Question about JVC Audio Players & Recorders
Hello, we have a jvc audio cd JVC-MX-G7 shelf system . and we find that the audio signal between amplifier and speaker is not going. can you help solve this problem ?
  • 9 Answers
SOURCE: JVC MX-J900 CD-RW
just connect the hifi to the player of your cd rw disc and put the speaker output.check it out.
Posted on Feb 19, 2008
SOURCE: how do i unlock my
the model # that on the back is jvc ca hxd7
Posted on Jul 08, 2008
SOURCE: JVC Stereo won't open cd tray
take off the cover and get whatevers jamming it out mine did the same thing
Posted on Jul 30, 2008
VOTIT
  • 2071 Answers
SOURCE: CD Player Problems
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 17, 2008
  • 4234 Answers
SOURCE: protect problem
I'm not really familiar with your specific model, so I don't know what the output stage looks like. I'd guess that this unit has a large black 'amp-pac" for the amplifier section. This should be attached to a heat sink in the rear of the unit. Look to see what the markings are on that part. I expect to see STKxxx. Can you post that here?
Thanks,
Dan
Posted on Sep 08, 2008
Connect JVC MX-GT88 speakers to a differant reciever
If it has a bi-amp, you can connect the speakers to it. By the amplifier, if it's a stereo with bi-amp, be sure that it has at least 400 watts and up in order for the speakers to turn out great, if a receiver like a integrated amplifier, it may have like 2-10 connections, you can connect the speakers all together if it has more than 3 connections, if below 3, you may need to take the speakers apart and make it 3 way by connecting one wire to the tweeter, another wire from the tweeter to the main or mid speaker then one more wire from the main or mid speaker to the sub.
Feb 03, 2014 | JVC MX-GT88 CD Shelf System
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
JVC TH-V70 Shuts Down
Hello
Even after disconnecting the speakers, the systems shut down, means that there is something short inside the set. Normally, the output amplifier section circuits will have the short. The set need service, and may have to replace the audio output IC of audio secion. Contact the nearest JVC authorised service center at your town. OK.
Jan 24, 2012 | JVC MX-GC5 CD Shelf System
I have a JVC MX-GT80 there is a problem with it, it turns on just fine but does not give sound, plays cds and everything the only problem is no sound when this happened there was sound then i heard a pop...
It looks like you've either blown the speakers of the amplifier itself. What were you doing when you got the pop and the sound stopped? (Playing CD or from External Source and at what volume level?)
If there is no sound at all from the speakers, not even a crackle or buzz then it's more than likely you've blown the amplifier.
You could narrow the fault by trying these speakers on another unit or another set of speakers on this unit.
If you require further assistance then please ask.
May 10, 2011 | JVC MX-GT80 Shelf System
No power not even light but power is going to transformer also touch the metal cover with a phase tester and it lights up (only just though)..jvc mx-j30
hello you may have ac power but no dc power take the cover off and have a look for any swollen capacitors or components that might be burn't
regards
shaun
Feb 10, 2010 | JVC MX-J30 CD Shelf System
No sound coming from JVC FS-SD7
You burn out the audio amplifier IC you need to replace him
Mar 28, 2009 | JVC FS-SD7 CD Shelf System
Displays "Protect" on screen
the audio amplifier output are fried
Dec 03, 2008 | JVC MX-KB30 CD Shelf System
Protect problem
Thanks,
Dan
Sep 08, 2008 | JVC MX-GC5 CD Shelf System
Maybe something's jamming it, try fixing the drive, so it comes out.
Mar 16, 2008 | JVC MX-KB30 CD Shelf System
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
