Question about Garden
My Stihl whipper snipper will not run after I have started it with the choke then turn choke off. What could be the most logical explanation and remedy? Cheers John
  • 124 Answers
My name is Dane and I am going to assist you in solving your problem.
If your fuel is mixed with oil, make sure it is mixed correctly. Too much oil in the mix will cause problems. Make sure you haven't left old fuel in it for a long period of time and gummed those jets up. Sometimes an engine just needs to run with good fuel in order to clean the jets out. If this is the case, just replace the fuel, get it running and work it normal for a tank of fuel if you can. You should see improvement by then.
If it still doesn't run correctly, you will have to adjust or clean the Carburetor. If you need to clean the Carburetor, you will probably need to remove, disassemble, soak, and use compressed air to blow out the jets in your carburetor. Pay close attention to how the carburetor is attached to the engine. Make a drawing if you need to or take some pictures. Remove the Carburetor from the engine. Remove the air filter, linkages, throttle/choke cables and fuel line. Remove the mounting bolts/nuts. You will need to disassemble the carburetor as far as possible and put it in some Carburetor cleaning solution. You can get this at any auto parts store. Do not place rubber parts in the solution. Allow it to soak in cleaner as directed, and then blow out the ports and jets with compressed air immediately after you take it out of the cleaning solution. Be careful not to get any spray back on your skin or in your eyes. Reinstall the Carburetor in the reverse order. Replace any worn or torn gaskets or o-rings as you assemble and reinstall it.
If you need to adjust the high-speed mixture setting on your Carburetor, turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however you do need a special tool that is very hard to get your hands on. They don't make many engines with plain screw heads on the jet screws anymore. The newer Carburetors are factory set lean so they can pass emission standards. If you have a local dealer, they should adjust the mixture for a couple of bucks. If you can adjust the screw, start the engine, allow it to warm up, and apply full throttle. Start backing off the screw just until the engine gets max RPM. That's it. You're done.
Just a TIP: Always mix your fuel with an approved fuel stabilizer. Fuel begins to go bad after a few months and that's why many people have fuel problems in the spring.
I hope I've helped. Thank you! Dane
Posted on Jan 04, 2011
My stihl whipper snipper loses power and cuts out when i try to rev and apply throttle.
With 2 strokes I always start with 'AIR' 'FUEL' 'SPARK' from the sounds of it the choke might be stuck on (choking the motor ha ha) also check the air filter, You have fuel and its moving through but the fuel filter might be slightly clogged. As its starting and going on low your spark unit is ok but you might need a new spark plug.
Dec 21, 2015 | Stihl Garden
I have a stihl 2 stroke petrol whipper snipper. It seems to have over heated at the reel end. I have smoke and grease spewing out at that end (metal neck at the reel end) have I fried it?
Sounds like you have a straight shaft trimmer version that have got bad bearing(s) that needs replacing. It probably will take the whole gearbox as a replacement item.
Jan 20, 2015 | whipper snipper stihl fs 38
I have a brand new easy start stihl 50 whipper snipper it came already fuelled it kicked over then died and now wont start or kicks and dies any thoughts
Try turning the choke off after it tries to start. This is a first for me. I have never ever heard of any type of yard implement, chain saw, mower, weed trimmer, etc that came brand new with fuel( gas mixture) in it or in the package. The fuel mixture for this trimmer I beleive is 50:1. Is that correct? This means that for one gallon of gas, 2,56 ounces of two cycle oil is added to the gas.
May 17, 2014 | Garden
Stihl whipper snipper fuel oil ratio
all Stihl products are 50:1 fuel mixture
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Mar 30, 2013 | whipper snipper stihl fs 38
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
Stihl whipper snipper wont start.. everything checks out ok furl spark plug etc
I have a Sthil and the wiper snipper it starts but when I increase the power it seen to either stall or flood plesae help
Oct 12, 2010 | Garden
My fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Jun 28, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Garden Logo
1,219 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
