Question about Whirlpool 5' Jacuzzi Tub Bathtub Cetra 532 H525-969
Jacuzzi had not worked for about 2 years. I took the door off to check for moisture and I noticed the air switch was disconnected. I replaced the switch and the motor ran for about 2 seconds and stopped. Will not restart.
  • US Parts Center
    US Parts Center Jan 12, 2011
    What did you connect back up? the air tubing or a couple of wires to the air switch in the motor?
  • Whirlpool Master
  • 717 Answers
Sounds like the air switch didn't latch. you may need a new air switch in the motor to make it work again.
the way to check this is to remove the pump. plug it into an outlet and take a straw and blow into the air switch on the motor. if you can get it to come on then the air button is bad on the top of the bathtub. if it will not come on/off then the air switch is bad on the motor.
Posted on Jan 13, 2011
Need indicator rings for 3 controls on U640959 Jacuzzi bathtub. These are flat rings 1.5" ID, 2" OD. The two for the air have 5 circles. Also need the on-off ring.
Good luck Scott Jones...
I've been looking for some specifics on Jacuzzi (seacrest) faucets... for a couple of years...
Since before Jacuzzi moved out of the EAST-BAY area (here) they had pretty good stuff.
I have their "washerless" ceramic faucets..
Through trial & error I've been able to keep these working...
No thanks to the so called "Jacuzzi" (moved out of CALIFORNIA).
Not only were they not helpful when I told them I didn't want their NEW STUFF...
I only wanted to service what I've had for 30 years
(controls sound like what you have)
Try calling these folks... At least they know what JACUZZI used to mean... GOOD STUFF:
Jacuzzi of El Cerrito ... (510-) 527-5547
5327 Jacuzzi St Ste 2c,
Richmond, CA 94804
Toll FREE... Call 888-738-5523
Hope this helps.
Hot Tubs Swim Spas Saunas in California Sales Service Paradise Valley Spas
Jacuzzi Whirlpool Bath JWB 1 2 Air Volume Control Elbow PA54000 U775000...
Dec 05, 2016 | Jacuzzi Home
I have a Capella 55 with a jacuzzi pump 595 H2O. The tub or motor hasn't been used in over a year. I checked plug outlet and it is working fine. All I get when I try to turn it on is a small short cli
Does this turn on and off with an air button or is it an electric button?
If it is an air button (as it sounds like to me) then it is most likely to be the air switch inside the box on the motor.
You should change the air switch in the motor. The cost of a latching air switch is around $21
Rod
US Parts Center
Mar 15, 2014 | Jacuzzi 9590 Comfort Bath Capella 55...
Hytec Kohler Model LM34520 air jet swtich not working. 4 years old and last use, the push button stopped working. Cannot see connection detail at switch/button end but disconnected at motor and and can...
The problem you are experiencing tells me that the air switch in the motor most likely the problem.
This is a latching air switch that operates when the button on the side of the tub is pushed.
The replacement TBS-339 air switch is around $21
Rod
US Parts Center
Jan 06, 2013 | Jacuzzi Home
I have Jacuzzi whirpool, and used for 10 years. now even push air switch to blow air through jets, but they do not work. What parts or where I should check it up to find anything wrong ??
The tubing is most likely swollen and loose or even fallen off the bottom of the air switch or off of the back of blower motor. Time to replace tubing.
Aug 31, 2011 | Home
Microwave turns on but won't heat. it appears to be working normally but does not heat. It 2 yrs old
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Jul 06, 2011 | Microwave Ovens
Microwave stopped nothing works. fuse and outlet are OK. No light, no bell no power. Repair location? Berlin Germany Initial cost 4 1/2 years ago 70 euro. Is it worth repairing?
Make sure that the program controller is working if not check the door switches, if contact is not through the microwave will not work.
Apr 23, 2011 | Microwave Ovens
My microwave just died this morning. Not a fuse, not the plug. It's only about 1 year old. Any suggestions?
Apr 05, 2011 | Maytag MMV4203D Microwave Oven
Old Jacuzzi Vectra (86), not cycling!
Keep giving it a few kicks! When that happens to motors it usually means that it is on its way out, I'd milk it for as long as possible but start thinking about a new pump and motor.
Aug 03, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
My brand new jacuzzi bathtub motor just clicks and will not run when i push the button, whether it has water in it or not.
check 2 things......1) see that the power is connected and that the breaker is on.......2) if everything from 1 is a yes check the hose that runs from the switch to the motor it may be lose, disconnected or has a hole in it. If you have anymore questions just ask. I am a professional plumber for over 25 years
Jul 30, 2009 | Jacuzzi Bellavista 6 Whirlpool w/2-Speed...
Whirlpool 5' Jacuzzi  Tub Bathtub Cetra 532 H525-969 Logo
475 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
