ADFDOOR IS OPEN IN HP PRINTER WHAT PROBLEM - Office Equipment & Supplies
  • 126 Answers
The document feeder on top is open. the document feeder is the part where you put the paper to copy.open and close that cover again.
Posted on Jan 05, 2011
Hp color laserjet 2550l need driver for my mac
Sir/Madam
The latest HP printer driver for devices listed below are built into Mac OS X 10.6. You do not need to download or reinstall any HP software for full printing functionality.
HP LaserJet print drivers are included in Apple's Mac OS X 10.6 Snow Leopard DVD and also available via Apple Software Updates.
Please Visit official HP Printer website Below Link URL:
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01844302-4%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken#N1000E
Snow Leopard - HP LaserJet printer setup instructions
  1. Upgrade install from Mac OS X v10.4, 10.5:
If updating a Mac using the Snow Leopard DVD, the install process should automatically detect your previous HP printer queue, delete, and then create a new HP printer queue using the latest HP printer drivers included in Snow Leopard.
USB printers:
  1. Make sure printer is turnedOnand connected.
  2. Open a document to print, and then choose File , Print .
  3. Open the Printer pop-up and choose your printer.
  4. If you don't see your printer, choose Add Printer , and then selectMore Printersbutton.
  5. In the Name column, select the printer, then clickAdd.
Network printers:
You can connect to HP printers on your local network that use Bonjour, IP, and Open Directory, as well as shared printers connected to an Apple Airport base station.
NOTE:Apple does NOT support AppleTalk in new Mac OS X 10.6.
  1. Choose File , Print .
  2. Open the Printer pop-up menu and choose your printer. It may be in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu.
  4. A dialog appears listing any Bonjour, IP, shared, and Open Directory printers on your local network. It may take a minute or two for your printer to appear.
NOTE:On larger networks, outside the Bonjour link-local network, your printer may not show up in the list. You can connect to the printer using IP. An IP printer is a network printer that uses TCP/IP protocol (such as JetDirect, LPD/LPR, IPP) to communicate with your printer. You need to know the IP address or DNS name.
  1. Click IP in the toolbar.
  2. Select HP Jetdirect - Socket in the Protocol pull down menu.
  3. Enter the printer's information available from printers front panel or printers network configuration page.
  4. The system should automatically bind to the HP print driver in thePrint Usingpull down menu.
  5. ClickAddto create the HP printer queue for your HP LaserJet.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays, duplex unit, or extra memory. If it can't, a dialog appears that lets you specify them. Make sure the settings in that dialog accurately reflect your printer's installed options to enable full functionality.
  1. Clean install of Snow Leopard or setting up a new Macintosh with Snow Leopard already installed:
If configuring a new Mac running Snow Leopard or if performing a new or clean install of Snow Leopard:
For USB connected printers, the install process should automatically create a new HP LaserJet printer queue using the latest HP printer drivers included in Snow Leopard.
For network connected printers, follow steps below.
USB printers:
  1. Make sure that printer is turnedOnand connected.
Network printers:
Or
In Case You Have Still Problem Then Please Foll Us On:
HP Printer Support
Feb 12, 2014 | HP LaserJet Office Equipment & Supplies
How to open hp 5150 printer?
Hernando, this depends upon your version of Windows. Go to Start, then either My Computer\ printers & faxes, or Start\devices and printers, or whatever it takes to open your printers. Check to see if your HP 5150 is listed. If not, you will need to re-intall the disc that came with your printer, or go to HP.com and download the drivers for your model of printer.
Sep 10, 2012 | HP Office Equipment & Supplies
Not printing from a mac
Use one of the following methods to print, depending on how the printer is connected to the computer. hpweb_1-2_minus.gif Method one: Printing from a USB printer
  1. Make sure your printer is turned on and connected.
  2. Open a document to print, and then choose File > Print .
    NOTE: You can also go directly to System Preferences > Print & Fax .
  3. From the Printer pop-up menu, choose your printer. If you do not see your printer listed, choose Add Printer , and then click More Printers .
  4. In the Name column, select your printer, and then click Add .
hpweb_1-2_minus.gif Method two: Printing from a network printer You can connect to HP printers on your local network (wireless and Ethernet) using Bonjour or IP, as well as shared printers connected to an Apple Airport base station.
NOTE: Apple does not support AppleTalk in Mac OS X 10.6.
  1. Choose File > Print .
  2. From the Printer pop-up menu, choose your printer. A dialog appears, listing any Bonjour printers on your local network. It may take a minute or two for your printer to appear.
    NOTE: Your printer may also be listed in the Nearby Printers submenu.
  3. If your printer does not appear, choose Add Printer from the Printer pop-up menu. Printers that are turned on and connected to the local network (wireless and Ethernet) should appear as Bonjour devices.
  4. Select your device from the list, and then click Add to create the HP printer queue for your HP Photosmart, Officejet, or Deskjet All-in-One printer.
Your computer can usually detect whether a printer has special accessories installed, such as additional paper trays or a duplex unit. If it cannot, a dialog appears that lets you specify them. To enable full functionality, make sure the settings in that dialog accurately reflect the installed options.
The latest HP Utility is included in Mac OS X 10.6.
Method one: Open the HP Utility from System Preferences
  2. From the Apple menu, choose System Preferences .
  3. Click Print & Fax .
  4. In the list of printers on the left side of the dialog, select the HP All-in-One to view the options in the Print & Fax window.
  5. Click Options and Supplies .
  6. Click the Utility tab at the top of the window, and then click Open Printer Utility . The HP Utility opens. Features and options may vary depending on your printer model.
Method two: Alternative The HP Utility can also be launched from the printer icon in the dock to open the Printer Browser window.
  1. Double-click the printer icon. The Printer Browser window opens.
  2. Click Printer Setup in the toolbar.
  3. Click the Utility tab.
  4. Click Open Printer Utility . The HP Utility opens. Features and options may vary depending on your printer model.
Jan 18, 2011 | HP Officejet 6310 All-In-One InkJet...
HOW TO SET HP LASERJET 1005 PRINTER SCANER ERROR 12
how to solve engine scanner error for hp laserjet p1005
Oct 10, 2010 | HP LaserJet M1005 All-In-One Printer
Hp 2480 desk jet printer prints photos with a large white border at the bottom how do i fix this? - thanks - Andy
Cleaning cartridges
# Open HP Solution Center:
* Windows XP: Click Start , click All Programs , click HP , and then click HP Solution Center .
* Windows Vista: Click the Windows icon , click All Programs , click HP , and then click HP Solution Center .
HP Solution Center opens in a new window.
# Click Settings
#In the Print Settings area, click Printer Toolbox . The printer Toolbox opens.
#On the Device Services tab, click Clean the Print Cartridge(s) ( ).
#Click Clean to begin the process.
Can check by cleaning the Roller inside - Problem usually come because of the dust on the roller
Happy new year
Jan 03, 2010 | HP Office Equipment & Supplies
My hp solution centre wont open
Mine was a different, but very similar model. I had to reload mine from the hp web site. It gives detailed step by step instructions. My printer had disappeared as well, had to reload it. No idea where any of it went, just opened it up one morning and it was gone. Have you chatted online with hp?
Jan 17, 2009 | HP OfficeJet 6210 All-In-One InkJet...
k24674
jasbo
jasbo
