I have a Kenmore He 4t in the Elite series. I am getting the Sud and F 02 errors. The lady I spoke with told me that those were detergent errors. There is more than one family living in my home and I am sure that some of the detergent being used is not the appropriate kind. There is always water left in the tub of my washer. It doesn't seem to be draining out at all. Can I fix it? If so, how?
  • 246 Answers
F2/ SUD often indicate there is a drain error. You likely have something stuck in your pump (which would also explain having water left in the unit). Remove the lower front panel. (there are 3 #20 torx screws on the bottom of it holding it on)
Once you have the panel off, the white object in the front center is your pump. Remove the #20 torx screw out of there too to make life easier. Slide the pump forward slightly so you can raise it. Now, on the front of the pump is a handel that you
will need to turn counter clockwise. So after placing something underneath to catch the water left inside the machine ( a large bowl or bucket), turn the knob slowly counter clockwise. If there is too much water for your container, screw it back clockwise and go empty your container. Repeat until all of the water is out. Once that is done, unscrew it all of the way and slide if forward. You will usually find missing socks, toys, coins and all other kinds of fun objects. While you have the trap out, reach in with your finger to the hole on the right. Try and turn the wheel
inside to make sure there isn't anything keeping it from turning (bobby pins, nails, screws, etc) If there is, you will need to unclamp both hoses on the back of the pump and remove any further forign objects. Now re-assemble the unit but leave the panel off. Run a quick fill and drain to make sure all of your connections are tight and you don't have any leaks. Put your panel back in and you're ready to go. You do however want to make sure a high effeicentcy detergent is being used by everyone. It will cause undo wear and tear if you use a regular detergent and can lead to costly repairs. I don't perscribe to the whole powder or liquid, this brand or that. I just say make sure it's an 'HE' soap.
Posted on Jul 09, 2008
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
He3 elite kenmore- sUD and F21 error
Hello there"
Sud SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds.
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Dec 25, 2009 | Kenmore Elite 45986 Front Load Washer
Sud/F35
if your using more than 2 tbl spoons of HE detergent, you WILL have the same problem with your new washer." sud "stands for TOO MUCH SOAP
Jul 24, 2009 | Kenmore Elite 45986 Front Load Washer
F35 & SuD error codes on Kenmore Elite Washer
F35 has to do with the pressure switch which is located under the top panel on the back right. It will have a little black hose hooked to it. This happens when SUDS or detergent somehow gets up into it and usually locks unit out. Only solution is to replace pressure switch. You can find the tech sheet behind the bottom front panel usually tape to the back side of that panel or taped to the bottom right side inside unit. Hope this helps
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
My washer is flashing sud...what do i do?
The following link explains the "SUD" error and how to correct:
http://www.fixya.com/support/r629564-suds_error_whirlpool_kenmore_front
The error can be caused from obstructions in your drain pump (or lines) to using the wrong type (or too much) of detergent. Read through the link thoroughly and let me know what you find. This problem usually has a simple remedy that does not require a repairman. However, if you require additional assistance, or have questions, please let me know. I hope this helps you.
Feb 23, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4t Washer
Error code F02 f the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the ?Sud? error will be displayed, then 4 minutes later the F02 error code will be displayed. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check the electrical connections at the pump and make sure the pump is running. ? Check the drain pump filter for foreign objects ? If the above does not correct the problem replace the pump
Sep 11, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He 4t washer
washer weary, You need to clean the filter on the pump. Remove the bottom panel and the filter will be right in front. 3 #11 torx screws it will pull down and off. Get yourself a bucket to catch the excess water. Unscrew the filter and clean it. Check to see that nothing is in the impeller. The F02 should go away..Catriver.
Washing Machines Logo
Top Washing Machines Experts
