I'm trying to reboot my laptop. it's an Acer Aspire 5670. alt+F10 doesn't work and i uninstalled epower managment and erecovery managment. so i don't know how to reboot my laptop now.
GodSpeed
SOURCE: d2d recovery
Send me an e-mail and I will send you the fix! If you can't downloadload it from the below link. I had the same problem. The mbr was replaced, you have to add RTMBR.BIN to the MBR and it will work again. As long as you can get on your desktop and run this bat file you will repair the D2D again. Took me an hour to learn what was wrong, It works 100% though.
I have the Aspire 5610Z with the 2GB 533 mhz memory Stock.
Link #1
http://rapidshare.com/files/64293596/Acer_MBR_F10_Repair.zip.html
Link #2
http://www.sendspace.com/file/ngd4ql
matrix@gainbroadband.com
Posted on Oct 22, 2007
Junoon007
  • 1011 Answers
Hello Sir / Madam,
Many Acer systems come with the ability to press ALT+F10 to kick off the Acer Recovery applications from a special hidden recovery partition. Sometimes this won’t work and there can be a number of reasons.
1. D2D Recovery is “Disabled” in the BIOS (Main menu).
FIX: Enabled it and try pressing ALT+F10 again as the computer boots.
2. The Acer hidden recovery partition (PQSERVICE) has been removed or damaged. If the disk drive is a replacement drive then you won’t have this partition.
FIX: Unless you have previously imaged the PQSERVICE partition it will not be possible to use D2D recovery. You will need to restore from the Acer Recovery CD/DVD.
3. You have converted the FAT32 partition on the hard drives into NTFS. Acer D2D recovery won’t be available if you perform this conversion. Ironic that NTFS is a more desirable disk format to use but Acer won’t support this in their systems!
FIX: Restore your system from the recovery CD/DVD media.
4. The special Acer Master Boot Record (MBR) has become corrupt or has been overwritten with an non Acer MBR. As long as the PQSERVICE partition is there or you can get your hands on a couple of Acer service files for your model, then you can remake the special Acer MBR. Let’s cover how this is done.
  1. Disable D2D recovery in the BIOS. Can be found in the “Main” menu section. Save the BIOS settings and exit.
  2. Log into Windows with an “administrator” level account.
  3. Download ParTEDIT32.ZIP (registration required for download).
  4. Extract PTEDIT32.EXE from the zip archive and run it.
  5. Identify the PQSERVICE partition by its type or size. It is likely to be 12 or another custom value and is likely to be reasonably small in comparison to the other normal partitions - see the example below from a working factory default Acer. Click the Link below see the image full size. http://www.roundtripsolutions.com/blog/wp-content/uploads/
  6. 2007/10/AcerDiskRecoveryBroken_F031/hidden.jpg
    Change the type to “07′ (Installable File System NTFS, HPFS) and “Save Changes”.
  7. Reboot the computer and login with an “administrator” level account.
  8. You should then be able to open up a command prompt and navigate to the PQSERVICE drive.
  9. Enter the following command at the command prompt:
    mbrwrdos.exe install rtmbr.bin
    - You may have to search for these files and change into the relevant directory.
    Note: This step writes the Acer MBR, with mbrwrdos.exe and rtmbr.bin being the special service files.
  10. Close the command prompt window and reboot.
  11. Go into the BIOS again and enable D2D Recovery. Save the BIOS settings and exit.
  12. ALT+F10 should now start Acer Recovery as the computer starts.
  13. The Acer MBR ensures the PQSERVICE partition is hidden therefore there is no need to reset the partition type back to 07 - well there shouldn’t be if all has gone well. If you need to manually reset it then run PTEDIT32.EXE again, set the partition to 12, or whatever the original value was, and save the changes to complete the process. Reboot and it should now be hidden.
If Windows is unbootable, due to whatever issue, you can always use the Ultimate Boot CD for Windows (UBCD4Win) along with a copy of PTEDIT32.EXE to achieve the same results. Likewise, use UBCD4Win along with PTEDIT32.EXE if the PQSERVICE partition is being changed back to a hidden one by the existing MBR. We’ll leave that as an exercise for those who need to do it! It has been pointed out in the comments that UBCD4Win already has an application that will do partition maintenance, so checkout TestDisc if you go down that road.
If this is a new drive or someone has completely wiped the drive, including the hidden partitions, it may be necessary to use partitioning software to recreate the partitions that the Acer Recovery system is expecting! You’ll also need to restore an image of the recovery partition from a previously made backup, so it is worth making that backup image straight away while the laptop is still new and shiny, and certainly well in advance of any problem.
A final word or two of caution: take great caution when playing around with partitions on an Acer system… you have been warned… and remember to make the backup media disks as soon as you fire the computer up for the first time!
Thanks
Good Luck
Don't forget to rate the Solution!!!!!!!!
Posted on Mar 20, 2008
xCAUSALITYx
  • 210 Answers
Unfortunately once your original HDD has been replaced you lose all e-recovery features and there is no-way this can be reversed.
If you could get hold of the image from your old drive you maybe able to write it to your new, its a bit messy though.
The main reason for the "factory default image backup" you have not working now is because a snapshot of the C: drive is stored on D: drive so when you replaced the drive itself you basically made that disc useless for eRecovery features.
Sorry its bad news.
Cheers
Posted on Jun 17, 2008
ginko
  • 19396 Answers
SOURCE: ACER eRecovery management
Download the recovery manager from this link.
I will be grateful if you can take some time to rate the solution.
Many thanks.
Posted on Aug 31, 2008
  • 479 Answers
SOURCE: aspire 4520 epower management DMC has stopped working
uninstall any game recently installed (cossacks).
Posted on May 29, 2009
Aspire one d257-13473 wont factory reset
Windows key > All programs >Acer Empowering Technology>eRecovery management>Restore>Factory(Top of list)..
Or
If computer will not boot.
Tune computer ON
When Acer splash is on screen hold Alt and keep pressing F10...
Select factory from top of list.
You will need a password , the default is "000000" (Six zeros).
Recommend you use the first option if you can...
1. Power on the machine.
2. At the ACER BIOS screen, hold the "Alt" key and press the "F10" key simultaneously to start Acer eRecovery. The window of opportunity is very small, so this may take a few attempts.
3. Once eRecovery has loaded, click "Restore to Factory Default Settings" (the password is six zeros, 0.0.0.0.0.0.).
4. Click "OK" to continue.
5. From here, the eRecovery process will update all the data on the C: drive and restore the factory image (approximately 10 minutes).
6. Once eRecovery has run, press "OK" to reboot unit.
***This will erase all your unsaved data!***
Or
Running System Recovery from Windows
1. Click Start>All Programs>Acer Empowering Technology.
2. Select Acer eRecovery Management.
3. Select Restore (bottom of eRecovery screen).
4. Select Restore system to factory default (the password is six zeros, 0.0.0.0.0.0.).
5. Select Yes then Next, the system will reboot and start the recovery.
Or
1. Reboot, and press F8.
2. Select Repair.
3. Select Reinstall Windows and follow prompts.
Dec 06, 2013 | Acer Aspire One D257-13473 Netbook
How do i recover to factory setting onacer travelmate when f10 doesn,t work i got it used and have no disk
THE answer is if your machine can boot to windows, go to start, all programs, Acer eRecovery Management. or immediately when you boot up your unit hold the Alt key down, and continuously tabing the F10 key, hthat should take you to the eRecovery console. (Alt+F10)
May 31, 2011 | Acer Aspire One PC Notebook
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
The system will reboot.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
HOW CAN I RESTORE MY ASPIRE KAV10 TO ORIGINAL FACTORY STATE?
press alt+F10 at acer logo displayed at first screen
you will directed to acer erecovery management
at acer erecovery management chose restore to factory setting
then follow the instruction until finish
Mar 14, 2011 | Acer Aspire 1 Xp Notebook
I need a acer aspire one happy recovery disk
The Acer Aspire One Netbook has a hidden partition on its hard disk drive which allows recovery of
1. operating system to original factory image (with no recovery disk required)
2. applications (selectable)
3. drivers (selectable)
If the netbook came with pre-installed Windows XP, use Acer eRecovery Management by
1. pressing start button at bottom left corner of Taskbar
2. hover cursor over All Programs then Acer Empowering Technology
3. then click on Acer eRecovery Management and follow subsequent recovery instructions
Alternatively, on powering up, press Alt and F10 together while Acer logo is showing.
If this doesn't work, there is the possibility that the D2D recovery is not enabled for startup.
To enable D2D recovery,
1. press F2 on powering up to get into the startup utility
2. cursor over to the Main tab
3. cursor down to D2D and enable it.
4. save changes when exiting - system will reboot
5. again, press Alt and F10 together while Acer logo is showing.
Jan 15, 2011 | Acer Aspire One Netbook 8.9" Notebook
Restore to factory default
Unlike other laptops, Acer notebook/laptops integrate a computer management utility called 'Acer eRecovery Management' to create backup of hard drive data, create restore point, reinstall applications & drivers, and reset Acer Aspire 4315 to factory setting.
Step 1: Before starting your Acer Aspire 4315 laptop, ensure that there is no external storage device attached to it. Now start your laptop.
Step 2: Press 'Alt + F10' when the laptop starts booting, and wait for a moment while Windows loads the reset files.
Step 3: When 'Acer eRecovery Management' window appears, select 'Restore System from factory default' and click 'Next' to continue.
Step 4: Again click 'Next' to reset your Acer laptop. This process will erase all data from your hard disk and reset your Acer one to original factory settings.
Step 5: Click 'OK' in the notification window to begin the the resetting operation. Now wait while your Acer Aspire 4315 is reset to factory settings.
Tips: You can also create a backup copy of your notebook data before factory reset. Simply click 'Backup' in 'Acer eRecovery Management' window.
If you face any issue with your Acer Aspire 4315 Notebook/Laptops/Desktop, feel free to get expert technical assistance at
http://www.vtechsquad.com/acer-support/
Jul 26, 2010 | Acer Aspire 4315 Notebook
How can i reformat my laptop on CD acer aspire 3000
Using Acer eRecovery Management
You can launch Acer eRecovery Management in a number of ways:
Acer eRecovery Management requires a password to activate. The default password is six zeros (0s).
Note: These steps will return the system to the original factory installation including all factory installed drivers and applications.
Back up all data prior to using this procedure.
  1. Plug in the AC adapter and battery.
  2. Turn the system on
  3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
  4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
  5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
OR
From the Start menu, go to Start > (All) Programs > Empowering Technology > Acer eRecovery Management.
Or try this By clicking on the Empowering Technology icon from your desktop, or pressing the key to launch the Empowering Technology user interface. Select the Acer eRecovery Management icon.
Oct 11, 2009 | Acer Aspire 3000 Notebook
Aspire 4520 epower management DMC has stopped working
May 29, 2009 | Acer Aspire 4520 Notebook PC
Acer laptop restore factory settings?
If windows is running you can start it by going to Programs, Acer Empowering Technology and run the Acer eRecovery Management. Note that on the bottom of the eRecovery Management window are 3 choices, Backup, Burn Disk and Restore. Click on Restore. Here you have the choice of select Restore System to Factory Default.
If windows is not working but the system boots -
Reboot the system and when the Acer logo appears, hold down the ALT key and press F10. This starts the recovery process, just follow the instructions.
Oct 19, 2008 | Acer Aspire 5050-3242 Notebook
Drives not recognice
did u try to reload the os using alt+F10 or disks ?
It should fix your problem
Feb 06, 2008 | Acer Aspire 5101WLMi Notebook
Computers & Internet Logo
David Payne
David Payne
