Question about Smeg STX2 Dishwashers
Dishwasher f70 - Smeg STX2 Dishwashers
  • Smeg Master
  • 19,396 Answers
F70 plus not draining completely
check for obstructions in the pump, the hose and the drain.
Sep 25, 2012 | Miele Dishwashers
How to fix leak in miele dish washer g1202 svi has F70 fault and small leak into catch pan
The reason the pump keeps running when F70 fualt appears is that the water leak circuit has tripped which causes the dishwasher controller to empty the dishwasher to avoid flooding of the motor and pump area.
The sources of leaks could be many, to start with hoses and water inlet valve. If you feel you can handle such repairs then go ahead otherwise call a technician.
Make sure the mains power is turned off when you are working with the dishwasher internals.
Aug 10, 2012 | Miele Dishwashers
The panel is flashing a F70 problems what does this mean
Hi, F70 means that the dishwasher senses the motor running even though control board is not telling it too. Here would be the reasons for this 1) There is water in the base pan so it has flooded and is trying to remove any water remaining in the tub. 2) Your control board relay is stuck.
If you want to to check for water in the base, you need to uninstall the unit tip it on it's side and remove the 4 screws on the bottom of the base pan. If you remove the pan and see water you need to determine where it's leaking from. If not you need a new control board.
Jun 28, 2011 | Dishwashers
What does the fault F70 mean for a Miele G 1534 Sci dishwasher, please?
hello,
The code is an indication of a problem on the washer
F67 means the input voltage on the microprocessor is incorrect. Code F70 indicates a problem with the water temperature sensor circuit. F76 means the NTC temperature for the cold water valve is over the limits.
thanks.
Oct 26, 2010 | Dishwashers
Miele dishwasher doesn't work.error F70
When this problem happened to our machine, it was simply the pipes under the sink where the dishwasher drain pipe fits were blocked with muck. This was preventing the one way valve connecting the drain hose to the household waste from fully opening thus preventing the machine complete its drain cycle.
Solution was to thoroughly clean the sink drain pipes - plunger, power plunger and then a dose of chemical cleaner. Dishwasher is as right as rain now:)
Mar 29, 2010 | Dishwashers
Miele dishwasher error message F70
Hello, I hope you remember me, we just had a Live chat session on Fixya, about the Miele DishWasher.
I request you to please Login back to your FixYa account and on the top right corner you will see a 'My Profile' link, go there and find the chat we had.
And kindly leave some feedback after accepting the solution, as that will be useful for FixYa's future reference.
I hope you will spare some time for this. We will feel obliged.
Concerned, WAQAR.
Mar 13, 2010 | Microwave Ovens
F70 fault error keeps appearing on my Miele G1220SC full dishwasher - any idea?
it is the float switch in the base of the unit, which registers a water leak. you are probably using too much detergent and it is overflowing into the base.
Oct 31, 2009 | Zanussi 24 in. DE6850 Free-standing...
Fault code f70, drain pump keeps running, nothing else works
Yes. F70 is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Hope this helps.
May 29, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
Smeg STX2 Dishwashers Logo
118 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Garth Jackson
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
