I have an EL-M710G calculator, and i have lost the instruction for setting the vat rate, could you help please, it has been set on 17.5% for years, need to change to 20%
  • 193 Answers
TO CHANGE TAX RATE PRESS CA THEN +TAX PUT IN 20.00 THEN DO YOUR CALCULATIONS
Posted on Jan 04, 2011
INSTRUCTIONS DOWNLOAD: http://www.sharp.co.uk/cps/rde/xbcr/documents/documents/om/30_cal/ELM711G-M710G_OM_GB-DE-FR-ES-IT-SE-NL-RU.pdf
Posted on Mar 22, 2011
How to change date and time on a sharp EL - 1197P calculator
Found Instructions for EL-1197PIII Calculator, think its the same thing
To set up date, time, conversion rate, and tax/discount
rate, place the switch at the "RATE SET" position. Date: · Enter in the order of month, day and year, then press to complete the entry. · Use to separate month, day, and year. · When is pressed, the number entered is evaluated and displayed as “date” if the value is within the following range; “Error” is displayed otherwise, and the previously set date is restored. Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits) Time: · Enter in the order of hour, minutes, then press to complete the entry. (There is no entry available for the seconds value. The clock starts at zero second.) · If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”. · Use to separate hour and minute values. · When is pressed, the number entered is evaluated and displayed as “time” if the value is within the following range; “Error” is displayed otherwise, and the previously set time is restored. Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Apr 06, 2010 | Sharp EL-1197P Calculator
Sharp 8 dgit calculater .elsimate,el-m710g model.how to set tax rate
Jan 13, 2010 | Casio DF-120TV Calculator
How do I set the GST/VAT tax rate on a Casio WM220T calculator
This works on several different casio calculators
Press AC butoon
Press AND HOLD % /Rate Set button for 2 to 3 seconds - This is important
Press Tax+ button
Input the tax rate you want eg: 12½% = 12.5
Press the % /Rate set button again
Voila
Aug 27, 2009 | Casio Office Equipment & Supplies
How to change tax rate on Casio MS120TV
I found the solution listed against a different CAsio Calculator.
It was .. Press AC, then hold 'set' for a few seconds then press 'Tax+' , input new tax rate then press 'set'. Job Done
Jan 06, 2009 | Casio FR-2650Plus Calculator
Casio Euro & Tax FR 620TER
To change the VAT rate:-
1) Press the [CA] button
2) Hold the [SET/%] button for about three seconds until the display reads 0.
3) Type 15 for the new rate of VAT
4) Press [TAX+} button
5) Press the [CA} button
To check the new rate you have press [CA] and [TAX+] to show the current rate, the [VAT-] is linked to the [VAT+] button and doesn't need changing.
Hope this helps
Dec 11, 2008 | Casio Office Equipment & Supplies
Setting tax
If the model is EL-2125 , and not 2125C or 2125E the following will work
1)switch on
2)press CE and then CA (you should see 0. with small 00 in top left hand corner but nothing else)
3)press M- button (rate set button),current tax rate 17.50% will appear with tax at left hand side
4) type new rate eg 15.00 (making sure to hit the decimal and two zeros, tax at the left and % should still be on the screen)
5) press M- (rate set button) (small 00 will appear in top left hand corner)
6) press = ( new rate and G will appear small 02 in top left hand corner and = sign below it)
hope this works for you, please let me know either way
David
Jul 31, 2008 | Hanns.G Corporation HW191D 19" LCD Monitor
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
May 01, 2008 | Sharp EL-330AB Calculator
588 people viewed this question
k24674
jasbo
jasbo
