Question about Fujitsu Siemens Computers & Internet
Need to replace my battery # 63GL50028-5B as I have been running it right out until the computer cuts out and then recharging it but it does not seem to hold its charge. Where can I purchase a new battery please
    Sergeant:
    Champion:
  • 215 Answers
Hi,for replacement purchases go to these site: www.notebookparts.com
Posted on Jan 04, 2011
Hello I cannot get my ue boom speaker to charge.I also tried diff charges
The battery is below the cutoff point. Devices with Lithium-Ion Battery's. The battery it's self has a built-in protection device. It's a circuit board with miniature integrated circuits and components custom designed to monitor the state of the battery. And if the battery gets to high or to low in voltage or to hot or cold or if the battery is over loaded or short circuited the device disconnect the battery from the outside world preventing a fiery explosion when you see in the news people who have had laptops or phones or whatever go up in flames because these circuits have failed to do their job. You need to take the device to someplace like Batteries Plus Bulbs and have the battery checked to see that it is not completely dead and it has only Fallen below the cut-off limit it can be jump started to recharge if it is only slightly below the cutoff otherwise it has to be replaced. What causes this problem is using the device until the battery is in need of being charged and then not charging it right away letting it sit the little circuit board that I mentioned that is in the battery draws a very tiny bit of power to run it's self. So if you use the device until the battery is very low and don't rechargeable it right away then it sets for a couple of months that tiny current draw from the protection circuit will drain the battery to the point where the protection circuit will disconnect the battery from the outside world.
Sep 11, 2017 | Radio Communications
Inactive air suspension
Crank the steering wheel while the engine is running (in park) all the way to the left until it stops then all the way to the right till it stops that will solve your problem.
You're welcome. ;-)
Mar 17, 2015 | 2005 Land Rover Range Rover
Doesn't power on
Running a ups without batteries is not a got idea, the batteries are a critical part of the system and without them the ups will not function when the mains power is cut off.
however we can determine if the batteries may be an issue by removing them and checking the output voltage of each battery with a multimeter. I have personally found in the past anything less than 6v may or may not indicate an issue.
With all that said the ups should still turn on and try to boot and charge the batteries regardless if the batteries are dead flat or not. Assuming mains power is connected and the safety fuse is good then it seems most likely a fault in one of the control boards.
It's also worth mentioning that the fans will only start when either the inverter is running ie the mains supply is cut or like in my units the fans will remain on after the mains supply has been restored until the batteries have been recharged.
Aug 25, 2017 | APC Computers & Internet
What wrong with my computer?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 20, 2013 | Toshiba Satellite L750 Notebook
Replaced the k134 car cuts off after engine gets hot. guessing 40 minutes of driving
The battery in most cars is used only for starting and operating electrics when the engine is not running.
After that, the alternator provides power to operate ignition and electric systems - and of course; recharge the battery. A faulty battery shouldn't cause the car to stop running. If the alternator is not functioning properly, the car will get power from the battery instead. When this happens, the voltage will drop quickly - depending on how many electrical accessories are on, etc. You will notice headlights becoming dim at night just before the engine quits. The car would not be able to start / run until the battery is recharged.
Nov 08, 2012 | 2000 Cadillac Catera
1997 Chrysler Sebring cut out while running, replaced fuel pumd, cranksensor, got used distributer from running car, then replaced the computer and it started!! but cuts out right away!at first would
See if resetting your ECC (ECM) called the computer will get rid of these problems. You do it by unhooking both battery cables, waiting at least 15 minutes and rehooking the battery. No security thing, only the fact the computer needs new settings for the parts you installed.
Sep 10, 2012 | 1997 Chrysler Sebring
Just saying battery life low consider replacing, only had laptop 18 months, did`nt think it would need replacing in such a short spell.
Run the computer only on the battery, until it is exhausted.
Fully recharge it.
Fully recharge it.
These "deep-cycles" may give the battery-life a "kick". Maybe.
Check the web-site of the manufacturer of the computer.
Maybe, there is a "known" problem with that particular model of battery.
Do a Google-search for the part-number of the battery, to see if anybody has posted comments about poor battery-life for that part-number.
If running only on batteries is "important" to you, then consider replacing the battery.
Jun 12, 2011 | Computers & Internet
Seems to be electrical problem
What initiated the need for jump starting? Is the alternator charging? Has the battery been checked?
To check the alternator, once the engine has been jumped and is running, remove one of the battery post connections. If the engine dies, the alternator is not charging the battery, and the symptoms you describe are the on-board computer going through low voltage spasms until sufficient electrical power to operate the engine / tranny is drained and the car dies.
If the car continues to run with no battery attached, the alternator is charging - - - and I would recommend removing the battery and having it checked and (if good) recharged to full capacity. I would also recommend having it charged even if the alternator is the problem just to delay the onset of the low voltage problems. The car should operate normally for a few miles before the battery drains too low after a full recharge, enabling you to get it to a shop for alternator service / replacement.
If you attempt replacing the alternator yourself, make sure the battery is disconnected prior to starting the job. Saves blowing up good stuff by accidental short.
Hope this helps and good luck!
-WB.
Jun 12, 2008 | 2002 Mazda Tribute
Computers & Internet Logo
204 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Marcin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
