Question about Iomega 250GB Ego Portable HD Red 250 GB Hard Drive
My Iomega HD is beeping and the computer doesn't recognize it anymore. What can I do?
SOURCE: Iomega lphd160-u beeping
The same thing happens with my moms iomega. Wish I knew the answer!
Posted on Jul 03, 2008
jfktech511
  • 13 Answers
SOURCE: it does`t show on my computer and make sounds
All might not be lost. There are services that will attempt to recover files from decaying hard drives. There is also software you can download to attempt it yourself.
Here is a review of one such service at PCMAG:
http://www.pcmag.com/article2/0,2817,1911133,00.asp
Posted on May 01, 2009
  • 164 Answers
SOURCE: computer doesn' t recognize iomega eGo portable
a windows update may have run and killed the drivers...try rolling the system back to before the problem started, then if updates run again..and set them to download but dont install..install them yourself..run updates and see if the problem re-appears.
Posted on Jul 24, 2009
  • 2509 Answers
SOURCE: My iomega makes a beep
I am afraid that the drive has been physically damaged by dropping it, but the only way to be sure is to remove the drive from the housing and connect it directly to a computer with the correct adapter or cable. This will eliminate whether it is the drive or the electronics.
It is possible but not very likely that a connection has become loose (which you can check when its open) or the electronics has failed but sadly it is most likely to be a damaged disk drive.
There are data retrieval companies that could possibly retrieve some of your data but it is VERY expensive.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
Posted on Feb 21, 2011
  • 51 Answers
SOURCE: Hi, My FreeAgent Go portable hard
This is a mechanical failure of the drive. You will need to get a new one. Recovering the files off of this can be very expensive.
Posted on Sep 13, 2011
Iomega screenplay dx
It may depend on what type of file system you chose when formatting it. For file-type support beyong 1.5 Gb, such as high-resolution videos, aka. HD movies, Iomega should be able to recognize NTFS file system. Perhaps you chose FAT, or FAT32? In that case Iomega may not recognize it.
Jan 21, 2013 | Iomega 35039 1 TB ScreenPlay DX HD Media...
Beeping noise when connected to tv
Beeping often indicates a power problem. Try a different usb cable.
Sep 04, 2012 | Iomega 500GB Prestige USB 2.0 Portable...
My pc doesn't recognize my iomega external drive. when i turn the drive on it beeps.
Does it work on any other computer?
Beeping normally means a post code error
Nov 28, 2010 | Iomega 1.5TB Desktop USB Hard Drive
Disk spins ...then I hear a beep...icon does not show up
The hard disk or the adapter case maybe faulty.
To test the hard disk, remove it form the Iomega case and connect it to an USB hard disk adapter and plug it into a computer's USB port.
If this computer see it as an external hard drive and you can open the folders and files then the hard disk is OK, then the Iomega adapter case is faulty.
Then you need a new hard drive adapter case, it doesn't need to be an Iomega brand.
Nov 26, 2009 | Iomega (33654) Limited Edition 500 GB USB...
My iomega 500gb external hd isn't being recognized. There's an icon for safely removing hardware but under the 'my computer' tab there's no icon for the drive, as though its not even there. It had been...
Did you have to install a driver for it initially? Try reinstalling the driver, if so.
I thought most drives were plug and play. If it does not have a driver, trying using a different USB port. Sometimes the ports can freak out and not recognize the item plugged in, especially if you use multiple items in the same port. (ie, cameras, cell phones, printers, etc)
Hope this helps at least some. Good luck!
Jul 31, 2009 | Iomega 500GB Ultramax HD USB 2.0/FW 500 GB...
Computer doesn' t recognize iomega eGo portable
Jul 24, 2009 | Computers & Internet
Hard drive not recognized
is damaged my friend. Hard drives are very, very delicate pieces of equipment. The disk is paper thin and any sudden jarring, especially dropping it creates a warp in the drive. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Jul 12, 2009 | Iomega 500GB Ultramax HD USB 2.0/FW 500 GB...
Your USB port does not have enough power to support the drive. You will need to use an external power source of try a firewire cable if the drive has that option.
Travis Cable
Mar 29, 2008 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Open Questions:
Iomega 250GB Ego Portable HD Red 250 GB Hard Drive Logo
288 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
