Question about GTCO InterWrite SchoolBoard 1077 (SB1077TVU12)
I need to know the best distance for setting up a projector for use with a GTCO interactive whiteboard.
What's the feature of an interactive whiteboard
Interactive whiteboards are mainly used to improve quality of the education in classrooms. The use of interactive whiteboard allows instructor to alter the different information present in the board which can even be copied and transferred to the next slide. The data that is present in the board can be clicked on, moved, copied and analyzed. The interactive whiteboard also allows the teacher to write like the any other whiteboard but it also turns the handwritten notes into texts which can be later referred to at any moment of urgency.
Please read the following tutorial to know some features of interactive whiteboards.
https://www.eztalks.com/whiteboard/features-of-interactive-whiteboard.html
Jun 07, 2017 | The Computers & Internet
Panasonic interactive whiteboard won't project computer
If you'd like to email me at bruce.brassington@n-vest.co.uk I'll be able to help you in more detail. There's a fundamental error to the question here. That is the board in itself will not show the image - your boards is effectively a large flat mouse. A pointing device infact. The peice of equipment that "shows" your PC image is actually the projector. There could be several reasons why your projector isn't showing the image.
1 - is there either a VGA or HDMI cable connected from your laptop/PC to the projector (Sometimes via a wall plate).
2 If 1 is true and the projector is turned on does it show any sort of image? Now there are two thongs you can do from here. a) If you have a laptop check to see if your Video settings are set to clone across to a secondary monitor on most laptops you should hold down Function key and F8 this will toggle through three options Onboard screen remote screen and then both. there could be some lag between the two so hold down fucntio at the same time press F8 then wait a few seconds then go again.
Finally on you projector remote there may be an auto search buttion which will hunt for your PC image by checking each of the Projector inputs in turn. Generally speaking however you should select "Computer 1" or sometimes named as RGB 1
Hope that helps email me if your still having problems.
Aug 21, 2012 | Panasonic Panaboard Ub-T880 Interactive...
Adjust size of display on interactive whiteboard we are using a projector and a smartboard and can't get the same display on the smartboard as we have on the computer monitor - we want a better fit. If we...
if you have no zooom and only a digital zoom this wont work so you need a longer vga cable and if you have mounted it you need longer wires and to take your projector further back.
Jan 15, 2010 | Toshiba TLP S30 Multimedia Projector
Compressed air Vs vacuum cleaner for filters?
don't clean with compressed air, you will contaminate the air you breathe. I just bought a small ShopVac with an 18-foot hose to clean exactly what you're describing
Feb 21, 2009 | NEC VT470 Multimedia Projector
Connecting to laptop
Try changing the refresh rate on your graphics drivers to 60 or 70 hz on both your laptop screen and the projector. Do this at the desired resolutions as well.
Aug 07, 2008 | Acer PD523 Multimedia Projector
Sanyo PLC-SW30
The filters are starting to show their age. This is a normal occurance for projectors and is the result of heat. The filters and/or the mirrors might need to be changed.
Dan
May 08, 2008 | Sanyo PLC-SW30 Multimedia Projector
Colour
ok this problem occurs mostly due to the loose connection in the VGA cable between the pc and the projector..
try changing the cable to give any other input and see it and then confirm it... that the color sensor of the projector is weak...
Mar 10, 2008 | Office Equipment & Supplies
GTCO InterWrite SchoolBoard 1077 (SB1077TVU12) Logo
Top GTCO Computers & Internet Experts
William F. Bryant Jr
Level 1 Expert
Ciricuario Dh
Level 1 Expert
Are you a GTCO Computer and Internet Expert? Answer questions, earn points and help others
