Model no. OAS-9HR45 Hi. the unit is powered and the fan is working. The compressor fan is also working. The cool air has stopped flowing though. I have lowered the temperature to 19 c but still no luck. Hope you can help
  • 43,501 Answers
Check to see if the compressor is running....if the fan is running the contactor is pulling in... if th compressor is running then the system may have a leak...if not then the capacitor for the compressor may be gone... if that don't work then the compressor may be bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Jan 04, 2011
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
Luxpro psd111 thermostat shows snowflake (sometimes blinks), outdoor fan works, but no cool air comes out inside- no air flow at all. Is it the thermostat or an a/c unit malfunction?
If the outdoor unit is running the indoor fan should definitely be running. Turn power off to indoor unit. Put red green and yellow wires together behind the tstat with a wire nut. That is power (red), indoor fan (green), and compressor (yellow.) Turn power back on. This is bypassing the tstat and you should have indoor fan and outside running as well. If yes the problem is in the tstat, if no indoor fan the problem is in the unit. Good Luck!! Let me know!!
Apr 28, 2017 | Heating & Cooling
Hi my 2010 x5 air conditioner only works when the car is moving?
possible that the fan used to cool the condenser is not working
that would stop the the gas to go to liquid and would create an over pressure situation that would activate the high pressure switch and stop the compressor
as the car moves , the air flow through the condenser does the job of the fan , pressure come down compressor comes back on
best take it to an accredited ac specialist shop for a proper diagnosis
Nov 25, 2016 | Heating & Cooling
Kenmore 596.50692001 side by side stopped cooling. The fan is working, the compressor kicks on for less than a minute then kicks out. No cooling air flows. Water dispenser is working fine, but the water...
You most likely have a fried overload, it is the small white square shaped piece on the compressor, to tell if it is bad, remove it and smell it for electric burning smell, or if you shake it and it sounds like sand shaking around it is definately bad. costs around $25 to replace. You can purchas this at http://www.reliableparts.com/ using your model number.
Dec 01, 2010 | Kenmore Refrigerators
Freezer works Refrigerator will not cool down
The compressor should be OK this time because you caught it in time. But if the condenser fan stops you need to consider replacing the fan. I have had refrigerators do fine until the fan motor warms up and you are away, it stops. Don't think you should use the refrigerator until the fan is fixed. Sea Breeze
Apr 22, 2009 | Kenmore Refrigerators
Hi cool or high fan still not working the back unit is the same unit.
it looks like a control problem with the thermostat or relay board (if you have a wall mounted thermostat). If the compressor is coming on, then you need to look into the airflow of the unit. Whether or not the compressor is coming on, you need to check the voltage. Like every appliance on board, the air conditioner needs adequate power to operate. If the voltage is 110 volts a.c. or below, the effectiveness of the unit will start to suffer. After verifying correct voltage, we need to look at how the air conditioner does it's job- it requires adequate air flow over both the inside (evaporator) and outside (condenser) coils. If the air filter is clogged refrigerant will not be able to pick up enough heat from the inside air, and if the condenser coils are blocked by leaves, it will not be able to give off enough heat to the outside air.
Jun 25, 2008 | Dometic Rooftop RV Air Conditioner
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Hums and freezes up????
The fan motor must have been stopping. If the fan stops, for sure the fins will freeze because there is no air flowing. common Fan motor problems defective bearing or bushing and starting condenser. If the bearing is defective, it will heat up and seize. Have the fan motor checked. The fact that the fins are freezing, means that there is enough freon and the compressor is working.
May 29, 2007 | Frigidaire FAS155K1 Air Conditioner
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
