Question about Linksys SR224 (srw224) 2x1000 Mbps Networking Switch
Hi, Im using Linksys SR224 24 ports as my main switch. I got a poor internet connection, this problem occurs few weeks ago. I tried to connect my modem through a LAN cable directly to my server and works fine. I also tried to rearrange my LAN cables but sometimes it i got poor connection or sometimes no internet connections. At the meantime I use my back-up switch. What cause this problem? Need Help Thanks.
  • 1,552 Answers
Try a brand-new cable between the modem and the "uplink" port on the router.
Try a brand-new cable from one of the "LAN" ports to your computer, and test to see that you get a good connection.
Posted on Feb 09, 2015
5 Suggested Answers
SOURCE: Connect Linksys 8-Port Switch to two PC's, a modem and printer
What's the model number of it? Is it a router/switch? Or just a switch?
The modem would go into a WLAN port. Everything else would go into the numbered ports.
If you pass me the model number then I can provide more information.
You'll want to connect one computer or laptop to it first before setting it up so you can configure the correct settings. You'll need the admin password. If it's just a switch, then you can just plug in; however, I strongly advise putting a router in between a modem and switch. You want to have a firewall in place.
Posted on Apr 01, 2009
  • 13 Answers
SOURCE: I have a Linksys 5-port switch connected to a cox
Because the cox cable modem will only bind to one mac address (computer). You need to purchase a router, any router linksys, dlink, will do, get a wireless one so you can setup wifi as well. Plug your cox cable modem into the wan port on the router, plug your pc into one of the ethernet switch ports, you can use your web browser IE to login to the router and secure your wifi signal, power cycle your modem to make it bind to the new router. Most linksys dlink are programmed for a class c network, you could in theory put 254 devices, computers on your connection now.
Posted on Aug 29, 2010
  • 16 Answers
SOURCE: doen Linksys sr224 support SRW224. I
Should be no problem. I would use the SRW224 as your main switch and hang the other one off one of its 100mbit ports.
Posted on Oct 25, 2010
  • 561 Answers
SOURCE: I have use SR224 Linksys
there might be loop in your network. unplug all devices from your switch and make sure there is not redudnt link in your switch ports
Posted on Oct 07, 2011
Cannot connect to internet using this~help!
Hi Friend,
Please follow the steps in order to resolve the issue;
I hope you have a cable internet connection.
1.Make sure the connections are properly fitted as mention below:
The wire coming out from the modem should be fitted into the WAN/INTERNET port of the router. Connect the computer to either of the four LAN ports.
2.At the back of the router there is RESET button, push and hold that button for 30 seconds and then release it.
3.Turn off the router for 30 seconds and turn it on after that time.
4.Type in the address bar of the web browser (Internet Explorer, Mozilla) and hit enter
5.Enter the Username and Password(default password is admin and leave the username blank)
6.Under the setup page make sure "Obtain an IP Automatically" is selected and DHCP server is enabled. click save settings
7.Now Click MAC Address Clone
8.Enable MAC Clone Service and click the TAB Clone
9.Click save settings and turn off the router for 30 seconds and Turn it on after 30 seconds.
I hope this will resolve the issue.
May 28, 2010 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Can not ping our netvanta 3200 from behind a Linksys nat router
The switch between the NAT routers and the Netvanta had some faulty ports ... the physical connection was broken. Once the switch was replaced, the internet connection was restored.
Dec 29, 2009 | Adtran NetVanta 3200 Router
I have a WRT54G ver.6. Was working fine until I went fron DSL to Broadband(cable) Now system won't connect. ???????
Are you attempting to use the device as a router or a switch?  Because if when you switched to cable you got a new router with it this device may be trying to steal this devices capabilities. Im assuming there are five ports, one to plug the Internet into and another to plug in the devices you wish to connect. Try plugging the Internet Ethernet cable (directly from your cable modem) into one of the four device ports and NOT the singular Internet port.
Sep 03, 2009 | Linksys Wireless-G Broadband Router
When I try to connect my router to my laptop, the 321 error screen appears after about a minute. It says my ethernet cable is not plugged in properly, but it definitely is. Even the connection lights on...
This is a well documented problem with linksys routers. Go to google and type in "error 321 linksys". You will have to manually configure the router as stated on the linksys forum posts.
Jun 05, 2009 | Linksys WRT54G2 Wireless Router
Im trying to hook up my xbox and get on the internet by using a linksys
Physically connect the XBox to one of the LAN connection of the router or be connected wirelessly.
If unable to connect to the Internet open these ports using the router under virtual server or port forwarding:
TCP 80, 3074 and 53
UDP 88, 3074 and 53
Note: Also the IP address of the XBox should be open to the section.
Mar 08, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Hi i have a satellite internet provider and im trying to set up my linksys broadband router so i can hook up my xbox 360 my problem is everytime i hook it up im getting no internet connection can you tell...
there are two things to be addressed in this case.firstly you have a satellite internet provider which can create consistency issue.then when you connect a xbox to router you need to do a port forwading on linksys router(port forwarding=opening ports in router so your xbox can communicate freely).in order to do the port forwarding you have to log onto router user interface.then go to applications and gaming tab,where you can do the port forwarding.
but before doing so,you have to contact microsoft to know the ip address assigned to the xbox and the ports(numbers) to be opened.
thank you.
Nov 27, 2008 | Linksys Wireless-G Broadband Router
Problem with a linksys ethernet cable router
The router may need to be reconfigure since you lost the internet connection , If you still have the setup CD you can just run it again or better call Linksys Tech support so they can walk you through with the process the number is 800-3267114 you can call them any time of the day..
Hope that helps.......
Sep 03, 2008 | Linksys WRT54GX4 WIRELESS 802.11G...
If the firewall is turned on you router you will have to turn off the ports that LimeWire uses.
Aug 04, 2008 | Linksys Wireless-G WRT54G Router
Linksys nro41 4-port router
Hi, I read your site and took it for face value, hoping to solve my problem. Like you offered, I would gladly pay $10 if your solution worked. But it seems like so many sites, pay up front and get ........... Sorry Paul
Jul 04, 2008 | Computers & Internet
No signal to my laptop
try to restore the laptop that doesnt work by going to start accessories system tools system restore then restore it a few weeks back try that
Dec 12, 2007 | Linksys Dual-Band Wireless A+G Broadband...
Linksys SR224 (srw224) 2x1000 Mbps Networking Switch Logo
204 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
