Back to:
Tags:
Fuji FinePix A345 Digital Camera
Green light flashes then nothing happens (by 2 users)
posted by lorileinb on Jul 09, 2008
When I press the on button the green light flashes but the lens does not extend, it does not beep, the display does not come on...nothing. It was working fine until the last battery change then it started doing this. I've tried several new sets of batteries but no change. Any ideas?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by nrio, posted on Jul 14, 2008
I have a similar problem. The camera will only work if I hold down the power button continuously which obviously is not a viable solution. Any ideas anyone??
Can you Help with these Digital Cameras problems?
on power up the display is blurred and if a photo is taken...
The screen is will go white after taking a couple...
The image is blurred and will not focus.
Respected Sir, I lost the cd which helps you to display...
when i turn on my camera it is stuck on the...
Loading problems.
Repair Service
Find Digital Camera Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
