E-4. Short of gas. Gas leak. Open top cover of outdoor and check for oil tracing. If not, call repairman to find leak and rectify. Then do gas charging.
May 14, 2019 - I read somewhere that it may be caused by some fuse behind the display (soldered on) and/or faulty motor. I am planning to disassemble my ...
YOU did NOT SPECIFY your MODEL NUMBER but tonight ~ Christmas Eve ~ YOU got LUCKY! I found this and it may help you... but
THIS INFORMATION MAY NOT BE FOR YOUR DEVICE!
"LCD shows "Er 4" Pneumatic system leak or cuff is too loose during inflation
And this:
LCD shows "Er 0"
Pressure system is instable before measurement
Be still and measure again
LCD shows "Er 1"
Systolic pressure detect fail
LCD shows Er2 Diastolic pressure detect fail
LCD shows "Er 3"
Pneumatic system is
blocked or cuff is too
tight during inflation
Place the cuff correctly
and try again
LCD shows "Er 4"
or cuff is too loose du-
ring inflation
LCD shows "Er 5"
Inflation
above
300mmHg
Measure again after 5
minutes. If the moni-
tor is still abnormal,
please contact the
local distributor / ma-
nufacturer.
LCD shows "Er 6"
Over 3 minutes while
pressure above 15
mmHg
Hi ,our company is Wuxing baisi office consumable co.,ltd . we can offer Max ribbons . like Max ER-1100 ER-1500 ; Max ER-2200 ER-2500 ER-3100 ER2200 ER2500 ER3100 /Max ER-IR102E. Please contact me at [email protected]
We can do B2C, B2B business.
LG refrigerator "Er IF" error code is the "Icemaker Fan Error" message.T his error code indicates a problem with the fan
that controls the unit's ice production. If this problem occurs because
of ice buildup, unplugging the unit for 3 to 4 hours and allowing it to
thaw may fix the issue. Call customer service if that doesn't work.
Hi. You may have a bad battery. This can cause lock ups. If it hasn't been replaced in the last 3 to 4 years, take it to a dealer to have the internal battery replaced. The battery will eventually leak all over the inside of the machine and damage it beyond repair.
I've had many requests for the Sharp ER-A470 manual. Here is a link
http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
CD Changer Error Codes:
If problems arise during CD changer operation, the following error codes may appear in the display: ER-1: No magazine loaded. ER-2: Problem in the disc loading function. ER-3: Error in the disc loading function. ER-4: Error in the disc unloading function. ER-5: Error in the magazine position. ER-6: Error in the laser pickup position. ER-7: Error in the laser focus on the disc.
dear nchase
This problem generally occurs due to the following reasons. I've included the solution too.
1.Windows and air vent wings maybe open .Close windows and vent wings 2.The compressor belt is slipping. Try to Tighten or replace compressor belt 3.Heater is on. Shut heater off 4..Condenser is clogged with debris. Clean the condenser . 5.Refrigerant has escaped through a leak in the system. Have system checked . 6.Receiver/drier is plugged. Have system serviced.
Try these solutions. Do respond with your comments please.
With regrads
Ajuz.
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to
"#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER
RESET." Power the unit off/on.
