Question about Samsung CXJ1952 19 in. Combo
The samsung 21 inch Colour TV video is showing the lock signal on the left side of the TV , how to open it
    Top Expert:
  • Samsung Master
  • 74,383 Answers
Hello
To unlock Samsung TV, do the following procedures. It will unlock the V-Chip settings, and you have to reset it after.
1. Turn the power off.
2. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
3. You should now see the service menu. To exit the Service Menu always select RESET.
OK
Posted on Jan 04, 2011
55 inch Samsung smart tv. Has two purple spots showing on the screen. One on left side and other on right bottom.
If you wish to get more details visit the site linked here. Faults and possible causes of both LCD and plasma TV screens are given with illustrations. http://electronicshelponline.blogspot.com/
Feb 22, 2017 | Samsung Televison & Video
Why cant i change the tint of my picture? the menue keeps skipping the tint option
If you're watching UK TV broadcasts then we don't have a need for tint. Similarly, with HDMI sources you shouldn't need tint either because the TV's colour decoder isn't active.
Tint is a throw-back to the American analogue TV system called NTSC. Their system doesn't lock the colour phase to the sync signal. So depending how far the TV was from the transmitter the colour would be further and further out of whack. Hence the industry joke that NTSC stood for Never Twice (the) Same Colour ...N - T - S - C. The Tint control was used to re-time the colour signal. The UK didn't have this issue because our TV system (PAL - Phase Alternate Line) includes information to lock the colour signal phase.
Strictly speaking, Tint is only required with NTSC analogue composite signals. This is where the brightness information is mixed with colour on a sub-carrier frequency. So, that would be signals via an aerial lead or from the yellow video connection which is how most of us first see a composite signal. These signals are encoded as NTSC. Any signals where the colour and brightness (luma) information is kept separate shouldn't need Tint. So, S-video, Component and RGB at 60Hz all bypass a TVs NTSC decoder. If the TV is correctly designed then the Tint option should not be available. Some TV manufacturers break the convention though, for the simple reason that many old school US consumers grew up adjusting Tint, so it's too much of a culture shock to take away that feature.
To recap then, if Tint isn't available then it's because the signal doesn't need that adjustment. The colour timing is already bang on accurate.
Sep 16, 2014 | Televison & Video
21 inches colore tv samsung
Simple fix.Check the spelling and the colour should be good.
Aug 14, 2014 | Samsung Televison & Video
I need a honda car code , i can't turn on my radio
service manual.
Code Description Possible Cause
0 ECU / ECU signal No signal to ECU
1 Oxygen sensor circuit Oxygen sensor or circuit, ECU
2 Oxygen sensor circuit Oxygen sensor or circuit, ECU
3 MAP sensor circuit Map sensor circuit
4 CKP sensor / engine speed (RPM) Crank angle sensor or circuit, ECU
sensor
5 MAP sensor circuit MAP sensor or circuit, mechanical
problem
6 ECT sensor circuit ECT sensor or circuit, automatic
transaxle control unit
7 TPS / Angle Sensor TPS sensor or circuit, automatic
8 CKP sensor / engine speed (RPM) Crank angle sensor or circuit, ECU
sensor
9 CMP sensor CMP sensor or circuit
10 IAT sensor IAT sensor or circuit
11 Idle Mixture Adjuster Sensor Idle mixture adjuster sensor or
circuit
12 EGR system fault No EGR action, faulty EGR valve
13 BARO sensor circuit BARO sensor or circuit
14 Idle Air Control valve circuit / ECU Open or shorted out ignition signal
circuit / No signal to ECU
15 Ignition Output signal Open or shorted ignition output
signal circuit
16 Fuel Injector Circuit Open or shorted fuel injector
circuit
17 VSS circuit VSS sensor or circuit
18 Ignition Timing Adjuster Open or shorted signal circuit
19 A/T Lock-up control solenoid Open or shorted signal circuit,
Lock-up control solenoid lock-up solenoid
20 Electrical Load Detector / Sensor Electrical load detector or circuit
Honda/Acura
Fault Code Definitions (21 - 59)
Chapter 3 22
21 Spool Solenoid Valve Open or shorted signal circuit,
spool solenoid valve
22 Valve Timing Electronic Oil Open or shorted signal circuit,
pressure switch valve timing oil pressure switch
23 Knock sensor circuit Knock sensor or circuit
30 AT / ECU communication signal A AT control unit, ECU
31 AT / ECU communication signal B AT control unit, ECU
35 Traction control / ECU / signal Traction control module, ECU
36 Traction control / ECU / signal Traction control module, ECU
41 Oxygen sensor heater - left side Oxygen sensor / heater or circuit
42 Oxygen sensor heater - right side Oxygen sensor / heater or circuit
43 Fuel Supply system - left side Oxygen sensor or circuit, fuel
system
44 Fuel Supply system - right side Oxygen sensor or circuit, fuel
system
45 Fuel metering - left side Injector control circuit, incorrect
fuel metering
46 Fuel metering - right side Injector control circuit, incorrect
fuel metering
48 Heated oxygen sensor Oxygen sensor or circuit
53 Right Knock Sensor Right knock sensor or circuit
54 CKP sensor 2 CKP sensor 2 or circuit
59 CMP sensor 2 CMP sensor 2 or circuit
Dec 28, 2010 | 1994 Honda Accord
ShubhangiWe try to connect CD player with Samsung LCD TV. CD Player is having Three Component Yellow, Red,White. It dont have Blue and green components.What to do ???
Hi, Component input connectors use the colour convention
Green = Y (luminance signal)
Red = Pr or Cr (Red colour difference signal)
Blue = Pb or Cb (Blue colour diffrence signal)
Composite input connectors use the colour convention
Yellow = CVBS (composite video, blanking, sync)
Red = Audio Right
White = Audio Left
for compatibility both units will need to have matching colours. note the component inputs do not have audio and as such will also have a set of red & white connectors for use with the audio signals too ( rule of thumb Component = 5 connectors, composite=3 connectors)
Sep 23, 2010 | Samsung Televison & Video
Red colour on screen
if crt pic tube magnitized need to degausse with coil
Jun 01, 2010 | Thomson 21DC320 21" TV
Red colour appearing on screen
Your tv could have one of several faults. None of which are to be tackled by anyone except a qualified engineer due to the electric shock hazard.the first problem could be the crt (tube) the second could be the componets on crt base circuit board ie resistors or ic.
With a tv 9 years old it may not be economical to carry out a reair.
Samsung CXJ1952 19 in. Combo Logo
186 people viewed this question
Henry  Thomas
Henry Thomas
