Question about EliteGroup P965T-A Motherboard
Hi, I had a computer with motherboard ECS P965T-A. What I want to ask is "can this mainboard support for 1 TeraByte Hard Drive?" Thank you in advance.
  • 233 Answers
of course you can. capacities not be a problem.
Posted on Jan 04, 2011
Describe your (ECS 915PL-A2) Motherboard Problem do not detect hard disk and dvd rider in the bios
1. Check if both drive data and power cables are correctly and tight fitted.
2. If both are fitted on PATA (IDE) on the same port/cable:
The harddisk should be the MASTER and DVD the SLAVE device.
3. Recheck.
4. If not OK, Power OFF the computer (also from the wall outlet).
5. Place the mainboard jumper for CMOS RESET to the other position for a few seconds and place it back.
6. Turn the computer Power ON and check.
Aug 25, 2011 | EliteGroup (ECS 915PL-A2) Motherboard
Unrecognise SATA HARD DISC Mainboard : ECS G31T-M
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 24, 2011 | EliteGroup ECS G31T-M Motherboard - Quad...
Is core duo e8400 compatable with ecs P965T-a motherboard. I cant get it to boot
The mobo is in fact compatable with the core 2 duo socket 775 chips.
Where does it hang on boot? Do you get the POST?
Apr 25, 2009 | EliteGroup P965T-A Motherboard
Tower top mounted USB portss
The cables from the front panel USB connectors have a key in them that will line up with the missing pin on the board's USB headers. Just line up the connectors and plug them onto the board. It doesn't matter if you use USB1 on the board for the plug marked USB1.
Apr 12, 2009 | Computers & Internet
What is the biggest HD I can install using the original BIOS (2006 version)
Yes you can install that drive. The only thing your limited on is the number of drives you can install..
Jan 27, 2009 | ECS 945P-A (V3.0) Motherboard
Reseting...
The reset jumper for an ECS P965T-A (V1.0) is J1 color red tag as "Clear CMOS Jumper" located near the Lithium memory battery. To reset, simply move the jumper temporarily to the opposite end/pair and revert back to original position soon as finished. pls refer to below image.
Alternately, removing the memory battery for a couple of minutes also reset the CMOS/BIOS configurations.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 31, 2008 | EliteGroup P965T-A Motherboard
EliteGroup P965T-A Motherboard Logo
42 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
