Question about Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher
How do I unstop my pump?
How do I unstop my pump on my Maytag. My dishwasher is not draining either
  • Anonymous Jan 20, 2009
    i've seen everything from unhooking the hose to the sink and force air in it to using baking soda and vinegar to try to clean the clog.....
  • 93 Answers
Short of removing it and placing on back. No other way.
Posted on Jul 24, 2008
How do I unstop my dishwasher?
Turn the breaker off for five minutes and the turn back on. Start the dishwasher and see if it will drain. Sometimes power bumps can mess with the control board. Otherwise it could be the control board or the pump.
Apr 24, 2014 | General Electric Dishwashers
Maytag dishwasher won't drain
Drainage problem of some sort is usually the cause. Could be blockage before your drain pump, in your drain pump, or in your drain hose. One possibility is that you just installed a garbage disposal and forgot to remove the "knock-out" plug for the dishwasher drain line. Another cause can be that you have not looped your dishwasher drainline under your sink and water from your sink is flowing back into you dishwasher. You must attach your dishwasher drain line under your sink so it is higher then your sink drain lines, creating a trap for your dishwasher. Your drain sump could be plugged, not letting the water get to your drain pump easily. This is caused by not getting loose or hard debris off your dishes before putting them in the unit. Also make sure your drain pump is getting the right voltage when it is supposed to.God bless youfa618d8b-d0fd-412a-b0d5-a88d44bf89d3.giffb1320dc-7bec-4cb0-98ed-c24cf54e5e3b.jpg
Apr 02, 2013 | Dishwashers
The hose detached from the garbage disposal. I re-attached it and now the water can't pump out of the bottom of the dishwasher
You have a clogged drain, remove the sink trap and use a plumber's snake to unstop the clog. Reattach the trap under the sink and disposal should drain. The pressure from the dishwasher pump more than likely caused the drain to slip loose, it's a drain, and it should not have any backpressure.
Jul 08, 2012 | Whirlpool Dishwashers
Maytag dishwasher MDBH985AWS1 won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 19, 2011 | Maytag Dishwasher
Water will not pump out of my Maytag dishwasher!!
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Mar 25, 2011 | Maytag Dishwashers
My maytag dishwasher won't drain. It is not clogged. It just won't drain
Hi
Jan 31, 2011 | Maytag 24 in. DWU9202 Built-in Dishwasher
How do i unstop drain?
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 29, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
Will not drain, pump runs, how to unstop it
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Thank you !!
Jul 13, 2010 | Hotpoint 24 in. HDA3400G Built-in...
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Oct 30, 2008 | Maytag 24 in. MDB7650AWS Built-in...
Maytag 24 in. MDB5600A Jetclean II Built-in Dishwasher Logo
123 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
