Hi there, The picture for my plasma does not turn on. Whenever I turn it on, the red light flashes and no picture comes on. Does it mean the tube needs replacing? If so, how much will this costs me to repair?
  • 4,889 Answers
Hello. This is eagle338. I was in a live session with you earlier and it seems like you had a disconnect. Please click on the re-connect with eagle338 button to re-connect. We can also solve the problem through this forum, so please tell me how many times it blinks in between each pause.
Sai.
Posted on Jan 04, 2011
My 2009 panasonic hd plasma tv, model TH-46PZ800A will not turn on, the red light just flashes
2009, get a new LED, they're more solid, and have a better picture. Plasma has a short tube life.
Feb 12, 2014 | Televison & Video
No picture and blinking red light on Panasonic Viera Plasma TV model P50XT70A
Your Viera is showing symptoms of internal power supply failure
Mar 19, 2013 | Televison & Video
Sony Trinitron KV-ES34M90 turns on OK but goes off after about 5 mins. Timer is off. The screen goes orange before it turns off and the red light flashes x2 at intervals. Could you please help me with...
The two blink code means the set is turning off because of over-current protection. This, along with your saying that the screen turns orange before the set shuts off, leads me to think your picture tube is bad. What's probably happening is that as the tube heats up (there's a filament like that in a light bulb in the neck of a conventional picture tube) one of the metal elements moves and touches something it shouldn't. This then lets high voltage from the tube get to places it shouldn't and the protection circuit kicks in.
There's no fix for this other than to replace the picture tube. It would be far less expensive to buy a new LCD or plasma TV than to buy a replacement Sony tube. And the replacement tube then needs convergence to get the red, green and blue color beams properly aligned and adjustments to get them balanced. Work done in the field seldom looks as good as the factory job, and it can be disappointing. The LCD or plasma sets don't have these issues.
Now might be a good time to start checking sale prices.
Jun 22, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When i turn my samsung 50, no pic or sound 3 lcd lights keep flas
Hi friend,,,
welcome to fixya
Commonly for plasma tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
The toshiba 46h83 46in rear projection tv comes
the red flash you are talking about im assuming is the screen going red
that usualy means a red picture tube they break down
one way to tell turn the red screen control counter clockwise and see if you can control the tube gain
and then you can lightly tap on crt neck and i do mean carfuly and see if it flashes it most likely will and you would need to change the crt and reset it up
Nov 02, 2009 | Toshiba 46H83 46" Rear Projection...
Plasma TV Does Not Turn On - continous Red Flashing Light
Had a similar problem with my Sony. Unplug for 36 hours and try again.
Aug 29, 2009 | Philips 50PFP5332D 50 in. Plasma...
TV won't come on - get a blinking red light instead
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you the flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jul 01, 2009 | Philips 50PFP5332D 50 in. Plasma...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
42" Panasonic plasma has no picture, but power light is flashing
I think accroding to your model number this unit is plasma.
I need to know red light how many times flashing and correct model number
Sep 18, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
