Question about Volvo S80 06 2006
LOOKING FOR A POWER SUPPLY OF CAR RADIO HU-831 IN A VOLVO S80.
  • 3 Answers
SOURCE: Car won't start
I had an OLDs with the same problem... it was the starter, I got one and its still a city car two years later...... ck it out... good luck................
Posted on Jun 04, 2009
  • 85 Answers
SOURCE: 99 Volvo S80 water pump replacement
if this helps.. I had the 1998 model S70. the water pump was driven by the timing belt. you had to take the timing belt off just to replace the water pump. it was just a simple bolt on replacement. the only difficult issue is resetting the hydraulic tensioner on the timing belt. the hydraulic tensioner has to be completely taken off and compressed VERY SLOWLY in a vise. then insert a very hard drill bit or (special volvo tool) into a keeper hole, reinstall hydraulic tensioner onto car and reinstall timing belt.very quickly remove drill bit from keeper hole in tensioner and the tensioner snaps back out to put tension on belt. and you are done.
Posted on Jun 24, 2009
SOURCE: I have a S80 Volvo 2000 model. I lost my spare key.
Pay the dealer the $300.00. I have been told it's worth it to have an extra set due to the computer communication of the keys with the ignition (not sure how it works exactly.) To re-key or get a new ignition costs like 1600-1800 dollars and takes approximately 10 days to even get the parts. I checked with a Volvo dealership in WA State. I am having problems with my ignition now and the keys won't come out or turn the last little click to be able to pull them out (but not all the time), also my car will turn on no problem (only have trouble getting keys out) my car just won'y go into gear, it seems it happens more frequently when it is below 55 degrees, even after the car temp guage has reached the half way mark. I have a 1999 Volvo S80 (I hate that car!)
Posted on Jul 07, 2009
VOLVOCHICAGO
  • 33 Answers
SOURCE: 2001 Volvo S80 trunk pops open by itsself
it a bad trunk lock or handle switch
Posted on Aug 18, 2009
  • 4869 Answers
SOURCE: diconnected battery and don't have the code
Volvo codes are usually readily available for free from your Volvo dealer providing you can quote the VIN and Radio Serial Number
Posted on Sep 01, 2009
In my 2001 Volvo S80, the radio worked intermittantly for a few months and then not at all. There is still power to the radio, speakers are good, and all radio fuses are good.
I had a car radio do that once in a used car I bought cheap, it turned out to just be a loose connector on the back of the radio, I clicked it in and it worked fine.
Apr 23, 2014 | Volvo 2006 S80 - Radio HU-650 - Amplifier...
I need a scamatic to install a used HU 850 stereo with nav into my 2006 t5 s60
Unless you are a master automotive electrical engineer, or a volvo service tech with mainline access, this will be lots of trouble. The original head units for volvos were flashed at the dealer or factory to each individual car. Even if you got all the wires to match up between years/models, you would still need to take the finished rig to a dealer or specialist to get it "relearned". Plan on spending hundreds of dollars no matter which way you go.
Mar 31, 2014 | Volvo s80 radio hu-850. audio 2005-...
WIRING DIAGRAM hu-650
Here are diagrams for hu-650. If they do not fit your needs, then you can call your local library to see if they have a book on your Make and Model.
WIRING DIAGRAM hu 650 RADIO INSTALLATION Google Search
Thank you for contacting Fixya. Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Jan 19, 2014 | 2006 S80 - Radio HU-650 - Installation Kit
I need radio code for volvo s40 2003 HU 555 SE NUM -VO 3840 30035077 Thks for your help
This is a Mitsubishi radio fitted in your Volvo and unfortunately Mitsubishi codes are only available from your VOLVO Dealer or by taking the radio into a Radio Decoding Service.
It won`t be available for free from anywhere on the Internet
Sorry
Mar 05, 2011 | Car Audio & Video
Code volvo s40 HU-405
Hello! The code for a HU-405 stereo can be acquired at a Volvo Dealership...However, you will need the part number of the radio...It is located on the same sticker as the serial number...
Guru....saailer
Jan 09, 2011 | 2000 Volvo S40
Volvo s40 2002 radio hu 605 radio says OFF any suggestions
press on, enter your security code, if you enter wrong 4 digit code the display is OFF or EEEE, wait 2 hours to enter code again
Jun 19, 2010 | 2001 Volvo S40
Need code for volvo v40 radio VOLVO HU-605
The HU-605 radio is made by MITSUBISHI and unfortunately the code is not normally available for free  (using the Serial Number ) from anywhere on the Internet as access is required to the original factory database which is only available at the Main Volvo Dealer ( and just a few of the larger Decode Services)
However , many VOLVO Dealers will provide  this code for free provided you can quote the car`s VIN number+ Radio Serial Number and have all the car documents available.
If not, then the alternative option is a Decode Service or your local Car Radio / Audio Store who will plug in a laptop to electronically read/recode the memmory chip (EEPROM)
Sep 23, 2009 | OEM Systems Car Audio & Video
Diconnected battery and don't have the code
Jul 11, 2009 | 2000 Volvo S40
Car won't start
Jun 03, 2009 | 2001 Volvo S80
Volvo car radio
i used to sell volvos . I believe if you call volvo serice usa , give them the vin # and identify you're the owner , they should help you.
Aug 11, 2008 | Car Audio & Video
Volvo S80 06 2006 Logo
49 people viewed this question
Top Volvo Car Audio & Video Experts
xxxxxx xxx
Jax Planet
Jax Planet
Tom Chichester
Are you a Volvo Car Audio and Video Expert? Answer questions, earn points and help others
