Question about Dishwashers
My problem is the drain pump stays on.. overflow cut out.. is this easy to fix... many thanks
    Novelist:
  • 222 Answers
Depend on the model,but mostly its hard to remove,much better call an authorized service technician.
Posted on Jan 04, 2011
  • gerbee gomez Nov 02, 2013
    most the washing machine if the drain pump is always on, you have a prblem for pcb if electronic if mechanical it is on the switch, but both of them is mostly is burnt part and not easy to repair or replace.
Kenmore washing maching overflow after washing
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 28, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
F-09 error code
Hi
F09 error occurs due to overflow condition, if the overflow contact on the pressure switch is closed for more than 60 seconds and overflow condition will occur. To start with check the drain hose and make sure it is not clogged, also try to clean the drain pump filter. If everything is fine and the drain pump is running then check the wire harness to the drain pump and control unit. Please post a comment if you need more help.
Thanks
Rylee
Nov 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an LSv66 Ariston dishwasher. When it is switched on, no matter what program, the knob just stays in the same position. It sounds as if the dump pump is running constantly.
The dishwasher overflow detection may have triggered. This causes the drain pump to operate.
The overflow float is located at the base of the diswasher and maybe faulty. It is spring loaded float and should move down and up when pressed. If you cannot find this in your model, then water has leaked into the overflow cavity where the motors are located. This could also trigger the overflow protection circuit.
You have to replace the overflow float if it exists or empty the overflow water in the overflow cavity and dry it out. If leak is taking place then the gasket needs replacement.
Hope you are able to fix the problem with some of the suggestions I have made.
Please rate the solution if you find it helpful otherwise post a comment.
Oct 11, 2010 | Ariston Technologies LL64WNA Built-in...
Washer overfills and does not drain - entire floor was wet. What went wrong? How can I fix it?
Hi There
I have found the code you are looking for and i hope this helps you. Let me know how it went.
F/09 Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service.
  • Check the drain hose and make sure it is not plugged or inked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check for Drain Pump Failure
  • Check the Inlet Valve for proper shut off
  • Check the Pressure switch for proper operation
thank you for writing to fix ya.
Best Regards Richard
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
F 09 ?
Hi There
Just want to say is merry x-mass and a happy new year. I found the codes for you so you can read it. I hope this helps and put you in the right direction.
Thank you for writing to fix ya.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
ASKO D3122 PUMP STAYS ON AND MACHINE WILL NOT SWITCH ON
The machine has activated a safty seq. There is most likely water on the lower buttom. Leakage or drain pipe blocked. The power will get to the drain pump, when this happends. To prevent overflow on your kitchen floor. Dry out the water. Then it will start as usual.
Jul 25, 2009 | Asko D3122XLSS Stainless Steel Dishwasher
A message comes up that says "I NEED SERVICE Fault code 37 Please call for service" What exactly is a fault code 37 and what's involved with getting it fixed? For example is it a major, expensive...
F27 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. This is verbatim from the tech sheet. You will need to check to following:
1. First, UNPLUG the washer for at LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, proceed to step 2.
2. Check the drain hose and make sure it is not plugged or kinked.
3. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
4. Check/Clean Drain Pump Filter of foreign objects.
5. Check for Drain Pump Failure.
6. Check the Inlet Valve for proper shut off
7. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pulling a vacuum on it with a shop vac. You may have an obstruction in the drain line or drain pump. It is also a good idea to check the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub and runs to the inlet side of the drain pump. This area can get clogged with small articles of clothing.
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the rear of the washer with all the wiring running to it). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the clear tubing (air hose) is still attached. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. This may generate an F27 error.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. Look for obstructions in the clean-out trap and impeller area of the pump.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off. You need to ask yourself if you find standing water in the tub when not in use.
5. The "Sud" error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent, HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause an over suds condition.
NOTE: Knowingly or unknowingly using the improper detergent on these model washers MAY void your manufacturer's warranty. Read all instructions and documentation that comes with the appliance, thoroughly.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a component failure (more commonly, the CCU or pressure switch)
May 03, 2009 | Washing Machines
F09 displayed on the machine
Hi!
F09 code on your whirlpool means---
Overflow Condition
If the Overflow contact on the pressure switch is Closed for more than 60 seconds and Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly. Try pressing PAUSE/CANCEL twice to cleaar the Display.
If display doesn't gets cleared then check for---
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump.
  • Pressure Switch, and Central Control Unit (CCU)
Please rate this solution as Fixya if found useful.
Please ask for any clarifications.
Thanks
Rylee
Mar 14, 2009 | Whirlpool Washing Machines
GE Mod WDSR2080D5WW won't drain
The last one I repaired had a 2 quarters in the pump.
Remove the hoses and inspect the pump for coinage.
Feb 03, 2009 | GE WDSR2080D Top Load Washer
Kenmore HE3 F 09 error message.
F09 Overload condition If the Overflow contact on the pressure switch is Closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check Wire Harness connections to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) ? Check / Clean Drain Pump Filter of foreign objects ? Check for Drain Pump Failure ? Check the Inlet Valve for proper shut off ? Check the Pressure switch for proper operation Replace failed component.
Sep 11, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
