Question about Microwave Ovens
Philips self-clean steam iron Mistral 10 No manual - the self-clean/temperature wheel comes 'out'. Is this okay? Do I leave water in the iron whilst self-cleaning?
SOURCE: How do I clean the microwave ?
I work in a kitchen and we spray some plain water in it turn it on for 15 seconds and when it turns off the stuck on stuff wipes off with no problems. if it all does not come off repeat until complete. :P cheers
Posted on Feb 05, 2010
  • 19 Answers
SOURCE: how do i self steam
something you can do instead of the steaming, try the Mr cleaner white miracle spounges, they are really miracle, good luck, God bless
Posted on Jan 26, 2011
  • 2006 Answers
SOURCE: my iron is squirting out
Sometimes using vinegar and water will clean out your steam iron - but smells really bad. Usually the brown gunk is a sign that there is corrosion so even if the vinergar works, you should plan on buying a new iron in the near future.
Posted on Jun 22, 2011
vko007us
  • 254 Answers
SOURCE: how do you clean the
please specify ur microvave model no company name with clarity on the service problem to resolve ur issue
Posted on Aug 16, 2011
SOURCE: bosch b35l steam power iron in
no steam coming out from Bosch B35L. Sny suggestions
Posted on Aug 18, 2011
What is this silver piece in my microwave? what is the result of using the microwave without this piece?
hi..
"Iron with aluminum soleplate quickly smoothes out wrinkles"
product overview...
- Combining a simple, classic design with an array of modern conveniences, this powerful iron quickly and easily smoothes out wrinkles. The unit's fabric-select dial and convenient fabric guide make it easy to choose the right amount of heat needed for the job, while its aluminum soleplate creates crisp creases and comes with a pointed tip that works well for getting into pleats, between buttons, and along seams. Other highlights include an "on" indicator light, a thumb-activated steam-surge button, an anti-drip system that prevents water spotting at low temperatures, a pivoting cord, and a stable heel rest. For enhanced safety and peace of mind, the iron will shut off automatically after 30 seconds of inactivity if left on its soleplate or tipped over on its side; if left vertically on its heel rest, it will shut off after 8 minutes.
  • Iron with aluminum soleplate quickly smoothes out wrinkles
  • Fabric-select dial and convenient fabric guide
  • Thumb-activated steam-surge button; anti-drip system prevents spotting
  • Dry-iron option; pivoting cord; stable heel rest; 3-way auto safety shut-off
  • Full-range fabric/temperature settings
  • Power indicator light
  • Button groove
  • Pivoting cord
  • 2-year limited warranty
  • Note: Product may vary by store
  • Home Depot Protection Plan:.
Nov 14, 2015 | Black and Decker USA Black & Decker F67e...
I have a Bosch steam iron TDS25, and the handle of the iron is getting red hot and water is coming out of the back of the iron. Help!!
Steam irons become clogged from water deposits. You may clean your iron with white vinegar and water. You should use distilled water. Make a Mixture of 1/2 water and 1/2 vinegar, and pour the mixture into the iron as you would when you fill the iron with water. Turn the iron on 'steam' and let the mixture run through. You may need to do this a few times, depending on how clogged the iron is. After cleaning use distilled water to fill the iron, becuase distilled water leaves minimul deposits behind.
May 01, 2014 | Microwave Ovens
No steam coming out of iron, does it need descaling and if so how do you do it? Thanks Iron is Wahl zx506-1
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Aug 25, 2011 | Microwave Ovens
My iron is squirting out brown gunk from the steam holes under the iron itself. i have cleaned and rinsed it out. the manual says it is a gc 7430, gc7420.
Jun 22, 2011 | Microwave Ovens
I HAVE A ROWENTA STEAM GENERATOR IRON AND IT IS ALWAYS SPITTING OUT WATER WHICH STAINS MY FABRIC. i AM A QUILTER AND USE THE IRON ALOT.
Drain the water if don't need steam function, that's the best thing you need to do. Some iron when there is water like the one you use, when if its full on water really split out water, keep water in minimum or drain all of it.
I hope my advise help you.
Mar 29, 2011 | Microwave Ovens
Microwave now takes ~2x longer to heat up and is steaming up inside
Place a 1/2 litre of water in a plastic microwaveable container. Record its temperature and place it in the microwave. Microwave on full power for 1 minute. Leave for 30 seconds and measure the temperature again.
If the temperature rise is at least 10 degrees Centigrade, the magnetron is fine.
Mar 02, 2011 | Whirlpool Microwave Ovens
I have a polti steam iron 600 do i have to use distiilled water or will tap water be ok thanks
Steam irons are built to run on tap water, there will not be any problems whatsoever unless the water is hard, which may leave sediments inside the iron after evaporation.
Feb 28, 2011 | Microwave Ovens
How do I add water to the pressa bella dry steam iron
Turn the big yellow top, if it's air tight use a plier and gently turn it. That will the trick.
WARNING!!! Becareful not to over fill the water reservoir by doing so the water boils making it leak. It is extremely dangerously as I steam burned my hand. Other than that u won't have a problem.
Jan 18, 2011 | Microwave Ovens
I have a steam station Iron, it stopped sending the steam from the base into the iron through the cord .Also it has debris in the base when i empty the water Do you know the problem & can you offer...
This can be checked by you as there is not much of mechanics . Make sure that the steam is generated in good quantity so that the cord gets full pressure, if not clean the base perfectly so that there is good contact -- no debris .. make sure with a air pressure or water jet the connection tube is clean and not damaged at any points, if so the steam will not flow .
Once this is established you will get good steam pressure or else the connection tubing cord needs a change.Also make sure there are no issues in the iron to block off steam.
Sep 30, 2010 | Microwave Ovens
Microwave Ovens Logo
241 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
