Question about Microsoft Windows 7 Ultimate, Full Version (PC DVD)
Windows 7 ultimate Vaio VPC-F12Z RAID 5 does see only 1,9 terabytes LaCie 4Big Quadra Hard disk (4TB)
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 31 Answers
Guys need windows 7 key can go link http://proudctkeyhere.blogspot.com to got. My key got here and after i used is great works. Hope can help you.
Posted on May 04, 2016
    Problem Solver:
  • 6 Answers
  • es2ryahee!!
Posted on Jan 04, 2011
LaCie 2big Triple - I replaced one drive, but capacity is wrong
Most likely the problem you are encountering is due to the RAID mode the device is set in. Most RAID arrays utilize multiple drives of the same size, or with drives of differing size, they just use a portion of the largest that matches the smallest drive. When the device rebuilt the array it partitioned off a portion of the 4tb drive of the same size as the existing 500gb drive. If you want to use full capacity of both drives you would need to use JBOD mode, which just strings the disks together into a storage pool using all available space. This won't offer the data redundancy of RAID1 or speed boost of RAID0, but should allow using full space.
Backup any vital data before doing anything, then look for a switch on the back. Rather than RAID0 or 1 the options may be labelled Safe or Fast, but JBOD is usually still labelled JBOD, or sometimes Big. You can try just flipping the switch to JBOD and seeing if it rebuilds to use all space. If that doesn't work you may need to remove the 4tb drive, connect it to a different system and erase it to get rid of the 500gb partition, then with the Lacie set to JBOD reinstall the 4tb drive so it will add its full size to the array.
The safest option though would be to buy another 4tb drive, backup all data and install both 4tb drives with the device set to RAID1/Safe. You would only get 4tb of total storage, but it would mirror the data on both drives so if one fails the other will still have your data. With JBOD you won't have any auto-backup. If a drive fails the data on it will be lost.
Jan 21, 2014 | LaCie 2big Network (2-disk RAID) (301257U)...
4big Quadra drive not appearing in disk utility or LaCie desktop manager
Could be defective. Try swapping power cord and usb cable with know good ones. You could also plug it into a different (known working) usb port.
Good Luck
Nov 28, 2013 | LaCie 4TB Biggest Quadra U SATA II Hard...
I have a 1TB LaCie 2Big Quadra. It has 2 500GB and runs on RAID 1. I replaced both 500 GB LaCie drives with 1.5 TB LaCie drives, but my computer only recognizes the original 500 GB. I formatted both...
I have the same problem too on my 2big form lacie . If I use 2x 1,5 tera disk in "fast mode" or in "big mode" my disk manager only shows 746 gigs available (it should be at least 2,5 terra).
If I use "safe mode" so my system can see 1,3 tera available, wich is normal for a raid mirror configuration.
I hope to find a solution quickly.
Dec 13, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
Product: LaCie 2big quadra ((Professional 2-Disk RAID. I have no back-up with the 2 disks, and this soon after purchase (August 2010). Serial number: 5102001839. Disk 2 does not work. At the front, light...
If the failed hard disk drive is replaced with the exact same capacity, RPM and make of hard drive, then the array can be rebuilt. Raid 0 cannot be rebuilt as each drive contains half of the data, If RAID 1 then can be rebuilt as data on each drive is an exact copy. However if combination of RAID 0 and RAID 1 then can be rebuilt. It's best really to handel this hands on, I recommend taking it to a computer technician especially if the information on it is important.
Thanking you
damnor01
Nov 13, 2010 | LaCie 2TB 2BIG QUADRA RAID EXT ESATA FW800...
I am trying to format my lacie 4big quadra raid drive for FAT 32 so that I can use with Mac and Windows. My windows machine won't recognize it so I am not able to format and use with both Mac and Windows....
You cannot format a 4GB drive ALL under FAT32, it is NOT mathematically possible IT will be possible to Break Up the drive into Partitions, and then Format them FAT32. You need to keep each partition under 1GB.
Mar 13, 2010 | LaCie 4big Quadra 4000 GB
4 big quadra 6 TB, win7.0 pro,i can see the unit, format it,etc. but always in raid 0, the unit doesn´t change when i tried to reconfigure it to raid 5, and i have followed the lacie instructions
The hard disk might originally came from a computer with raid 0 configuration that is why no matter what you do to reformat, it will always give you the same drive space as your Raid 0. The solution to your problem is actually deleting the partition first from another computer before formatting.
You will be needing a windows installation disk and you can plugin the big quadra thru the usb cable in another computer. Run the windows installation disk (this could be xp or vista) and when it prompted you to choose a task, just press enter to start windows installation (DO NOT press R to go to recovery console). Next, the system will search of every available partition and will show you the drive partition for your Big Quadra. Select for it and delete the partition from there. After it has been deleted, you can cancel that installation process from that computer and try re-formatting your drive into Raid 5 again as you have been doing before.
Should you have any question, please feel free to ask. Good luck!
Feb 24, 2010 | LaCie Computers & Internet
I'm running Windows XP professional. Have plugged in my Lacie d2 Quadra (500 GB). Device manager shows that it is working properly, but it is not initialized and it doesn't show up on my windows...
1.
log onto d computer as administrator
2.
start->my computer->manag
3.under storage->disk management
4.ef intialize ndcovert disk wizard appers click next ef not skip to step 8
5.on d selct to disk intialize page click next
6.on d select to disk covert page click next
7.on completing dhese two click finish
8.right click u r external drive nd click format
9.in d format dialog box type d name for u r external hard drive nd then click ok
10.click ok again
Sep 14, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
WIndowx XP can't see my LaCie Big Disk 3TB
did you checked disk management? is it formated to basic or dynamic?
Jul 10, 2009 | LaCie 3 TB Biggest Quadra External Quad...
Disk manager only sees 25% of it
your partition size is incorrect not disk manager
Apr 27, 2009 | Computers & Internet
Microsoft Windows 7 Ultimate, Full Version (PC DVD) Logo
66 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
