Back to:
Tags:
ASUS K8V-MX Motherboard
Problem loading windows xp
posted by ashish_2806 on Jul 09, 2008
when ever i try to install a fresh copy of windows xp ..it fails...it get hangs at the time when it says "installation will complete in 32 minutes " and it remains as such for ever , as i think there is problem in installing my network devices...how do i handle this situation without taking my system to an expert..?
Comment by ashish_2806, posted on Jul 10, 2008
hi i am ashish kumar with an id ashish_2806 ,i have only posted the query ,
my motherboard is ASUS K8V-MX.
and my chipset is AMD ATHLON ...
the problem is windows (XP) fails to install while installing network devices and halts ,when only 32 minutes is required for complete installation and the thing is it never shows any error but halts at this point ....
plz help
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by Latoof, posted on Jul 09, 2008
SILLY question... SORRY!
what motherboard is this? what chipset does it use?
Solution #1
posted on Jul 12, 2008
Not Rated (0)
map9966
Rank:Guru Guru
Rating: 89%, 1290 votes
Hi ashish,
Please click on this link for the last updated drivers posted by Asus for the K8V-MX motherboard.
http://support.asus.com/download/download.aspx?modelname=K8V-MX&SLanguage=en-us
After reading the trouble you seem to have this might not be windows hanging on installing a simple driver. You're trouble may be caused by the primary hard drive not allowing windows to write to the drive. There is no other reason why windows would hang. Window should load completely with out you having to install any specific driver from the Asus CD. Motherboard drivers like the LAN driver can wait until windows has finished installing its self.
(This is normal for a windows install).
Suggest you go to the hard disk drive, manufacture's web site & download their tool /utilities, setup software. (This software works out side of windows in a dos like mode). You can create either a bootable floppy disk or a bootable CD disk which will allow you to check the drive for internal errors. The software will clear the sectors & repair the hard disk drive if needed allowing window to install. You can also use the software utilities to format the drive rather than using windows. This will ensure there is nothing wrong with the drive. Than load you're window CD into the CD-ROM & install windows. When windows has finished installing you can than install the driver's from the Asus CD. Than go to the above Asus web side & download & install any driver's that are newer than on the CD. Lastly update windows to SP2. Do not install SP3 until you are 100% sure windows & the motherboard are running perfect.
Good Luck! Take you're time.
Mike
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on problem loading windows xp:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Latoof
Rank:Guru Guru
Rating: 88%, 186 votes
try disabling legasy USB devices in bios
Thank You!
Can you Help with these Motherboards problems?
Motherboards
I put my computer together and I don't seem to get a...
Motherboards
Does anyone know if 2GB ram of OCZ platinum work on Asus...
Motherboards
tengo una placa soyo 6bb 1.0 y necesito el manual para...
HI, you answered my query on the folowing...
Hi, I have bought a 500 GB SATA HDD and the drive is...
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
