Question about Dishwashers
Baumatic bdw17 dishwasher door seal keeps being dislodged
5 Suggested Answers
SOURCE: Baumatic dishwasher won't start
Had this problem with the Baumatic 13. Perhaps the door is not closing properly. Make sure you push the door hard in the top centre. It should beep once and then start after a few secoonds.
Terry
Posted on Dec 28, 2007
  • 148 Answers
SOURCE: dishwasher seal issue
I use ge silicone clear sealant it is flexible adhesie that can handle water and heat
You can get this at Ace or big box stores you do not need a big tube
FIX:
1 Open dishwasher door
2 gently pull rubber seal away from dishwasher guide You do not have to remove the entire seal unless it is loose just keep pulling until you feel the seal staying on dishwasher
3 put a small amount of clear sealant on loose seal(side facing housing) and small amount on dishwasher guide ( dip your finger into water so that it does not stick to your finger)
4 press the seal into place on dishwasher housing
5 wipe excess with a damp cloth be sure you do not get any on seal side that faces dishwasher door
6 Allow to dry over night
Good Luck
Posted on Jan 02, 2009
SOURCE: error 3 on dishwasher
E3 on BDW45.1 is a failure to reach correct temperature (or the diswasher is unable to dectect the water has reached the correct temperature). You may find the items are not being dried fully.
Posted on Sep 15, 2009
arikrom
  • 528 Answers
SOURCE: My Baumatic bdw9 dishwasher's door is leaking from
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Posted on Jan 01, 2010
Broken door spring
This should not be hard to replace. It would have helped if you had provided the model number of the dishwasher.
You need to buy a replacement spring (best to get the pair) which looks like this item.
BAUMATIC DISHWASHER TG5 DOOR SPRING for BDS461SS
To replace you need to locate the second spring on the other side of the dishwasher and remove it. The front base plate needs to be removed first to get access to the spring anchor points. Use a screw driver or a nose plier to grab it and dislodge. Always make sure the door is shut to ensure least tension in the springs. Put the two new springs and close the base plate. MAINS POWER CHORD SHOULD BE TAKEN OUT FROM SOCKET WHEN WORKING ON THE DISHWASHER
Aug 07, 2014 | Baumatic Dishwashers
Baumatic bdw10 door catch
Have you tried at PartMasters. Looks like around 30 pounds.
Sep 22, 2012 | Baumatic 23 in. BDW10 Built-in Dishwasher
Door will not shut.No error code.Door keeps springing open!
Hi there
If this door was mine I would get the dishwasher -doctor to come and fix the door. On the other hand if you have a good friend who likes repairing things he might talk to your machine.
kolbrun
Feb 25, 2012 | Baumatic 18 in. BDW45.1 Built-in...
My Baumatic bdw9 dishwasher's door is leaking from the bottom, I dont know if it is over filling or the door seals have gone, any help would be appreciated
Dec 26, 2009 | Baumatic 23 in. BDW9 Built-in Dishwasher
Trips circuit breaker when door is closed
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Dec 15, 2009 | Baumatic 23 in. BDW5 Built-in Dishwasher
Error 3 on dishwasher
Feb 21, 2009 | Baumatic 18 in. BDW45.1 Built-in...
Baumatic bdw13
the top tray has a nozzle on rear,which pushes into a screw on rubber seal on inside rear of appliance.this splits and stops water being fed to sprayer on top tray.phone baumatic parts dept,only a few pence,but sent mine free!
Jan 09, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Terry
Nov 22, 2007 | Dishwashers
Rubber door seal problems
Try gorilla glue ,it needs to be wet with water to be its strongest.Please rate this .Thanx!
Apr 25, 2007 | Indesit 24 in. D63 Free-standing...
Dishwashers Logo
59 people viewed this question
Top Dishwashers Experts
Owen Barnes
