Whirlpool washing machin 11580 dry linin wm 123650h i want to know price of this machine I want to purchase this model
jsrock516
  • 5911 Answers
SOURCE: Error code F09/Whirlpool Duet front loading washer
"F09" is an Overflow Condition error. This is usually attributed to a malfunctioning pressure switch, loose or broken connector between the Pressure Switch, Drain Pump and Central Control Unit (CCU), or...a drain pump or drain line that has become clogged.
Since this problem occurs periodically during the wash cycle, I would check your drain pump filter for obstructions first. It could be that you have debris lodged in the pump causing it not to drain properly. To access the pump:
1. Unplug the washer.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge. HINT: Placing a couple of blocks of wood under the front feet of the washer will make access much easier.
3. The drain pump is located under the wash tub in the center. HINT: If you own a shop vac, remove the drain line from the standpipe at the wall and pull a vacuum through the drain line. This will remove all residual water from the washer and make clean up later a lot less messy. Now, remove the cover on the drain pump and remove. Clean out the pump filter and check the pump impeller for obstructions.
If you do not own a shop vac, place a bunch of towels around the drain pump BEFORE you open it. There's about a gallon or so of water in the tub, drain line and pump.
Try this first, and let me know if this corrects your problem. If not, you may need to check the pressure switch and wiring. I hope this helps you.
Posted on Apr 14, 2008
  • 250 Answers
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
Posted on Sep 20, 2009
SOURCE: need to find a manual for Onix WM 3011 washing
IF IT'S THE SAME AS THE ALDI WM3011, i have the booklet. what did you want to know?
Posted on Sep 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: whirlpool washing machine model wfw9500tw01
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
  • 6277 Answers
SOURCE: i need a user manual for bush washing machine
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Apr 30, 2011
Testimonial: "Thank you"
Is there a washing machine that can be purchased for the home that can handle heavy bedding such as quilts and comforters?
Samsung has a new set out that has a capacity so large, it's too big for just a 2 person household. And at that, king sized bedding is large and heavy I don't know how the set would stand up to it so I take large bedding to a Laundromat and use the hi Cap front loaders they have.
Good Luck with the search,
Cheers
Kelly
San Diego, CA
Jan 18, 2015 | Whirlpool Washing Machines
Washing machine top load leaking water bottom model # LXR7244JQ1
The pump is near the front, bottom of the machine. You need to unplug and unhook it from the water supply. Then get a wet and dry vacuum and remove all the water from the machine by using the vacuum on the drain hose. Then you can lay the machine down to get to the bottom of it and you can replace the pump. http://www.partselect.com/ModelSections.aspx?ModelID=709279&ModelNum=LXR7244JQ1&mfgModelNum=&ManufactureID=3&Selected=TVCOCCCE&Position=6&mfg=Whirlpool&Type=Washer&Mark=4
Jul 10, 2014 | LG WM-2277HW Front Load Washer
Model no is wft7700 lg washing machine, but i want the serial no, i have reg no is wm-2011/008453
I am sorry this is not possible , you need to contact the dealership at your location, check the purchase bill or call for the LG support.
Mar 23, 2013 | Washing Machines
Machine won't spin dry
The timer is th emost common problem. You can purchase a replacement timer and install it
Apr 14, 2009 | Home
I have whirlpool AWM 243-500 washing machine, but it does not dry the clothes, I get my clothes with a lot of soap and water. Please help me. Can I get it manual, as I have any manual to know how to use it...
Hi mate what i think you should do is claen out the filter compartment at the front as it sounds that it is not rinsing properly.
Let me know how you get on.....
Feb 26, 2009 | Whirlpool AWM5125/1 Front Load Washer
Need a part number
The part number is W10160252. You can order the part at sears.com . The price is 131.10
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
WHIRLPOOL DUET HT FRONT LOADING WASHER
This is a strange problem. I work on these all day, and never have a problem getting these boards. Might want to try and calling local part houses for this part.
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Replacement Cost Information For Damaged Washer & Dryer
if they were kenmore then more than likely they were built by whirlpool look at whirlpool for copariable models by going to lowes .com you can find same looking models but with the whirlpool name
Jan 20, 2008 | Washing Machines
How on earth do u find auto dry?
I don't know if this helps, but the washing machines I have used will only go straight from wash to dry if the wash is set to 'half load'.
Sep 02, 2007 | Whirlpool AWZ410 Front Load Washer/Dryer
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
