Question about Kitchen Ranges
Inglis Royal electronic stove. Wehad a power outage. How do you reset the clock
  • Maureen Holte Dec 05, 2008
    I plugged in my stove and can't reprogram the time any suggestions?
  • Anonymous Jan 29, 2009
    Englis stove 37600 unable to set clock
To set the time. The top strip on the upright part of the stove , where the clock is, flips up. The directions are under it.
Posted on Jul 11, 2008
Oven sets only at 35O won t accept other settings
Posted on Jul 31, 2008
F9 error message after power outage
The F9 is a door lock latch circuit problem, either the motor latch or the control/power supply board will need to be replaced.
Mar 22, 2008 | Jenn-Air JES8750 Electric Kitchen Range
Electrical power is off on my Hotpoint 183D6027G069, even though power is on for all other appliances and all circuit breakers checked normal.
I'm guessing this is a gas / propane stove - so the power is likely 120v if in N. America. If this is the case, I would unplug the stove and plug it into another outlet. If none is close enough, you should be able to run an extension cord to determine if it is an outlet or stove problem.
The 120v is needed on gas stoves mostly for lights, electronics, clock, ignitors, etc. It is not for heating / cook of foods so a decent cord should be fine to use. If it still refuses to function on a known to be good outlet, the power outage you had has caused a problem in the stove and will likely require service.
Mar 12, 2013 | Kitchen Ranges
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Electric panel on stove is locked after a power outage everything else works fine, light and stove top, but panel to oven is not working at all it will not let you press anything
have you tried resetting the power to the complete stove by cutting the power to the complete stove and reconnect5ing after a few minutes, it might bring the normal operation to the clock and control circuit, I do not see any other component that would cause a lock up mode on the control panel other than the electronic circuit itself< AT ABOUT A HUNDRED DOLLARS IT MAY BE A GOOD IDEA TO HAVE A REPAIRMAN TAKE A LOOK>
Jan 14, 2010 | GE Spectra JBP78 Electric Kitchen Range
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Had a power outage and since then my inglis digital stove does not work. all the light's come on but no heat on burners or oven.
my control panel doesn't light up for both ovens and the clock too. The porclain stove top all five panel do work... could i have blown a fuses? in the oven its self .
Apr 15, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
409 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
