Question about Maytag Washing Machines
Our maytag alantis (mav7650aww) makes a squeeling noise when it stops during cycles. How do I remove the front body panel to check it out? Thanks.
  • Anonymous Mar 30, 2014
    how to remove agatetor
  • 246 Answers
To open the front panel there are 2 green clips between the top of the unit and the front panel. (you can use a flash light to find them easier). Push on the with a putty knife or small flat head
screw driver while lifting on the top. Once the top is open, you will find 2 5/16 screws that hold the front panel on at the top on the right and left hand sides. Once these are removed, you can tilt the front panel forward and remove it.
However, the most common source for this squeek is a bad brake. You would need a specialty tool to remove it. If you go down to your local appliance parts store, bring your model number (located on the back top of the console). Ask them for a brake, stator, spring for that model and a maytag spring compressor. To replace it, first pull the unit forward and lean the top backwards to about a 45 degree angle (or until it will stay leaning against the wall behind it). Now pull your belt off from the bottom. It will come off the pulleys fairly easily. Next remove the cap on the bottom of the large pulley. Underneath you will see a clip on the very bottom. Work it off with a small flat head screw driver. Now place another screw driver on the bottom of the haft in the middle and let the parts fall down on top of it so they will stay in the proper order. Make sure to use your small flat head to make sure all of the washers have come off. Now, install your brake tool. (the directions come with it) but basically, you remove the pin, loosen the nut, slide the tool over the shaft, re-install the clip and tighten the nut back down until the tub turns freely. Next remove the 6 black 5/16" screws that are on the brake. Once you remove those, loosen the nut once more on your brake tool. Once it is loose enough, remove the clip on your brake tool. Reach up and tilt your tub slightly towards the front. This will let your stator, brake and spring all come out. Remove the cap from the top of the spring you just took out. Add it to the new brake spring and stator and reverse the process. The squeek goes away. Still having troubles? Drop me a note back
Posted on Jul 09, 2008
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune makes loud drums like sound 5 min before it stops.
its probably because of the way the clothes are in it. you have to make sure the clothes arent leaning to one side and that they are evenly set up. otherwise when it goes into the spin cycle itll lean and hit the side of the washers inside and make it shake and do what you said it was doing.
Jun 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Maytag alantis gas dryer mdg8600awq
HI thE ELEMENT IS LOCATED AT THE FRONT RIGHT SIDE.REMOVE THE FRONT PANEL 2 SCREWS ON FRONT AT BOTTOM REMOVE PANEL THE ELEMENT RIGHT THERE ON RIGHT THANKS FOR THE QUESTION THE APPLIANCE DOC
Sep 07, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Dishwasher
I had this same problem. I think its the upper spray arm vibrating during wash cycle. To verify; prevent the upper arm from rotating by putting a long spatula through the top rack or zip tie the arm so it don't rotate. If the noise goes away you found your problem.
Feb 15, 2007 | Maytag 24 in. MDBH940AWS Built-in...
Washing Machines Logo
396 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
