Question about Samsung SCX 4521F All-In-One Laser Printer
This problem is I am open samsung mechine and clean after fied any part but I can go start photocapy but not work this problem is [front or rear] [cover open] plase help to me how to slove in this problem
  • 360 Answers
Hello your front door is didnt close properly.some time your toner cartridge didnt install properly. try it again
Posted on Jan 08, 2011
I have a samsung front load washer and the fabric softner is not being released. How do I fix it
clean soap drawer with bleach put mech on final rince prog no clothes in mechine and let it go through rince program
Mar 02, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
The door will not open after the washing cycle is complete.I think the door catch is broken now do you go about replacing or fixing this?
u have to remove the front of door boot ie rubber seal from front of mechine 2 screws where the catch goes in holds the interlock 2 mechine remove wireing 3 wires or plug depends if three wires take note of wher the go replace interlock easy.
Feb 15, 2015 | Whirlpool LHW0050PQ Front Load Washer
Samsung VRT with a DS or D5 code? Door closes but won't lock
bad door lock switch mechinism or the control board is bad at the emergency door lock circuit? where the wires from the door swtich attache, check ur schematic and will need a multimeter
Dec 18, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
How i have to put the piston lube in titan impact 400?
There is a small opening on the front of the mechine has a little lip put 5 or 6 drops in.
Titan mechines don't have poly and leather packings its plastic and reopream O rings so it dosn't need as much throught oil as say a Graco mechine .
But I do like to run a little marvails mistery oil through after cleaning the mechine espeiclly if you are going to store for a while .
You see I use my mechines all of the time .And the biggest problem is people don't clean them correctly .It takes 1/2 an hour to clean any spray pump up and thats with latex oil paint take much longer .
Never under estmaite thats good enough because its not .
May 18, 2014 | Titan Spraytech Piston Lube Piston...
Samsung washing machine nf Error code
Here is the best troubleshooting manual i've ever seen. It's PDF:
http://downloadcenter.samsung.com/content/UM/201106/20110628141933509/WF350AN-Tech-02834A-02.pdf
I found it here:
https://www.samsung.com/us/support/owners/product/WF350ANP/XAA
NOTE: If water is not entering tub, you almost certainly need to replace the water valve. If water is entering tub but won't fill your drain pump is suspect. Hope this helps.
Dec 30, 2012 | Samsung WF350ANP Front Load Tumble
Samsung wt8202
Were did i get the front pannel in blue colour because my washing mechine wt 8202 drain knob is not working .Technician says change the front pannel board white colour is awailable but blue is not get yet.
Apr 05, 2012 | Samsung Washing Machines
I have a samsung 7Kg J845 front load washing mechine, when i turn on, water not fills enough ( only water fills couple of seconds after stops flows. the error shows 4E, Then i clean up all mesh filters...
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 08, 2010 | Samsung WF203ANW Front Load Washer
Paper jam --samsung SCX-4828FN
i found that paper jam was in the middle of the mechine. i opened the front door and removed papers.
Sep 17, 2009 | Samsung SCX-4828FN All-In-One Laser...
Samsung SCX 4521F All-In-One Laser Printer Logo
206 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
