Question about Fisher and Paykel GWL11 Top Load Washer
OK The description might be a bit lengthy. Had some problems with the machine and checked the controller with some mosfets blown. Repaired those but fault persisted and mosfets blown again suggesting additional damage on the controller. Decided to replace the entire controller and the water inlet valves as they also seemed to be suspect ( cold water after heating up a bit). After the replacement there was a error 9 (size switch error) and I did a memory reset. The machine started up on a short wash cycle and did everything correctly up to the spin cycle. I checked the water level during the fill and it was spot on the mark on the agitator. The machine started the spin cycle with movements similar to a wash (back and forth let say a 3/4 turn) I assume its doing some sort of a movement check. It then keep on doing this wash like action for some time (might be the two minutes as per the fault diagnostics description) and then stops. Checking on the fault diagnostics it gives error 40 (Basket disengage fault) but after inspection of the mechanical parts all seem OK. Even checked it empty without water while I could clearly check that the basket is all the way down and properly engaged. It also turns during the spin phase but only in this pumping action as described The machine doesn't go into a full spin. I am quite knowledgeable in electrical and electronic matters and would even be able to repair things on a component level if need be. I did manage to get it this far ( from a dead machine up to the final spin) and would hate to give up steps from the top of the mountain. Any suggestions would be appreciated Even if someone could only give me an indication what the machine is doing during the spin phase and what inputs it might be looking for to proceed to the final full speed spin. From my thinking the Hall sensors must be OK in order for the machine to do all the other stuff correctly. Thanks Hennie
  • henniealbert Jan 04, 2011
    Have the document. It is my reverence for all the clever comment I manage to come up with.
    Thanks
  • henniealbert Jan 05, 2011
    I did a full mechanical strip-down with the tub removed cleaned and checked everything. The tub can move up and down freely and it engage securely in the down position. I will check if the tubs move with the agitator when the machine tries to spin. Its so funny that if asked if it does I can't actually say for sure. I was so preoccupied looking at the movement of the agitator that I did not look at what the tub was doing. Will report on it as soon as I get a opportunity to look into it.
    Thanks
  • Fisher and P... Master
  • 8,220 Answers
Click here for a service document
This is the base manual. I do not have the supplement for gwl11 but the basic stuff is included in this document.
Posted on Jan 04, 2011
  • Dan Webster
    Dan Webster Jan 04, 2011
    Maybe something is between the tubs?
  • Dan Webster
    Dan Webster Jan 05, 2011
    I found this big king sized pillowcase jammed between tubs in a similar type machine.
    Let me know what you find out.
Player will not eject, play or stop, standby light will not come on
hi,
If there is no standby light then you have to check the power supply of your blue ray player. Its will be an smps power supply. Very carefull while dealing with such power supply beacuse there will be Live areas in the board. You have to check the fuse in the smps. If the fuse is faulty The its sure that the smps driver MOSFET is short. Before replacing the fuse you have to check the MOSFET. If not it will lead to further dameges to your system.
If the fuse is ok and the power supply is perfect then the mother board of your player is faulty. If so then you have to contact the nearest Authorise servicing center to get it repaired.
ok
Aug 02, 2011 | Oppo Digital BDP-83 Blu-Ray Player
Screen horizondally pulled right side and screen rolled to left side
hi,
your monitors horizontal deflection side have some problem. you have to check the horizontal width cotrolling transistor mounded on the aluminum heatsik near the lot( line output transistor). also check the three mosfets which adjust the width for different resolutions. there are three such mosfets in the horizontal section.
fist of all replace the width controlling transistor in the heat sink. photo of mosfet and transistor is added for reference. not the exact number.
ok
Jan 27, 2011 | AcerView 99C 19" CRT Monitor
I need help on changing a fuse in PMP3000. The mixer went out on us one day, so I hooked it into an amp that we had. It works good as an unpowered mixer, but cannot get it to work as a powered mixer. I...
No, that is NOT what the problem is.
The fuse protects the power supply. The power amps have failed. The usual cause is an arc between layers of the multi-layer circuit board. The labor to repair the power amp module is extensive. I have repaired several.
You can find new amp modules and I would purchase a new one and drop into your unit. The amp module is an HCA2400.
There is probably $15 of parts blown in each side of the power amp and it takes about 6 hours to repair. One has to grind out the burned area (internal layers not necessarily visible on surface) and re-insulate and then install jumper wires to replace those taken out.
Each side of the amp will likely take out 3 switching MOSFET transistors and often a Zener diode. Sometimes a low resistance metering resistor will be fried with smoky residue underneath the board. When this happens two small surface mounted resistors will be blown open. Great care has to be taken when insulating the board damage and replacement of the blown circuit traces.
You can find HCA2400 power amp module replacements for about $175 online.
Use of the unit as an unpowered mixer is a bit dangerous as if arc re-establishes it can fry the power supply taking out two very expensive IGBT's and many other components. If the mixer still works, then your whole power supply is still OK.
Sep 09, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Just got a used Snap on Plasma25. Put new Tip and elctode in it. Worked great for a few cuts then the Red Light on front of the machine came on and now wont do anything?? I dont have the manual so I dont...
I am not familiar with the guts of a snap on 25 amp plasma, but i have extensive experiance repairing inverter based cutters. 2 common problems which would cause this type of malfunction is the thermal protection circuitry, and mosfet failure. The first is easier to check and is the likely culprit. If the unit is Mosfet based, and i suspect it is, located on the aluminum heat sink the mosfets are mounted to, is a button sized device with 2 wires coming out of it. This is a normally closed switch with bi-metallic contact points inside. When it gets hot, the switch opens, and shuts down the output of the machine untill it cools off again. Many times, these arms dont quite return to their normal closed position if you exceed the duty cycle often. unplug the wires from this switch and check for continuity, if its open, you can temporarily bypass this by running a jumper across the terminals on the switch. If this gets your machine running, i advise you to replace the switch, dont operate it with the jumper in place...... If this isnt the problem, the feed back circuitry driving the mosfets is more than likely detecting a shorted mosfet. A 25 amp machine may have 9 mosfets, paired off in sets of 3, which handle abt 3 amps apiece.....chances are all 3 would have blown if there was a failure, check for obvious damage, a blown mosfet in most instances can be detected visually as 9 times out of 10, they explode..lol...hope this helps, good luck
Jan 10, 2010 | Miller Spectrum 375 Cutmate Plasma Cutter...
Unit blows the fuse on power up. This happened after it was working fine at low level, next power up the fuse blows. Checked large 5600uf caps are ok, removed the four 0N05HD MOSFETS and fuse does not...
Hiya try
http://www.icpowerx.com for the Mosfets, you will probably need to replace driver transistors also (not always but sometimes they go). Also check the resistors to output, they will be the big white ones.
Go here to read on testing FETs
http://www.4qdtec.com/mostest.html
Just to be sure. If one is blown, replace all
Jul 15, 2009 | Sony XM-754HX Car Audio Amplifier
2000 Mazda MPV radio is "dead"
try pulling all the fuses one at a time and see if any others are blown. if so replace.
Jun 23, 2009 | 2005 Mazda MPV
Blown channel
Its possible to repair, but you have to crack the amp open and prod around a bit. I found that the failure is usually in the power components or the MOSFET drivers. If you have 1 channel out, I would focus on the MOSFETS (if you dont know what they look like just Google MOSFET - they are the black 3-legged chips and are usually mounted to aluminum to disperse the heat). Some things to look for:
- burnt / melted solder traces (where the MOSFETS connect to the main board)
- disconnected leads (same place as above).
If you find any connection that looks suspicious, it wont hurt to re-melt the solder around the joint to make sure its a good connection.
Hope that helps...
May 08, 2009 | Car Audio & Video
Blown something found the problem just need to solve it !
Those black things are likely the MOSFET transistors (the bits that provide the amplification). They likely look similar to these.
Your problem may be deeper than just these units being blown - especially since there are 6 that are gone. Have you been overdriving the amp? Using speakers with the wrong impedence?
Anyway, you can try www.user-manuals.com to see if they have the service manual. You could also try to source new mosfets from online retailers (eg digikey, www.sayal.com) - just read the numbers printed on them. You may also want to try to determine why they blew in the first place. I have fixed amps where one or two have gone bad because of being overdriven, but 6 makes me think that something else is wrong. Unless the am has a number of MOSFETs serving each channel. Eg, 3 MOSFETS per channel on a 2 channel amp..
Apr 22, 2009 | Kenwood KAC-8104D Car Audio Amplifier
Blown mosfet
Hello dancisbrown,
If you or someone you know is relatively skilled at soldering, you should be able to replace the MOSFET. The problem may be in determining a suitable replacement. First get the data off of the blown component and then go here to the MOSFET cross-reference guide. http://clivetec.superihost.com/MOSFETs.htm
After you have found a replacement, go here to purchase the new one. http://www.mouser.com/
You might want to consider replacing all 4 while you have the board out.
Hope this helps.
Apr 14, 2009 | Kenwood KAC- X810D Car Audio Amplifier
Audiobahn A6004T Amp Blown PLEASE HELP!!
They are most likely a MOSFET type of transistor. If they are in the power supply part of the amp then you will probably need to replace all the MOSFET's in the power supply along with perhaps some gate control resistors for them. They each have their own resistors. It wouldn't hurt to see if the 494 IC in the power supply is working properly too. This IC is what sends the pulse width modulated square wave to the MOSFET's. Next you will want to test all the MOSFET's that are used as the audio output drivers and their predrivers and bias resistors. Don't forget to check the DC bias and offset on the outputs too, to make sure everything is OK there. In short, you will most likely need to go to a repair shop that can do all this and who would know what the heck I'm talking about. Good luck.
Mar 05, 2007 | AudioBahn A4004T Car Audio Amplifier
Fisher and Paykel GWL11 Top Load Washer Logo
52 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
