Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Evaporator Motor & Fan
I have a Whirlpool refrigerator model# EHT-201Zk, and I believe the evaporator motor is going. It is making a loud noise in the freezer area. It is still cold but just this noise keep coming off and on.
Is this something that I can replace, having no experience, or do I need to call someone. Please advise. Thanks.
  • 1 more comment
  • vdavids4 Jul 12, 2008
    I have a crosley side by side fridge. I think Maytag made it about 1987. I just had the evaporator fan motor replaced at a cost of $200. Had a big storm yesterday, lost power for about 2 hours but didn't open the freezer, and now the ice maker is not working again. That was the problem before when they replaced the fan motor. What is up? Can I fix this by defrosing the freezer as above? Thanks
  • Anonymous Aug 08, 2008
    I have that same exact model with the same problem. The fan squeaks and the door seal is starting to go on the bottom. Anyone know where I can find a door seal? Has anyone verified the solution to the squeaking problem?
  • ckr_44 Mar 19, 2009
    Wheeling squealing intermittent noise - stops when hit or kicked.
    I remember having the same problem before and it went away on it's own..? This time it's VERY persistent. It will also shut off if temp control is shut off, and sometimes air control. I can turn it immediately back on and the noise will be gone for awhile.
    My post is connected to the person who talked abt their Whirlpool frig....I have same model.
  • 417 Answers
you can try to completely defrost the fridge by unplugging it for a day and put you groceries in another fridge, sometime ice dams build up in those and freeze next to the fan blades and cause alot of noise, if its squealing, then its the motor for sure, evaporator motors are usually pretty easy to replace once you study where its at, usually the whole top or bottom and back of freezer has to come out then the motor and fan are right there, keep the fan blade assembly because you put that on the new motor, be extremely careful once you have the bottom and sides out because the coils will be vulnerable to anything if you hit them go to www.sears.com and go to parts area, theres a sears repair store in our town , hopefully in yours or just call around, dont forget to unplug it! hope that helps
J
Posted on Jul 10, 2008
  • Alec Hidell
    Alec Hidell May 21, 2011
    I've always found it better to take the time to find out FOR SURE where the problem is, in this case, where the noise is coming from. This is NOT the kind of problem you want to procrastinate too long with, since if the motor freezes up or fails in some other way, you stand a good chance to lse a freezer full of food. This fan also effects the cooling in the refrigerator section of the appliance.
    Empty as much of the freezer's contents into the refrigerator, and the rest into coolers, etc. Take out the shelves and drawers, and if the fan in question is in the back, you might find it makes it easier if you take the freezer door off; many Kenmore freezers have the top door hinge held on by three screws, and once they are removed, you can lift the door up and remove it easily.
    Once this stuff is out of the way, isolate the source of the noise. MOST LIKELY it will be inside the freezer, in back, behind some covers. Once you know where the noise is coming from, UNPLUG the refrigerator, and remove the covers to expose the fan. Once you can SEE the motor, use some light machine oil, preferably Kroil or WD40 in a spray can with a tube so you can direct a spray of oil to both bearings. Give both bearings some lubrication; (don't saturate the motor, as these lubricants can smell up the freezer, and your food.)
    While the motor is exposed, make note of what's holding it in place (screws, etc) and how it's connected electrically (pull off terminals, "scotch locks" wirenuts, or crimped wirelugs). This information will be helpful in assembling the tools and parts you'll need to REPLACE the motor if the lubrication doesn't solve the problem. Note* if the wires DON'T have reusable connectors, be prepared to cut off the crimped lugs and replace them with scotch locks. If you do this, cut off only as much wire as is necessary, as the manufacturer doesn't use extra length wire. Now, while the covers are off, plug the refrigerator back in and see if the noise is gone or has changed. If it has changed for the better, give it a LITTLE more lubrication. If the noise is gone altogether, save your notes, and (after unplugging the refrigerator again) put the covers, drawers and shelves back in, put your food back in, plug the appliance back in, and see what happens.
    If the noise comes back, or didn't go away, get the model number of your appliance off the tag (usually inside one of the doors) and order a new evaporator fan motor. If the noise went away and STAYS away, put your notes into the folder with your owner's manual, just in case it comes back. Meanwhile, you've saved about $50.00 on a motor.
    Tools needed to REPLACE the motor; the same tools you needed to remove the covers and door, PLUS a 4 way screwdriver, 1/4" drive socket set, wire cutter/stripper, Flashlight, (preferably the kind you can strap to your forehead while working,) scotchlock wirenuts, roll of electrical tape (use this to run one wrap around each scotchlock to hold the wirenut to the wire, and keep moisture out.)
    Good Luck!
My whirlpool freezer model # eh225fxtq01 makeing loud noise
Is this loud noise coming from inside or under the freezer? Inside usually means the evaporator fan needs lubrication or replacement. If it's under then look at the condenser motor for the same reasons.
Feb 18, 2017 | Whirlpool Refrigerators
My whirlpool side by side fridge/freezer is making a loud noise while running.
If the noise is coming from inside, the evaporator fan motor (the fan motor that circulates cool air located in the freezer section) may be the culprit. If noise is on the outside, the condenser fan motor may be the problem. This is the fan motor that removes the heat from the refrigerator to the room.
Jun 14, 2015 | Whirlpool Refrigerators
Samsung rm255lash, evaporator fan motor on refrigerator side making loud noise. We took off the panels as best we could but it seemed like it was frozen on. When I open the fridge and hold down the light...
i quick fix would be to take a quart of oil and remove the fan motor and soak it in the oil. This wont hurt it anter a couple of min in the oil, hang up so that all the oil can drain off it, then wipe it down. install motor and try again, let me know.
Feb 21, 2011 | Samsung RM255LASH Side by Side...
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
NEW HIGH SPEED EVAPORATOR FAN MOTOR TOO LOUD Repair technician told me there were problems with the original evaporator motor and replaced it with a new high speed one. Now the fridge is too loud. Before...
It's the rotors making the noise not the motors! I replaced the motor, still made noise, I took off rotor blade sanded it down around each blade, no more high pitched hum!
Jan 12, 2010 | Frigidaire FRS26H5AS Side by Side...
Whirlpool model ED5FHAXSLOO refrig 3 years old very noisy
If it is cooing fine, then the noise is probably your evaporator fan (the one inside your freezer). This can be cause by one of several things. The motor on this fan may be going bad, or, more likely, you may have a build up of ice around the blades that are touching the fan. This may be caused by a defrost circuit that has gone bad, or, the freezer may have been open alot lately and there is an excess of frost that hasn't melted away yet. If you can, manually defrost the freezer and see if it goes away. If it doesn't, it's probably the fan motor. If it does, and then comes back, it's probably the defrost circuit. Hope this helps!
Dec 06, 2009 | Whirlpool ED5FHEXMQ Side by Side...
I have a HotPoint side by side refrigerator. Model # CSX22GAS, my ice is melting and in the freezer section there is a loud noise. as if the motor is running hard.
Below is a link courtesy of www.repairclinic.com, that shows the evaporator fan blade. This may have come loose from the fan motor shaft and may be striking the fan shroud or rattling on the motor shaft
A loose fan blade cause elevated temps. If the fan blade is loose, replace it, not repair it, to avoid further problems.
1. Evaporator Fan Blade:
http://www.repairclinic.com/SSPartDetail.aspx?s=t-CSX22GAS-%3d%3di2611&PartID=2611
2. Evaporator Fan Location: Mouse over parts for illustration.
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
Aug 13, 2009 | Hotpoint Refrigerators
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
Whirpool Refrigerator Making Loud Noise
I have the same problem. 3 years old fridge. Under warranty?
Aug 08, 2008 | Whirlpool GC5SHEXNS Side by Side...
Noise
I believe you will trace this noise back to the evaporator fan motor inside the freezer making the noise. If you agree that the noise is coming from the evaporator fan motor inside the freezer it is not the motor that is responsible. Your model has a Main Mother Board on the outside rear wall of the freezer down low (about 10 screws hold square cover on over board). The Main Board is causing your noisy evaporator fan motor. Use caution when handling any electronic circuit board. Follow antistatic cautions. Static electricity in your body can damage these valuable circuit boards.
Nov 10, 2007 | Hotpoint HSS25GFP Side by Side...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
578 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
