Question about Samsung CLP-660ND - - colour - laser - Legal/ A4 - up to 24 ppm / up to 24 ppm
Samsung CLP-660ND keeps giving fuser error even after a new one is put in. Fuser seems to be very hot, even after a couple of seconds in printer.
Cops
  • 64 Answers
SOURCE: Fuser Error 50.1 Fuser is hot. What is a fuser?
50.1
A low fuser temperature error has occurred, possibly due to an inadequate external or internal power supply.
this basicaly means that either the dc controller board is on its way out (expensive) or that there is a drain on the power line.
if you have it plugged into an extension lead try plugging it directly into the wall socket. if this fails also try using a different power lead (very easy to get hold of and are normaly called kettle leads)
Hope this helps
Cops
Pete@wedotoners.com
Posted on Oct 10, 2007
Soulvisitor
  • 1113 Answers
SOURCE: HP clj 2550n error 50.2 fuser
Replace fuser assembly is the fix
Normal consumable, the lamp electrics (lamp, thermistor) will have blown.
9337832.jpg Part info
Posted on Jan 13, 2008
  • 125 Answers
The fuser bonds the ink powders onto the paper. It is usually located behind the cartridge in the paper path. There may be several reasons why this error shows. (Bad fuser or bad power supply). It looks like this:
http://printerworks.com/Catalogs/hp-supplies/Q3655A-CLJ-3500-3700-supplies.htm
Here is some useful info:
http://www.fixyourownprinter.com/forums/laser/42184
http://www.coldreset.com/modules.php?name=News&file=article&sid=200
Posted on May 12, 2008
Maanita
  • 1142 Answers
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Posted on Aug 17, 2008
ChrisPUT
  • 6 Answers
SOURCE: Fuser 50.1 error on HP 3500 printer
From HP Website:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
Posted on Mar 23, 2009
The paper keeps jamming in our Samsung laser printer 660 nd. We bought heavier paper for a laser printer but it still jams.
The ideal paper is around 80 GSM (gm2) if you are having problems with a BRAND NEW REAM of standard copy paper then your printer will need service.
paper that is thicker/heavier than this can actually cause more jams and problems and show worn out rollers earlier
These printers only tend to jam at the entry (pickup) near the base of the printer or in the fuser unit (hot area near the top)
if you are getting jams in multi page documents, have a look at which area the most crumpled piece of paper is in before you try and remove it.
the pick up rollers and separation pads are relatively cheap but the fuser units can be a bit pricey.
CLP 660ND CLP 660ND XAA Support SAMSUNG Canada
Sep 29, 2014 | Samsung CLP-660ND - - colour - laser -...
Low Heat error...Cycle Power Samsung ML-2855ND printer
There is a problem with the fuser unit. This unit fuses the toner powder to the paper and if it is not hot enough the toner powder won't bond onto the paper.
Try removing the fuser unit, check the two fuser power spring contacts, and insert it back in the printer. If the error still occurs then you may need a new fuser unit.
You may need to get the printer checked out by a technician.
Mar 19, 2011 | Samsung CLP-600N Laser Printer
Samsung CLP-650N Engine Fuser Inverter Error 3
the fuser and dave home drive got to be repalce.
most likely it has worn out.
May 10, 2010 | Samsung CLP 315 Laser Printer
Fuser low heat error
Hi and thank you for using fixya:
This happens when the fuser is not getting hot enough to start the printing process. This could be happening because the fuse is already failing. Try calling samsung see how much is a new fuser
good luck
Mar 23, 2010 | Samsung CLP 300 Laser Printer
Samsung clp-610 has an error code of ''adc slope error cycle power'' what does this mean? How can we rectify the problem?
this would be a problem with the fuser unit. the analog to digital converter, ADC, is malfunctioning or there is a problem with the heat being put out by the fuser itself. if cycling the power doesn't clear the problem you will more than likely have to replace the fuser unit.
Sep 11, 2009 | Samsung CLP-610ND + Demo Laser Printer
Error message Engine Fuser Overhaet
The fuser rollers (large orange rubber rollers visible with top cover open) are getting too hot, or the temperature sensor/wiring is faulty and misreading the temperature. Assuming sensor is okay, check the exhaust fan is running and expelling warm air as over time it will clog with dust and the fuser unit won't be cooled effectively.
May 04, 2009 | Samsung CLP-500 Laser Printer
My samsung clp-300 printer is very hot
low voltage power sully and fuser need replacing.fuser is overheating.
Oct 15, 2008 | Samsung CLP-300N Laser Printer
Samsung CLP-510 Engine Fuser Low Heat error
I would purchase a new colour printer, Brother make some good stuff now and put your toner on fleabay.
1 747results for colour laser printer
Apr 21, 2017 | Samsung CLP-600N Laser Printer
Samsung CLP-500 error
Machine needs fuser replaced, normal user changable consumable, about 200 bucks in Oz
http://www.precisionroller.com/manufacturers/samsung-clp500.html
Nov 06, 2007 | Samsung CLP-500 Laser Printer
Engine Fuser Low Heat Error
there is a 2 wire device (thermistor) that rests against the fuser roller to measure the temperauture. if the fuser is getting quite hot, suspect the thermistor to be either dirty (remove and clean it with alcohol) or defective. if fuser not getting hot, then suspect burned out fuser heater (look inside fuser roller for a long light bulb).
Aug 28, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP-660ND - - colour - laser - Legal/ A4 - up to 24 ppm  / up to 24 ppm  Logo
455 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
