Question about Sony Cyber-shot DSC-W80 Digital Camera
I have a problem error E:62:11 show in display
  • Sony Master
  • 2,517 Answers
HI there
Posted on Jan 04, 2011
  • RAJDEEP DUTTA
    RAJDEEP DUTTA Jan 04, 2011
    Hi there please follow the steps and let me know the result.
    1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
    2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
    3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
    4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
    5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
    Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
    back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
    in not done the press both Menu & self time key for 2 - 4 sec.
    i hope it will gives you success.
HP LASERJET MFP 1005 HAVE SHOWS ON DISPLAY ERROR B0601
head to this site there are instructions on how to fix it
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01687323-5
Oct 27, 2015 | HP Office Equipment & Supplies
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
My printer canon 4412 not work the display showing on main switch e202-0002
hi my printer canon mf 4412 printer is not working it is showing error batten red light showing , display is not showing pls solve problem pls it is urgent
Apr 05, 2011 | Office Equipment & Supplies
My Copise Xerox work center pro 423 are showing on display this error (U4-2) how i can clear this error please please tell me any body if knows
my copise xerox work center pro 423 are showing on display this error (u4-6 @ reboot) how i can clear this error please tell me
Mar 18, 2011 | Xerox WorkCentre Pro 423 Copier
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
When powered on it displays error C -6 blinking, then it displays 000.
press 1087 1087 the display will show U000 the press 163 and press start , display shows CLE press start again the error will be cleared
Aug 06, 2010 | Kyocera Copystar CS-1635 Copier
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Error message HO2 shows on vhs display
the player begins to read dvd. display will read 00---READ and it repeats this process a few times and the error then is displayed next.
Jul 10, 2008 | Panasonic Televison & Video
Sony Cyber-shot  DSC-W80 Digital Camera Logo
289 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
