Question about Gaggenau EB388 Electric Single Oven
I lifted it by its door and its came off, not broke though
My partner thought he was he-man and tried lifting our oven that was being moved at the time by its door, you guessed it, the door has now come off as he would not be patient and weight for his friend to help carry it.
please help, it is not broke but we cannot figure out how it goes back on.
or who wqould we contact and how much would this cost as i want to sell it now on ebay as i have a new one ordered.
kind regards
Carley
    Scholar:
  • 148 Answers
Ok wht you have to do is grab the hinge with pliers or your hand and fold the hinge to the open position,carefull this hinge has some pressure to it and you dont want to pinch your skin ,once the hinge is open,you want to take a screw or strong nail and stick it thru the hole that is between the top of the hinge and bottom in the center put the nail thru the hole and let the hinge close slow i,it will hold the hinge 3/4 open,now hook the door on it will be 3/4 open once you feel it latch on the door open the door all the way pull the nails out and close the door ,it takes a little practice but youll get it remember to use the nail to hold the hinge open,youll see the hole on the hinge
Posted on Jul 09, 2008
  • derek martin Jul 09, 2008
    I work at an apartment complex and when my cleaner cleans my ovens he does this to me all the time as he tries to move the oven to clean behind
Oven locked E1 F5 oven locked, how to unlock whirpool oven
try unplugging it and when you plug it back in hopefully it will open.the latch assy. is stuck,i don't know what model you have,if you look above the door through the grill slots can you see the latch assy. if so unplug the stove or flip the breaker with a screw driver see if you can move the latch or if you have a long skinny screw driver or anything that you can push on the latch with see if you can lift up on the latch to see if it will free up and when you plug it back in it will unlock,if you try to free the latch in the door and are not sticking anything through the slots you can leave the power on,you can try lifting up on the door or wiggle the door,all you're trying to do is get that latch to free up so it will move and don't self clean it again if you get it open,self cleaning can cause damage to the electronics on an oven and i would never use it.good luck
Nov 08, 2017 | Ovens
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
How do I replace the handle on a neff oven?
1. Fully open the oven door.
2. Move the catch levers on the right and left-hand sides to the fully open position.
3. Placing the door at an upward angle toward you, grasp the door with both hands and lift it out of the hinges toward you.
4. undo the screws in each Connor & lift out the glass.
5. do the same with the handle screws, then put new handle on.
6.repeat above steps backwards.
Aug 30, 2014 | Neff Ovens
How do you remove the door from a frigidaire gallery series double wall oven(self cleaning)?
Open the door and look at the hinges the connect the oven door to the oven body, on each side you will notice a piece that can be moved back and forth without moving the door, roll each side toward the oven body this should be the locked position, now try to close the door and you will notice the hinges lift up. At this time you need to pull up and push forward on the door and both hinges will come out.
Apr 24, 2012 | Frigidaire 30 in. Electric Gallery Series...
Hi the right hand hinge of the door has popped out whilst I was trying to move the oven using the door handle as leverage. The door is now wonky when closed as the hinged has popped out. Help!
All oven door typically lift off the hinges by design. If you open the door to what is referred as the broil position. You know when the door stops about 4 to 6 inches open at the top. Then do the following.
1. Lift the door up completely off the opposite hinge still in place and remove. Set the door aside carefully as if has glass window, you do not want to break.
2. Then set both hinges at the broiler stop position. If one is all the way in to door fully closed position pull it out with your hand or with pliers till it stops @ broiler position. If all the way down as if door was fully open, lift hinge until it stops at broiler position. CAUTION- THE HINGES ARE SPRING LOADED AND CAN SNAP BACK INTO FULLY CLOSED POSITION. You can use a heavy glove or if you have an oven mitten, that can work to protect your fingers. DO NOT GET YOUR FINGERS BETWEEN HINGE AND OVEN OR CAN PINCH FINGERS.
3. Now carefully lift the door over the hinges set at the broiler position. Careful not to bump them when doing so or can snap closed. If does, reset hinge to broiler position and repeat. Works best to hold door at angle that door is when in broiler position. Once you have them started evenly, you should be able to fully slide down back onto both hinges.
4. If one of the hinges no longer has spring tension you have to reattach the spring. You can usually access spring if needed by removing the bottom drawer.
Aug 27, 2011 | Ovens
I have a Frigidaire Gallery Oven Professional Series, I don't have the model number. In trying to self clean my oven, I accidentally pressed something that engaged the oven door lock. Now I can't close...
If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up.
If the hinges have become worn, damaged, or bent, you probably need to replace them. I recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Sep 04, 2009 | Ovens
Cant get the oven door to shut all the way??
Try opening the the door a few inches and lift it straight up. Then push it straight down. It should slide on the hinges up and down. You need to seat the door properly on the hinges. Don't be afraid to man handle it but, be careful the oven may tip if it's free standing. Good luck. Please rate me so I know if I helped. Thanks.
Dec 30, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Gaggenau EB388
I can fix it but Im in nyc.1-888-692-1055
Jul 09, 2008 | Gaggenau EB 270/271 Electric Single Oven
KITCHEN AID KEBC107KSS03 DOOR. REMOVE INNER PANEL. CLEAN GLASS
LOOK WHERE THE HINGE METS THE OVEN DOOR FACING..you will see on the hinge a tab with the door open pull these forward this will lock the hinges do this on both sides then closed the door slightly and lift up the door will come off then you can unscrew the bottom scres to access glass
Feb 22, 2008 | KitchenAid Architect Series KEBC107KSS...
Hotpoint range door doesn't unlock after the clean cycle.
It is possible that the lever has been bent somehow. If you can lift the top of the oven as if you were cleaning it. look at the lever mechanism, move it to the other position and push it back carefully, to bend it back. I have seen this happen a lot, people lean on the oven, the lever is in the open position and it is pushed a little bending it so when it is moved to close it doesn't go far enough to release it. I am assuming you have waited for the oven to cool down before you tried this first right?
Dec 06, 2007 | Hotpoint SY21 Style Line Gas Single Oven
Gaggenau EB388 Electric Single Oven Logo
241 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
