Question about LG Microwave Ovens
All my products are failed becoz of the incorrect temperature plz let me know how to use the microwave
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Jan 04, 2011
Emerson Microwave MW9117W. Timer Counts down and turn table stops, but continues to hum as if microwave is still running. Have to unplug to stop it. Anyone know what problem is? Thanks
Sounds like you have a ''smart board" or door switch problem, try to un plug the product, push all the 'buttons' on the control panel and then plug the product back in, if this does not correct the problem you have a component that has failed.
Jan 09, 2015 | Emerson Microwave Ovens
Tell me plz how can i understand about temperature bcoz microwave show in percentage
example if the microwave es 1500 watts if you use the 30%, your are 450watts only, and so on.
God bless you
Jun 18, 2013 | Microwave Ovens
I want a manual for a technika microwave oven please
Hi brucegoldbur ,
Plz mention the model no of the product to get the specific manual.Plz try this link , hope it works for you if not kindly revert:
http://www.microwavewizard.com/sharp-microwave-oven-manual.html
Thanx
Aug 25, 2011 | Microwave Ovens
Fan turned on by self, won't turn off
The unit has a temperature sensing device that turns on the fan if it gets too hot...if it is very hot in your house it could turn this on...
If it is not overly hot then the thermistor or the main control board have gone bad and are reading an incorrect temperature...
heatman101
Aug 06, 2011 | Maytag Appliances Over-the-Range Microwave...
Sharp Microwave Oven model R-330J(W) will not heat up, the display says cooking, timer countdown to zero, hear relays click but water temperature test fail. need a service manual with electrical diagrams...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Load test.
A simple safety test.
Place 1/2 litre of water in a glass container. Measure the temperature of the water.
Place in microwave and heat on full power for 1minute.
Measure the temperature after it has stood for 1minute.
If the temperature difference is more than 9 degrees Celcuis the magnetron is working and producing about 700Watts of heat.
If your microwave is labelled with 900 or 1000Watts. That is about right.
If the temperature is less then the magnetron is not working properly and may need replacing.
This a only a rough guide and any doubts you should consult an authorised service agent.
Feb 28, 2011 | Sharp Microwave Ovens
A LG stainless steel curved interior wavedom 900 watt microwave. when cooking a potatoe it shutdown completely after overnight i reset the clock etc. and every thing works except no heat.I am not tech....
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Hope that helps.
Load test.
Jan 25, 2011 | Microwave Ovens
Maytag Model MMC5000BDB microwave, clock works but the microwave doesn't
Hope that helps.
Load test.
Jan 19, 2011 | Maytag MMV5156AAS Microwave Oven
My daughter put foil in my microwave. it will not heat now. i need to know if it can be fixed. the part number on the part that looks bad is RM228 60820BN JF P
Hope that helps.
Load test.
Jan 19, 2011 | Daewoo WM1010CC Microwave Oven
I have samsung CE103VD microwave.could you plz tell me what temperature n what time should i set to bake a cake on convection mode?
I too have the same problem i try to bake cake and it turns to become biscuit or it dosnt cook in the centre
Sep 17, 2010 | Samsung MT1066SS Convection/Microwave Oven
How do you set whirlpool microwave to 50% power
The microwave oven should be at a temperature above 50°F (10°C) ... microwave oven can be manually set to defrost. To defrost. manually, use 30% cook power. ...
www.whirlpool.com/assets/pdfs/product/ZUSECARE/8205987.pdf
Jul 03, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave Ovens Logo
15 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
