Question about Hotpoint Ultima WF860 Front Load Washer
My Hotpoint WD860p washing machine purchased about 5 years ago in the UK has developed a fault which has got progressively worse over the last 2 weeks to the point now the machine can't complete a load and shows fault code F-02. Researching the F02 code online indicates a motor jammed or motor tacho fault. Thinking broader than just the F02 code, I removed the belt to confirm the problem wasn't related to bearings or something else. Drum spins freely, and motor without the belt attached "stutters" within 2 minutes of starting a wash cycle. I removed the motor to check the condition of it - found out it is a 3 phase motor, confirmed the tacho is working using a multimeter - have done other meter readings but unsure what I should be looking for - can't find any documentation on the motor pinouts. I found the part number - Hotpoint/Indesit/Ariston part number C00112768, and can source it from ebay UK. I now live in New Zealand, so to get it shipped over will cost more than the motor due to the weight - I am OK with the total cost, if it is definately the motor at that is at fault and not a PCB or some other fault. I videoed the motor running without the belt attached from around the back and have posted it online at I would really appreciate any expert input/opinions regarding if the motor is at fault or something else. I am obviously keen to make a decision about replacing the motor or next steps ASAP as we are without a washing machine right now, and will have about a weeks lead time for parts from the UK. Thanks very much, - Mike
  • mapson88 Jan 08, 2011
    Just took the motor out of the washing machine again to do further testing.
    Using a multimeter, it appears that pins 1 and 2 on the 8 pin connector are shorting within the motor - i.e. no resistance. I can't imagine the motor being designed like that so unless someone advises otherwise I am going to assume this is a fault and replace the motor.
  • mapson88 Mar 26, 2011
    I ended up getting a replacement motor.
    The multimeter test was the same on the replcaement motor, but installing it in the washing machine worked perfectly.
  • 121 Answers
SOURCE: My washing machine has stopped spinning.
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Posted on Mar 03, 2008
SOURCE: Change Bearings for HotPoint WMA62N
Hi, I also have the bearing problem on a hotpoint wma and have just stated the repair job. I have found the following on different forums, so maybe it might help others. You do need to remove the drum and there are two different sizes of bearings 30mm and 35mm. To find the size you need you have to get to the bearings and measure them.
. Ok,Hotpoint wma series drum bearing failure.Firstly very common problem since i work on these things every day-i think there is a design fault-nothing new in this trade!What follows is
the sequence of problems in changing the drum bearings:If the machine has been thrashed into oblivion just changing the oilseal/bearings will have you back to square one within a
couple of months since you would`ve damaged the drum shaft as the bigger bearing of the 2 goes into shapnell mode!So you`d best change the drum shaft(in the trade known as the
spider) however this thing is aluminium usually held onto the the drum via torx headed screws either in steel or soft Al2 also-forget it as your not going to get these out unless your mega
lucky,what we do at work is to replace the whole tank/drum/bearing assembly which comes with a new element and belt ie the whole tank unit,the trade price of this part is less than
£100.00-you can draw your own conclusions as to the retail price as you wish.If you haven`t thrashed the machine you can get away with replacing just the bearings or easier still the rear
half of the tank(trade price 30.00+vat) in which the bearings are already fitted via the factory and reuse the existing spider/drum shaft so long as it isn`t damaged by disintergrated bearing
shapnell.I hope this clears up this problem for you.Please note that this machine`s filter which is at the rear doubles up as the air trap-the oval section 8" long semi transpatent plastic tube
thing-the part that allows the water to compress the air so turning off the level of fill at the right level via the round swt behind the soap dispenser-called the pressure swt-if the filter gets
bunged up the machine o/fills and either overfills or overfills and floods or tries to spin with aload of water still inside the drum or perhaps no spin at all.Hope this helps someone.
The drum comes out through the front on this one. Take off kick plate and remove screws holding front panel to frame. Take out soap drawer & remove screws behind it. Take off band
holding door seal & peel seal back. Remove 2 screws holding door lock &push lock through. Pull control panel forward at left side & slide to right to remove being careful with board &
wiring. Remove screws holding top end of front then lift slightly &remove front. Remove back panel & take wiring off heating element & pump. Disconnect the pump hose at the drum end,
disconnect the hose from the soap dispenser, note that wiring is fastened to the drum at several points and will need to be disconnected. Remove panel from behind control board then
carefully move everything away from the front of the machine, the drum can now be lifted clear.
Forgot to mention unplugging motor but common sense will prevail.
Posted on May 13, 2009
  • 8 Answers
SOURCE: Will complete wash/rinse cycle, start spin and pump out but not speed up
put a full load in it, its telling you that, try 20 shirts, or 10 towels
Posted on May 28, 2009
  • 30 Answers
SOURCE: Hello, I have a Hotpoint
e11 is a pump fault and e30 is a motor fault there is a possible fault with pcb also
Posted on Jun 09, 2009
  • 5 Answers
SOURCE: hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Posted on Sep 17, 2009
How to put in the circuit board on hotpoint aquarius wf440 ?
this may be of some help good luck
otpoint control module configuration for selfix - YouTube
? 9:21
16 Sep 2011 - Uploaded by Selfix UK
Hotpoint control module configuration for selfix ... How to change the display pcb on an Ariston Washing ...
How To Replace A Washing Machine PCB - YouTube
? 4:19
27 Apr 2013 - Uploaded by Selfix UK
How To Replace A Washing Machine PCB ... Repair HotpointWF541 WF540 WF740 with flashing lights ...
Modules & Control Boards ' Washing Machines ' Spare Parts ' Hotpoint
Have you lost complete control of your washing machine? ... If your PCB assembly (printed circuit board) is faulty then replace today for an efficient and effective ...
How to Replace Washing Machine Control Panels - Hotpoint ' eSpares > Home > Advice Centre
8 Jun 2010 - Replacing any of the front panel controls on a washing machine is ... how to replace any of the knobs, buttons, printed circuit boards that sit ...
How to Diagnose Washing Machine Control and Program Problems ... > Home > Advice Centre
14 Nov 2013 - Watch Josh explain how to diagnose washing machine control and program problems. ... If you then suspect that the problem still lies in the circuit board ... to test the board and you'll actually just need to replace it altogether.
Hotpoint WD420 fault ' Page 2 ' DIYnot Forums > Forums > How to... > Appliances
31 Oct 2009 - 15 posts - ‎11 authors
hotpoint aquarius wf530 washing machine flash like Christmas tree when ... After reading this forum I took the PCB board out and the C17 ...
Hotpoint WF540 washing machine board issue - pics included ... > ... > Repairing Electronics
19 Mar 2011 - 14 posts - ‎9 authors
Just took the board out of the washing machine to check the c17 cap ... was gonna cost £150 just for a replacement board without fitting.
Hotpoint - EMW Electronics
This is the Mark 6 board fitted to late Hotpoint washing machines. The module will be programmed to your model number - ready to fit. Typical models are WF550P WF560G .... Hotpoint Arcadia PCB Modules. SKU: 256. Hotpoint Arcadia PCB ...
modules and PCB's for washing machines and washers for Candy ...
Hotpoint SCR, WMA, WMS washing machine pcb control board ... 1200RPM 6 KG 2003 TO CURRENT LINEN), HOTPOINT - WMA58N (AQUARIUS 1400 RPM 6 ...
  1. Hotpoint Appliance Parts‎‎rating for
    Save £5 When You Spend £35 or More! Low Cost and Next Day Delivery.
    Price Match Guarantee · Spend £35 & Save £5
  2. Hotpoint Spares - Delivered Within 24-48 Hours.‎‎Machine Spares
  3. Dishwasher Parts
  4. Cooker Spares
  5. Fridge Spares
  6. Hob Spares
  7. Replacement Circuit Board - Fried the hard drive circuit board?‎‎hotpoint washing machine circuit board
    hotpoint washing machine control board
    washing machine pcb repairs
    hotpoint washing machine pcb problem
    washing machine circuit board replacement
    hotpoint pcb repair
    hotpoint aquarius washing machine circuit board
    circuit board for hotpoint aquarius
1 2 3 4 5 6 7 8 9 10 Next
Nov 22, 2016 | Hotpoint Washing Machines
Door lock mechanism replacement
1) Will follow with reason to get hold of company or person who did prior repair.
2) Not familiar with this one.
3) When people more specific then help is a lot easier.
3a) That being said; Hopefully that you have a fix it warranty.
Large home appliances can pay off.
4) My problem was with a Whirlpool top loader. (The newer type with the 4" high impeller.) Machine made noises and had an error code which couldn't be reset. (Powered machine off/on a coupe of times.) Plus the clothes were always soaked and needed to be hand wrung to dry. Couldn't see why as the lid latch prevented opening to watch progress of cycle. (Development of the newer technology.) Had purchased the washer at Lowes. (And for once the extra warranty. A friend's suggestion.) 14 mos. after new the problem occurred. Called Lowes. A repairman came out and being as he had had repetitive faults he went under the machine and tightened the motor's hub nut which was lock washered. 5 days later the problem re-occurred. Called Lowes. They sent a different repair tech next day. This one did the same repair but added a substance (Loc Tite) before he tightened the nut. Loc Tite goes on as a paste or gel then semi hardens to form a lock washer effect by preventing the nut from backing off. That on top of using a new nut and lockwasher. Repair was done a year ago and is still good.
5) See #1. Call the repair company or tech. Hopefully your repair is less than a year old. Not all repairs or techs are equal!
Jun 28, 2014 | Frigidaire Affinity ATF7000E Front Load...
1 Answer washer is a hotpoint wd860p and I have a fault on it...the code is F-04 which according to the website is the pressure switch jammed would it be easy enough to fix myself or would it need an...
The pressure switch is jammed because the pump filter needs cleaning, the switch itself is not faulty.
You need to locate the filter, remove and clean.
This will solve the prob.
Oct 31, 2010 | Hotpoint Washing Machines
My hotpoint washer/dryer wd860p is spinning on drying cycle but there is no heat. What could this be ? many thanks
the heat coil may be damaged. A few years ago I took apart my dryer and saw that the coil resistance wire (glows red when a current is passed thru it) was broken. I was able to buy the part and put it in and it worked after that. If I had to do it again, I'd just call a repair guy.
Oct 16, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD64 is not spinning or emptying
check the pump, make sure drain hose is not cloghed, ensure the belt is in the place, spin the drum a bit by pulling the belt. then give it a go.
Update me about your progress
Jul 24, 2009 | Hotpoint Aquarius WD640 Front Load...
My GE frontload washer "jumps around" the room.
Plug off the mains. Open up the machine to look for defective shock-absorbers, broken springs, etc. You shd have done this much earlier, surely you're not walking around the house with a helmet.
For spares: (which is good)
Mar 01, 2009 | GE WSXH208A Front Load Washer
Hotpoint WD860P trips rcd within second of being switched on
the usual problem with tripping is the heater of the dryer box has become loose and touching an earth.
if you take the lid off you will see the box on top of the drum.
with the electric off you can look for loose/disconnected wires and wiggle the 2 metal tabs that are the ends of the heater, should not move.
you may be better with an engineer visit if it's not an obvious fault.
Feb 25, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
WF540 - Won't work and rinse hold and wash enhance lights flash?
Hi ya, just a quick suggestion, have you cleaned the filter on the front of your machine?? My machine did this and it was only when i cleaned the fluff and the 5 pence pieces from this filter it stopped, Hope it helps
May 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
He's talking BS, get another opinion.
Oct 06, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
117 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
