Question about Refrigerators
Moffat fridge leaks, every couple days water on floor at front of fridgee
The reason why it leaks is because the pipe that discards the water underneath the refrigerator is clogged and must be cleaned. The water normally drains through this pipe into the bottom tray of the refrigerator where this water deposit is supposed to evaporate during normal conditions. When the pipe is clogged then the water does not fall into this tray. Therefore, turn off the refrigerator (power off/ previous taking-out of all food of course!) than go behind the fridge and locate this pipe (plastic hose / if you have difficulty locate at least the tray on the bottom and than locate this pipe / to locate it you can see the little hole on the back bottom of the freezer this is where the water is supposed to get out. Put water into the hole and you can see where it falls). Clean the pipe and the problem should be solved.
Posted on Sep 18, 2008
Freezer leaking
open the freezer panel in back. unclog drain hole where water collects. defrost unit first. put a towel in front of unit for some water
Feb 25, 2010 | Refrigerators
A small amount of water is leaking out of the front of the refrigerator onto the floor every day and I can not fine the source of the water. Is there a drain pan and if so where is it? If it is not the...
older fridges drained water into a pan with the compressor in it, thus cooling the compressor and evaporating the water, this is located at the bottom back of the fridge. if this fridge has a water and/or ice dispensor, the water could be leaking from many a place.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leak in back of fridge for 2 days. All else works fine
It sounds like the fridge water supply line is leaking. Pull the fridge out and have a look. May just need tightening.
May 28, 2009 | LG Refrigerators
Water Leaking - Freezer
My mother's fridge had a leak on the freezer side in the front. I removed the cover below the doors and found a plastic coupling in the water line to the water in the door option, when anyone filled their glass with water the coupling leaked. I bought a new plastice 1/4 inch coupling and replaced the old one and the problem was solved. The coupling costs about $3.00 a Lowe's and it took about 2 min. to change.
Apr 18, 2009 | Frigidaire FRS26R4A Side by Side...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
No water or ice from older kenmore side by side
You must pull fridge out the water valve is in the bottom back. Sounds like the valve is stuck open. You can Google your model# to find appliance parts to order new valve.
Nov 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water leaking from refrigerator
hi thanks for the question you can, remove the spout use a flat screw driver and pry off . now clean it pull fridge away from the wall remove the drain tube from the back clean reinstall thanks the appliance doc
Sep 28, 2008 | Refrigerators
Frigidaire Side-By-Side Refrigerator Leaks Water on Floor
I don't have the same refrigerator, but had a similar issue with a GE. Melt the ice at the bottom of the freezer. I think the water comes from the auto defrost feature. There should be a hole at the back bottom of the freezer that water would go into, and run to an evaporator pan under the refrigerator. The tube may be blocked that allows this water to drain, so it is backing up in the bottom of the freezer, and overflowing through the front bottom of the freezer to your floor.
Refrigerators Logo
1,098 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
