Question about Samsung SyncMaster 2253LW Monitor
It shows "check signal cable",
  • 312 Answers
Hi, Hopefully you are seeing this error on the screen of your monitor. If that is the case,
do the following steps.
1 Shut down the computer. To do this, without looking at the monitor, hold the on/off button to your computer in for about 5 seconds. The computer should then shut down.
2 Shut off the monitor.
3 Unplug the video signal cable, the thick one that goes between between the computer and the monitor and then re-insert it observing not to bend any pins. There are two end screws that you will have to be loosened, although they may have not been tightened in the first place. When you reinsert the cable, hand tighten those screws.
4 If there is a similar connector on the back of the monitor, repeat step # 3.
5 Make sure that the signal cable is firmly attached to both the computer and the monitor. 5 Turn on the computer and see if it has solved the problem.
If it does not, examine the cable for signs of damage along it's length.
If it is damaged, replace it. you should be able to get a cable for stores like Best Buy, or possible from a friends old stack of cables.
Hope this helps,
Mark
Posted on Jan 04, 2011
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: "check signal cable" problem and
It is telling you that it is not getting the video signal from your PC video card. Did you trythis monitor with another PC yet? This monitor has 3 years warranty so please find out if it is still under warranty first before we open it up to look inside. Are also using DVI to VGA adapter?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
LTFubar
  • 102 Answers
SOURCE: The Hannspree monitor shows start-up
If you have more than one monitor connection it may be outputting the signal to the other connector.
Try booting into safe mode ( tap F8 key untill the menu shows, use the arrow key and enter to select)
if all goes well restart the computer and monitor should work.
Posted on Aug 29, 2011
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Acer x193w Monitor won't come on flashes blue light you see word "Acer" it goes to flashing Yellow light and keeps repeating that.
you disconnect the monitor from PC
& see: it will show no signal or check signal cable. that means the monitor is OK problem is in PC. may be you PC is not booting properly. if monitor does not come on there may be fault in the main board of your monitor.
Oct 13, 2011 | Acer X193W LCD Monitor
The Hannspree monitor shows start-up along with my computer monitor,but once it gets on desktop, the Hannspree monitor says "no signal input check video cable", but all the cables are connected...
Aug 29, 2011 | Hannspree Computers & Internet
S24a300b problem, not detected by pc. message on display say "check signal cable".
Check signal cable means that your monitor wire is not connected properly.
So remove your cable connect it tightly once again.
Tightly connect with cpu and power supply.
Thanks for using fixya
Aug 19, 2011 | Samsung S24A300B Monitor
Why the monitor says "no
because it doesn't receives any signal from the pc - check the video cable. If the cable is correctly plugged in at both ends then the pc is defective - test it starting with the video card.
Jul 01, 2011 | Dell E176FPC Monitor
I have bought a mew computer with a Sansung screem type LS19A300. It was working normaly and then a message "check signal cable" appeared. I checked all cables and nothing. So we changed the new...
Hi, what was the LCD displaying is that he is not sensing any signal from the computer video port that is why it is prompting "check signal cable". Have you tried checking the pins of your video cable from your LCD? if OK please plug in the cable again when your PC is already open to check that signal will pass thru and lets see what happen. If still the same, try to isolate it with laptop as external video if you have to check the LCD will work with other PC. If the same, replace the signal cable of your LCD if it is removable to further check the problem.
Jun 23, 2011 | Samsung SyncMaster 910T 19" LCD Monitor
VX922 only shows "No Signal" on black screen
The monitor shows no signal probably it didnt detect the tower
Ill be advising you to remoev the cable that conencts the cable
used a clean cot or rug clean both ends of the cable , clean also the area whre you plug in the cable , the ports on the monitor and on the CPU make sure its clean .
Then plugged it in , in case nothing happens
try to used another cable that conenct from the monitor to the CPU
you may aslo try to used other CPU to checked if monitor is working fine or try other monitor to checked if the port on the your CPU is working fine
May 23, 2011 | ViewSonic VX922 19" Monitor Flat Panel
How do I fix my hp w17e monitor that reads "VGA no signal"? I've tried unplugging my power cord and holding the on button for 30 seconds to a minute and plugging the power cord back in it still...
VGA no signal means "no signal" from the computer on the VGA (blue plug) cable... ...if the computer works check the cord for loose connection or get a new cord...if the computer is hooked to the digital cable (DVI/white plug)...set the signal source on the monitor to digital...
Feb 14, 2011 | HP w17e Monitor
I got this monitor off of craigslist "because it didn't work". The VGA has never worked, but the DVI worked fine for several months. Recently, the screen goes black, the screen shows a 'no...
Check the VGA output pins on your computer. Install a different monitor and see if it works on your computer. Or it could also be the VGA cable (pins) on the monitor is loose.
Dec 16, 2010 | Neovo E-19A 19" LCD Monitor
Samsung SyncMaster 2253LW  Monitor Logo
286 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
