T THERMAL SENSOR CABLE (CABII150MX) Motherboard
Does anybody know where to buy Asus thermal sensor cables,? I will buy all over the EU.
How do I get Netflix on TV?
buy the hdmi cable and plug the cable from your laptop to your tv. just buy the cable and it's all done.
Mar 15, 2018 | Electrical Supplies
Error 4
Unfortunately the error message 5 indicates that the thermal block and/or thermal sensor and possibly a control board need to be tested, and likely one or more, possibly all, replaced. My recommendation is to send it to Capresso ask what it will cost first. M
Aug 11, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Maytag dryer is less than 3 years old. Blew thermal fuse. Cleaned all of the venting inside and out. dryer still overheating and blowing the thermal fuse. Replaced the thermal fuse and the high temp sensor...
Have you tried replacing the operating thermastat it's what shuts it off at the right temp and would cause the thermal fuse to go if it is not shuting.off at the right temp. It happens.
Hope this helps.
Dec 05, 2010 | Maytag PYE2300AY Electric Dryer
Video of, How to assemble a Asus desktop.
Why Asus?
It's going to be an Asus motherboard. The rest of the parts will not be Asus.
If you bought a desktop computer that is a barebones unit, the number after the Asus name, is the motherboard Model Number.
Example:
Asus M4A785-M Ultra Barebone Kit.
The motherboard is an Asus M4A785-M
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6046490&CatId=31
Asus didn't make the computer, just the motherboard.
Information you need is how to assemble any desktop computer, and transfer this information to your computer build.
1) http://www.youtube.com/watch?v=LIaNP2eWWuI&feature=related
Also click on the other related videos to the right, under Suggestions.
2) http://www.squidoo.com/how-to-assemble-a-computer
Scroll down to the heading -
Table of Contents - How to Assemble a Computer,
and click on the links in order.
Now, tell me what Model Number of Asus motherboard you have, or what Asus barebones kit.
I'll guide you step by step.
1) Right off the bat!
Suggest you buy, and wear an ESD wrist strap.
(Electro Static Discharge)
Average cost is about $6 to $8.
Connect the alligator clip of the ESD wrist strap, to the metal frame of the open computer case.
You don't want to Static shock any of your computer parts!
A Processor is the most susceptible computer hardware part, to Static shock.
[Static will fry out (Short Circuit) the hardware components of a computer. You may not even see it, or feel it ]
2) Work on a table.
Do Not remove any parts from their protective Anti-Static bags, until you are wearing the ESD wrist strap, and it is connected to the metal frame of the open computer case.
3) IMPERATIVE!
Make SURE you have Thermal Paste.
Thermal paste is put in-between the top of the Processor's case, and the bottom of the Heatsink.
Helps to transfer heat from the Processor to the Heatsink.
There is a Correct method, and an in-correct method of applying thermal paste.
(Thermal paste is also known as thermal grease)
4) Make sure the parts you have are compatible with each other.
If you bought a barebones kit, the parts that come with it are compatible.
If there are parts you still need to buy to complete this computer system, they have to be compatible with the parts that have been already provided.
Post your reply/s in a Comment.
Sep 28, 2010 | Computers & Internet
Black and Decker ODC325 coffee maker thermal fuse temperature
Spoke w/ my husband about this. He says its perfectly normal, they are all like this. The company buys these in bulk and if were supposed to cut off at 100 degrees, and they get a batch of 50 degrees, its less expensive to just use the two. Hope that helps.
Apr 24, 2010 | Black & Decker SpaceMaker ODC325 Coffee...
Data cable from cd drive
okay google these, and tell us what it is: IDE, Sata, or SCSI.
If you don't have the same connection on both the computer and drive, then you need a new drive then that has that connection, my suggestion is to go to best buy and ask them if they have a * to * (the stars are what you need, and what you have) or get a new drive with that * (one you have)
Sep 27, 2009 | ASUS M3A76-CM Motherboard
Need a temp shut down device for a coffee maker Don't know what the part is called. It is marked 240V-10A-214 C. It stops the element from getting to hot (214 Cel.) radio shack used to have them but can't...
I believe you're looking for a thermal fuse or thermal cutoff.
In the EU or UK, try: maplin.co.uk
In the US, try: www.digikey.com or www.action-electronics.com/fustherm.htm
You might also try contacting a manufacturer directly:
http://www.thermtrol.com
Sep 13, 2009 | Betty Crocker Coffee Makers & Espresso...
Computers & Internet Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
