Question about DeLonghi Kitchen Ranges
Have purchased house with DE60gw multifunction oven - the dials to operate the electric oven have marking wiped off temperature dial and as have no instruction book unable to decide what the markings on the left hand cooking mode dial are ??? can we urchase an operating manual or download somewhere online many thanks for your help in advance Raewyn McCabe
catriver
  • 878 Answers
SOURCE: Oven, Broiler inopperable
Sandwich, is it your bake or broil thats not working? You have two ignitors, one for bake and broil. One of them is your culprit. This is not a hard job. The post header says broil not working so the part number for that is WB13K0003. Bake ignitor is WB13K0004. To get at the bake ignitor you have to remove the oven bottom inside panel, remove the flame spreader (both easy). The click you are hearing is the board relay sending power to the ignitor. The ignitor has to draw so many amps to open the gas valve. The oven is pilotless. Catriver..post back.
Posted on Apr 21, 2007
informatica
  • 1114 Answers
SOURCE: Indesit KP9508EXG - no markings on the controls!!
Your model number can usually be found on a white or silver rating plate located somewhere on the product, usually the base, rear. Instruction books can be downloaded from the following link: http://www.indesitservice.co.uk/hs/pages/manual/manualSearch.do
Posted on Jul 28, 2007
aborcass
  • 2651 Answers
SOURCE: How do I turn on my oven
look closely at ht e 2 dials push to stop cook manually.that s where theproblem lies. you need to set it for MANUAL cooking probably requires turning one knob till it pops out.its probalby set for timed cooking.Its usally labeled around the clock face in real small print "push in for manual operation"
Posted on Mar 22, 2008
SOURCE: too hot temprature is incorrect
yes, in the senter of the shaft of the oven knob.
Posted on Dec 06, 2008
  • 42 Answers
SOURCE: my viking electric oven does not have accurate temperature
how bad is the temp off?
Posted on Dec 21, 2008
Ariston tc720 dials have rubbed off
We had the same problem when our cleaner rubbed off the markings. Ariston "customer services" were very unhelpful (the model is now so old they don't offer any replacement facias for it) but managed to get replacement stickers from Mark at
http://www.ovenlettering.co.uk/. They come with a diagram for all four dials showing where they should go and are very easy to apply. Would highly recommend.
Jan 19, 2014 | Ariston Technologies Ariston FO98P...
The lowest setting on the dial of our Imperial oven is 175 degrees F. If we set the dial below the 175 mark, could we get the oven to level out at a lower temperature? We're looking to achieve a stable...
The temperature figures on the dial are a guide only. Play with the dial, you will pick up where the thermostat cuts in and out. 130 deg. is rather low, but it could be achievable. You will only find out through experimentation - nothing will be damaged.
Jan 31, 2011 | Imperial ICV-1 Turbo-Flow Single Oven
I have a farberware convention turbo-oven model 460 serial number 2336445 I can only read the first two temperatures on the dial [150*- 250*] I am guessing that 350*- 450* is that correct ? , is that...
The top temperature is actually 475 (which is 550 in a regular oven). That's with the dial turned as far as it goes to the left. Don't know how you'll figure out the settings for the temperatures above 350, unless you measure the intervals below 350 and mark them off on the other side some way.
Here's a picture of the dial on my oven:
Oct 08, 2010 | Farberware T490C 1500 Watts Toaster Oven...
Dials of our smeg oven have rubbed off
You need to disclose the model for any help.
Mar 06, 2017 | Smeg Ovens
New World E70DOA - Oven/Grill Temperature
Steve, I have a PDF of the manual. send me an email to david.stevens@vibanalysis.co.uk and I will reply with document attached.. We recentley moved house and were in the same situation. We contacted Newworld who sent us a paper copy which I have scanned to PDF.
Dave
Apr 27, 2008 | New World E70DOa Electric Double Oven
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Kitchen Ranges Logo
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Vitaliy Gins
Vitaliy Gins
Paul Bade
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
