Question about LG Flatron L1951S 19" LCD Flat Panel Monitor
I got on the screen following text : out of range 89.5 khz / 60 Hz.
  • 11,361 Answers
Your PC video resolution is too high for this display to work. it should be set to the native resolution for best pictures: 1280 x 1024 @60Hz.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 04, 2011
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Sep 10, 2014 | Envision Peripherals 22"" envision e218c1...
Out of range 64.0 KHz / 60 HZ
It might be because of wrong screen resolution. This problem can occur because of hardware as well as software change.
To rectify this issue you will have to set your screen resolution to lowest visual settings. For this purpose you can try restarting your PC to safe mode and then modify your screen resolution.
Sometimes setting your monitor to factory defaults can also rectify this issue.
You can view http://www.techyv.com/questions/why-do-i-get-out-range-message-my-monitor for more information.
I hope this would be of some help.
Feb 05, 2012 | LG Flatron L1515S 15" LCD Monitor
When i try to change to res it says out of range. it stays at 800 x 600.
Max Sync Rate (V x H) 76 Hz x 83 KHz
Max Resolution 1280 x 1024 / 60 Hz
Try changing the Hz to get it to accept a higher res.
Dec 02, 2010 | HP vp17 Monitor
I am trying to find the output power, watts?
bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
Jun 08, 2010 | Audio Players & Recorders
Out of range 64.0 kHz / 60 Hz
Unfortunately if you cannot get the resolution down, you cannot use it.
Jun 18, 2017 | LG Flatron L1515S 15" LCD Monitor
I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Jan 05, 2010 | KDS Computers & Internet
SCREEN SAYS OUT OF RANGE
I assume that you are using a DVI to VGA connection since this TV dose not have a DVI connection.
Make sure that the resolution are set to the following supported resolution:
1280 x 1024 @ 60 Hz
1024 x 768 @ 60, 75 Hz
800 x 600 @ 60, 75 Hz
640 x 480 @ 60, 75 Hz
Or just make sure its set to 1366x768 @ 60Hz
May 13, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Relisys Monitor model TL528A - Plug it in, screen is blank panel light is yellow. push ON button and I get a 5 second message stating: OUT OF RANGE HS: 53.5 KHz VS: 84.8 HZ WORK RANGE ...
It normally means that you have connected the monitor to a computer whose resolution and frequency are beyond the range that this monitor are capable of.
To fix this, you can do one of two things: reconnect the old monitor and reduce the resolution to 800 by 600, which every monitor can handle and then reconnect the new monitor and change the resolution settings again. by default, Windows will restrict you to only settings that the monitor can handle. The second option would be to start your computer in safe mode (F8, just before you get the windows screen during boot). and change you monitor settings that way, rebooting afterwards.
Jul 10, 2008 | Computers & Internet
A_turkovsky@yahoo.com
ya u enable vga mode hit f8 at start up in xp select vga mode ok resets u then use 60 hertz man and its native res ok only update drivers ect mark me ask fit ya ok thx nick
Feb 08, 2008 | ViewSonic VX1935wm LCD Monitor
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
LG Flatron L1951S 19" LCD Flat Panel Monitor Logo
119 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
