Question about Samsung Heating & Cooling
I couldn't on the air-cond. it will turn off automatically whenever I switch it on. Light keep blinking over the air-cond
  • 2,133 Answers
1. May be your blower motor mechanism locked. Replace bearings or motor. 2. Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor.
Posted on Jan 04, 2011
Honda CR-V ac light will not switch of unless I turn all the switches to the left when on just keeps flashing
Usually means there is a problem with the air cond system. It also runs in the defrost mode.
Nov 22, 2015 | Honda CR-V Cars & Trucks
The filter light keeps blinking. the filter isn't dirty. the filter is in the front and slides out either side. we keep it clean. so.. how do i get it to quit blinking? is there some regular...
Pam, be sure tat the filter is properly installed. Whenever you remove the filter for cleaning, be sure to turn the unit OFF, before removing it. And back ON after it is cleaned and reinstalled.
For the blinking problem. Turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes. Once the time has elapsed, plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, during that 15 minute timeout, the unit's electronics reset themselves and reverted back to the original factory settings. If so, the filter light should have stopped blinking, if the filter is installed properly.
I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 29, 2011 | Whirlpool ACQ122XK Air Conditioner
Air cond dash light works, compressor doesn't go on.
AC's have a low freon switch that shuts off the system to protect the compressor in the advent that you have a freon leak have the system checked for a leak
May 28, 2009 | 1996 Toyota Camry
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Wii console keeps swiching on after i set it up wirelessly
whenever the wii is getting information online, the disc slot blinks. it is supposed to do this (ps do not confuse the green power light with the yellow)
Nov 21, 2008 | Nintendo Wii Console
Will not ignite properly
If you look at the wiring diagram in your furnace you will see that 4 blinks means there is either a blockage of air or your room air blower is not working. Check the air filter for any debris first. Then test the room air blower to see if it turns on and blows enough air prior to going out on code. Are all the dampers open both in the pipes as well as at the registers?
Oct 14, 2008 | Goodman GMS90703BXA Heater
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Heating & Cooling Logo
147 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
