Question about Goodman CKL36AR36 Air Conditioner
Goodman ckl36-1f We cannot find where the air filter is in our spilt system.
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Hey, I can't either. Is this an up flow system--or down flow system? How old is it ? whats the name brand ... or better yet, just add 1 before the fan on the suction side...Thankyou very much!
Posted on Aug 23, 2008
Goodman furnace
Sounds like the furnace is tripping off on a limit safety, either temperature or air switch. Check filters and restrictions to air flow (furniture over return air grills, blocked filters) also, check the drainage line of the system. If the furnace can't drain water fast enough it will back up internally, and trip the system off on a pressure switch safety.
hope this helps.
Mar 18, 2014 | Heating & Cooling
Hi, I have a Goodman GMS80903BNA Furnace and recently what happens is that when the thermostat calls for heat the draft inducer motor starts. However, after this nothing seems to happen. I don't h
Youcould be loking at the pressure switch try jumping it out and see if it lights some times you can fool it in to working , check the hoses are tight and nor spilt or take a drill bit and just clean out the 2 ports where the hoses fit some times they get blocked , also check you air filter is clean and your fan
Dec 18, 2012 | Goodman GMS80903BNA Heater
Why does furnace heat cut back?
You might try checking your return filter. The new filters (pleated 3 month, ie real expensive ones) cut back your air flow 35% from the amount the regular 30 throw away allow. When air flow reduces the temperatur from furnace increases and can cause inadvertant high temperature limits to trip. If you are using a clean return filter, next you need to physically observe the air inlet side of your cooling coil to see if it is blocking air flow due to being dirty. If you have trouble with seeing the inlet, you might need to get a professional to take the air handler apart.
Oct 29, 2012 | Goodman Manufacturing...
Where is the filter on my Goodman model capf3636c6ba ?
The main places that filters are located are:
Return Air Vent or Vents
Inside Coil Box
Underneath Furnace (Will have a small access door)
Filter Box Attached to Return Air System
A lot of people still look for their filters inside the coil box, but more recently installed units will have them in the return grills inside the house. Follow your return air from the vent inside the house back to the unit and it will be somewhere in between there. Hope this helps!
Aug 05, 2010 | Goodman CKL36AR36 Air Conditioner
Vw golf mk3 8v 2.0l gti, stalls after a few seconds on idle or when i pull up at junctions :(
it is could be induction pipe have spilt so check it ,is where the air filter with big black rubber hoses check it if is spilt if had ,take it off and get tape it up where spilt are 4 temporary till u get new one if not spilt is be something else good luck
Nov 19, 2009 | 1996 Volkswagen Golf
Cold air comes out but doesnt blow
The filter in a Goodman unit is in the Air Handler located at the bottom of the unit. Screw on either side take them loose and the filter pulls out. Now trun of fan first so the filter will come out easier. You may ahve other problems like stopped up coil or low on refrigerant. Russ
Jul 20, 2009 | Goodman CACF048B2A Air Conditioner
GOODMAN ARUF3642
These guys list the actual sizes of a good selection of goodman filters - just measure the old one or the space where it should be and match it to the right filter(should be a fairly tight fit). http://www.filters-now.com/products/dgb.html#skipmenu and this site describes what the different filter types available are http://www.oxyclean.com/goodman.html Hope this helps :)
Mar 07, 2007 | Goodman CLQ36AR49 Air Conditioner
GOODMAN # ARUFO49 AIR HANDLER
MOST ALL GOODMAN ( UP TO 3 TONS)INTERNAL FILTERS ARE 22" x 22" X 1". YOU CAN GET THEM ON LINE AT www.filtera.com. ALWAYS TAKE A TAPE RULE AND OPEN THE BOTTOM FILTER DOOR AND MEASURE THE FILTER RACK. MAKE SURE YOU DO NOT HAVE A RETURN-AIR FILTER-GRILLE. LARGE WHOLE -HOUSE RETURN AIR VENT NEAR OR AT YOUR FURNACE, A/C AIR HANDLELER. Joe_Rex New Member of FixYA Retired HVAC&R contractor 45+ years exp.
Mar 07, 2007 | Goodman CLQ48AR49 Air Conditioner
Goodman CKL36AR36 Air Conditioner Logo
205 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
