Question about APC Back-UPS 300 UPS System
UPS 300 when power is out or unpluged does not provide power
When you unplug it all it does is make a alarm sound and does not provide backup power.
    Problem Solver:
  • 14 Answers
Many times the battery is bad. But before you invest in a battery,test the battery. Volt meters are cheaper than batteries and everyone should have one, or a friend that does. It will show you if the battery is dead. And if it is you can test if the UPS is charging it or not at the battery terminals. This way you won't waste money on a battery for an ups with a bad circuit board.
Posted on May 05, 2009
    Sergeant:
    Champion:
  • 214 Answers
Change the battery
Posted on Jul 22, 2008
I have a Tripp Lite G1010USB uninterruptible power supply that only powers the surge surge-suppressor outlets and not the battery-backup outlets. Unless the UPS is unplugged from the wall, and then i
You know they have a TWO YEAR Warranty ?
Sounds to me that it is faulty (one of the relays or switches is not providing 'through' power to the supposed 'backup' socket when the AC power is on.).
Have you followed the manual ?
available here http://www.tripplite.com/support/model/mid/G1010USB
Have you done a 'self test' ?
'To Run a Self-Test: With your UPS plugged in and turned on, press and hold the MUTE/TEST button for two seconds. Continue holding the button until the alarm beeps several times and the UPS performs a self-test. See "Results of a Self-Test" below.
Note: You can leave connected equipment on during a self-test.' see manual
If the LCD does not give you the answer then it is faulty. Seems like something went faulty on restarting your UPS in the morning.
Seems like plenty of help available from this companys' website.
Sep 13, 2014 | Tripp Lite Ups Battery Backup G1010usb
Constant alarm but works fine otherwise
Jordan,
It probably burned up one of the capacitors on the board that signal the UPS to turn the alarm off. I've had this happen before and I unplugged everything, turned the UPS off, disconnected the batteries and then opened the UPS up to cut off the tiny, annoying, surprisingly loud speaker. I then put everything back together and that was the end of it :)
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
Feb 02, 2013 | Opti -UPS PowerES 1000 UPS System
High frequency alarm sounds even when all components are unplugged from unit...even if I turn the unit off. The only way I can get it to stop is to unplug the unit.
You may have a problem with a Flat battery? Try taking the battery out and charging it, or swap it for a known good one, if this will not fix it, then you have a failure within the electronics, if this is so then it will need to be serviced by a professional.
Oct 12, 2011 | APC Back-UPS RS Battery Backup (apw...
Ups gave long continuous sound
A couple of things, first, are there any high-load devices plugged into the battery backup side of the unit? (Microwave, laser printer, and so on.) If so, there's your problem :). These devices cause a BIG load on your power system and need to be on the "surge protection only" side of the unit or plugged in to another surge suppressor.
If that isn't the case, it sounds like the UPS battery is bad. Here's something to try:
1. Shut the UPS off when this happens.
2. Take ALL load of of the "battery backup" plugs by unplugging them.
3. Start the UPS.
4. After the short self-test (the light blink and a few clicks are heard, in most cases), you should see a green light.
5. Plug in the loads that you unplugged from the battery backup side one at a time.
6. As you plug each one in, leave the ups turned on, but yank the power cord from the wall (unplug the ups from the wall while powered on and plugged in with a device drawing backup power from the unit)
7. Then, if the alarm goes off, you've confirmed that the battery can't take the load. So, it'll need to be replaced.
You can obtain ups batteries just about anywhere. (e.g www.planetbattery.com) All you need is the model number off of the battery and you can order a new cartridge. Make SURE the battery looks like and has the same voltage as the bad one to be sure your new one will function properly. Your manual should cover opening the battery door and replacing the battery.
Regards,
cyan990
Jun 03, 2011 | APC Back-UPS XS900 (BX900) UPS System
Hello! I'm from Riyadh Saudi Arabia. I've left on my Tripp Lite UPS 1000 just last night. When I came in my office in the morning, my desktop computer including my computer server was OFF. I supprised that...
Unplug the computer. Then run the UPS self-test and the unit will display whether it finds an overload fault, whether the battery needs to be charged or replaced.
Here are the instructions (copied from the User Manual):
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Jul 01, 2010 | Tripp Lite (OMNIVSINT1000) UPS System
Alarm sounding
ur internal backup battery is drained...change the battery....
+ the UPS may not be charging the battery...
Dec 21, 2009 | APC Back-UPS® ES UPS System
My Powercom UPS overload
remove all loads, unplug it, turn it off, wait 1 minute, plug it in, turn it on, apply loads. if this does not solve the problem, replace it.
Jun 08, 2009 | Computers & Internet
I bought a TrippLite Internet Office UPS surge protector in January 2009. I have misplaced the manual. Recently it began to beep for no reason. There is no power failure. It was so annoying I had to unplug...
this unit come with 4 with battery backup of 12v 7ah. check what are the indicator display shown?
it very diffcult know what the problem if u can give more info. u can try to replace the battery with new batts.. and test the ups if it not beeping again it show the battery problem. or maybe you had plug in more the the power consumtion that why it keep sound the alarm indication overload try to serperate the load. if u wan a user manual go to this website to download the manual: http://es.tripplite.com/support/manuals/index.cfm
u will get will u wan...
Apr 12, 2009 | Tripp Lite Tripp-Lite Internet550U 550VA...
Opti-UPS 1400ES UPS unit - Beeping 14 Times, stops, Beeps Again.
you can try this asia systems technologies look for our sale person william +65 65478990 william@asiasystemstech.com i suspected that now that u UPS is have hardware issue.. to determine if the unit is really the problem it hav to be do a further diagnos..
Mar 04, 2009 | Opti -UPS PowerES 1400 UPS System
My APC keeps beeping.
possibly..you have unpluged or dislodge you power cable from the outlet or from the power plug shuye at the back of your ups.. double check all the plug and re plug all your power cables !!!! make sure they are tightly pluged in and firm in their outlets..
Jan 26, 2008 | APC Back-UPS Pro 650 UPS System
APC Back-UPS 300 UPS System Logo
212 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
