Question about Microwave Ovens
I have a Panasonic NN-C2003S microwave/convection oven that won't heat anything under micropower mode and on countdown cuts out when it gets to 8 sec. It is working on the convection mode. Could someone please help me? thank you
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
This is a job for a professional.
Hope that helps.
Posted on Jan 04, 2011
Microwave model no.NN-C2003S beep sound has become low.Please provide remedy
Try a reset by:
- unplugging power for a minute
- plugging it back in
- setting the clock
- trying it again
If that does not fix it, see your owner's manual to see if it can be adjusted (usually not).
If you still have trouble, you should call for service.
Jan 08, 2013 | Microwave Ovens
I have a Panasonci NN-SD686S and after a power cut last night, the microwave is now in demo mode. After power cuts previously this has never happened, and I can't find anything in my manual to...
To set Demonstration Mode: press micro power once, then press Stop/Cancel 4 times. To cancel Demonstration Mode press Micro power once, then press Stop/Cancel 4 times.
Sep 09, 2011 | Panasonic NN-C994S Convection/Microwave...
Inside the NN-C2003S microwave on the right hand side is a paper like material that has deteriorated (90 mm long and 30mm high) and exposed an opening. Where can I buy a replacement cover or can I use...
It's made of milar from memory. 4 years ago I needed a new one as well as a magnetron and the ceramic tray, and even though I live in Sydney, LCS Electronics in Western Australia were by far the cheapest for the parts. Back then I think the milar was around $8.
Apr 01, 2011 | Panasonic NN-T888S Convection/Microwave...
My Panason NN-C994S is on demo mode and I am unable to switch it back? Do you have instructions to convert back to cooking mode. Thank you
If you go to the Panasonic site you can download the manual.
www2.panasonic.com/consumer-electronics/.../model.NN-C994S
Regards
Alan Hood
ami-man
UK
Apr 05, 2010 | Panasonic NN-C994S Convection/Microwave...
Countdown through oven's Power Levels
Check that particular outlet for a neutral ground
May 29, 2009 | Panasonic Microwave Ovens
The microwave works for only 8-9 seconds, then stops
It may be in demo mode.  On some units if you hit the timer/clock button 4 times to turn demo off.
Feb 02, 2009 | Panasonic NN-C994S Convection/Microwave...
Microwave not working but oven and grill do
Test the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Dec 17, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave light door turn table works but does not heat up food
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 01, 2008 | Panasonic NN-C980 Convection/Microwave...
Microwave Ovens Logo
468 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
