Question about Samsung SyncMaster 2253LW Monitor
"check signal cable" problem and
  • 11,361 Answers
It is telling you that it is not getting the video signal from your PC video card. Did you trythis monitor with another PC yet? This monitor has 3 years warranty so please find out if it is still under warranty first before we open it up to look inside. Are also using DVI to VGA adapter?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 04, 2011
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
About my monitor , f15t42 nec lcd monitor, signal cable problem , i don't know what the name of his connector.
signal cable is called data cable in technical terms. the connectors are called D type 15 Pin connector. if it is two end cable you can see one side is male type connector other side is female type connector.
Oct 13, 2011 | Computers & Internet
Acer x136w monitor, no signal. Connected parralel conector to back of computer. no signal..tried everything I know to do. Even stupidly pirchased driver whiz. nothing. ready to through monitor into th e...
No signal message on your LCD monitor screen means that your monitor is not receiving any signal from your PC graphic card. This problem "no signal" have nothing to do with the drivers installations. Have you check whether your graphic card is faulty or your cable connection properly connected/secured? ie VGA (D-sub). As far as I know there are no parallel connectors for PC Monitor connectors only, VGA(D-sub), DVI or HDMI cable interface.
Try to connect your monitor to another PC, just to test whether the LCD monitor is functional.
Hope it helps.
Mar 19, 2011 | Computers & Internet
How do I fix my hp w17e monitor that reads "VGA no signal"? I've tried unplugging my power cord and holding the on button for 30 seconds to a minute and plugging the power cord back in it still...
VGA no signal means "no signal" from the computer on the VGA (blue plug) cable... ...if the computer works check the cord for loose connection or get a new cord...if the computer is hooked to the digital cable (DVI/white plug)...set the signal source on the monitor to digital...
Feb 14, 2011 | HP w17e Monitor
My screen just stopped working and I have a rectangular box floating around in a counterclockwise rotation that says " Check cable signal " Do you have any ideas? It was working fine up...
that means your monitor is working fine, just check your video connection on both ends of the monitor and PC.
maybe your PC has two video cards, try to plug in another video connector
Jan 29, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
It shows "check signal cable",
Hi, Hopefully you are seeing this error on the screen of your monitor. If that is the case,
do the following steps.
1 Shut down the computer. To do this, without looking at the monitor, hold the on/off button to your computer in for about 5 seconds. The computer should then shut down.
2 Shut off the monitor.
3 Unplug the video signal cable, the thick one that goes between between the computer and the monitor and then re-insert it observing not to bend any pins. There are two end screws that you will have to be loosened, although they may have not been tightened in the first place. When you reinsert the cable, hand tighten those screws.
4 If there is a similar connector on the back of the monitor, repeat step # 3.
5 Make sure that the signal cable is firmly attached to both the computer and the monitor. 5 Turn on the computer and see if it has solved the problem.
If it does not, examine the cable for signs of damage along it's length.
If it is damaged, replace it. you should be able to get a cable for stores like Best Buy, or possible from a friends old stack of cables.
Hope this helps,
Mark
Jan 04, 2011 | Samsung SyncMaster 2253LW Monitor
I get a "no input signal" error message on the
Check the cable, to make sure that it's plugged into the monitor and the computer.
After that restart the computer - some computers only detect monitors right when it turns on.
Dec 22, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
My screen sayin signal cable disconected
if you are using an lcd monitor, make sure you have connected the vga (screen cable) properly and tight both on the tower and your monitor. if its crt monitor then make sure the vga cable is tightly connected to the tower on the female connector
Jul 19, 2009 | Dell UltraScan P1110 21" CRT Monitor
Monitor displays signal cable disconnected
Check your VGA connector (from monitor to PC), namely the pins in the connector. It's pretty easy to bend a pin, so that it doesn't make the connection. If you happen to do this to the connection present pins, then the monitor won't know that it is connected and will just display the message you are seeing.
Mar 15, 2009 | Dell UltraScan P1110 21" CRT Monitor
Radom flickering blue
Your video cable is not connected correctly. Make sure to check both ends, push in onto the connector fully, and then lock it in with the 2 twist screws on each end.
Mar 30, 2008 | E-Machines eMachines Monitor E15T4
Samsung SyncMaster 2253LW  Monitor Logo
182 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
